Radio Shack Amplified Mobile Extension Speaker
#58
4.2
based on 18 reviews
Ratings Distribution
5 star
12
4 star
3
3 star
0
2 star
0
1 star
3
Category Average
4.0
$36.99 at RadioShack
Find it at Amazon
Find it at Ebay
$36.99
from 1 store
Pros
  • Easy to use (11)
  • Durable (9)
  • Good reception (7)
  • Good value (7)
  • Clear signal (4)
  • Rugged (3)
  • Compact (2)
  • Great sound quality (2)
  • Powerful (2)
  • Weatherproof (2)
See less See more
Cons
  • Lack of power (1)
  • Loose connection (1)
  • Unexpected feature (1)
Best Uses
  • Outdoors (2)
  • Anywhere (1)
  • Boats (1)
  • In car scanner speaker (1)
  • Mobile (1)
  • Noisy (1)
  • Travel (1)
Provided by RadioShack
This amplified, mobile extension speaker provides the extra volume you need.
Specification Description
Model 21-541
Accessory Indicator Yes
Benefits Perfect for CB, scanner and ham radioPowerful, 7.5-watt output provides extra volume needed in moving vehicles
Body Material Multi
Cables Included 4-foot hooking cable with 1/8-inch plug
Capacity UOM mAh
Country Of Origin China
Description Header Get a copy on, louder and clearer.
Display Catalog Number 21-541
Enclosure Color Black
Included in the Box 1 x extension speaker with 4-foot hooking cable with 1/8-inch plug
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 21-541
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Outputs 1 x Phone 1/8"(Ext Sp)
Product Type Speakers
Protect your investment. Yes
Required to function CB, Ham, Business, or Scanner radio
Supported Languages English
Radio Shack Amplified Mobile Extension Speaker Questions
Questions and Answers
Where to Buy
$36.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 14, 2009
Radio Shack Amplified Mobile Extension Speaker Reviews
Most helpful positive review
Most helpful negative review
5.0
Kick As Speaker
"I recommend this speaker to anybody; I have had this speaker for approximately 3 years. It has been the best one out of all the others radio shack offers. I use this speaker for a police scanner and sometimes transmissions come in low to where if you had a regular speaker without being amplified, you would probably have a hard time listening to what they were transmitting. The short end of this is that it's a..." Read Full Review »
Sep 13, 2009 by elcapo
See more positive Radio Shack Amplified Mobile Extension Speaker reviews
1.0
This speaker failed to ...
"This speaker failed to remain under power. Power light would come on for about 10-20 seconds and then fade away. Returned it and powered replacement speaker directly off my truck battery in the RS parking lot. Replacement speaker did the same thing! RS store refunded my purchase price. I'd avoid this speaker as it cannot stay powered...." Read Full Review »
May 01, 2006 by Robert T
See more negative Radio Shack Amplified Mobile Extension Speaker reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Kick As Speaker
5.0
    Pros
  • Durable
  • Good Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Outdoors
  • Travel
"I recommend this speaker to anybody; I have had this speaker for approximately 3 years. It has been the best one out of all the others radio shack offers. I use this speaker for a police scanner and sometimes transmissions come in low to where if you had a regular speaker without being amplified, …"  Read Full Review »
Was this Portable Speaker review on the Radio Shack Amplified Mobile Extension Speaker helpful to you?
Sep 13 2009
elcapo
Deming,NM
I am:
  • Frequent Traveler
Reviewed at:
Price: $36.99
WHY? WHY? WHY?
4.0
    Pros
  • Clear Signal
  • Easy To Use
    Cons
    Best Uses
  • Noisy environment
"Why don't the instructions with the speaker say that it has a power down/time out feature? I thought the speaker was defective until I suspicioned what was happening. I confirmed the feature by coming to the website and noting others had mentioned it. It is a nice feature and it would help if the …"  Read Full Review »
Jun 13 2008
J. Fred
Lincoln, NE
I am:
  • Casual/ Recreational
Reviewed at:
Price: $36.99
Lots of Punch
4.0
    Pros
  • Clear Signal
  • Rugged
    Cons
  • Loose Connection
    Best Uses
  • In Car Scanner Speaker
"I bought this amplified speaker on the good reviews it had. Well, I had the same problem one other person had. It would power up and then turn off and no sound. It was late and I didn't want to go back to the store, so I took it apart. Turns out it was a bad solder joint on the audio input jack. I …"  Read Full Review »
Jul 12 2007
WB2VSJ
Apex, NC
Reviewed at:
Price: $36.99
Great speaker!
5.0
    Pros
  • Compact
  • Durable
  • Powerful
    Cons
  • None
    Best Uses
  • Anywhere
"I have had this speaker now for 13 years with no problems at all. Works great! I am thinking about buying another one for my HF Rig, to bad the price isn't the same as it was 13 years ago! See you on 20 Meters! "
Mar 18 2009
KC8DHV
Copperopolis, California
I am:
  • Amateur Radio Operator
Reviewed at:
Price: $36.99
[1 of 1 customers found this review helpful]
The catalog #21-541 ...
5.0
    Pros
  • Durable
  • Easy to use
  • Good reception
  • Good Value
    Cons
  • None
    Best Uses
  • None
"The catalog #21-541 Amplified Mobile Extension Speaker is pricy but well worth it. Recommend a 12 volt in-line noise filter to remove any ignition or alternator whine noise (discontinued from Radio Shack - but available at any auto parts store). "
 Report Abuse  (1)  (0)  0 comments
Oct 28 2005
Douglas K
Visalia, CA
Reviewed at:
Price: $36.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
