Radio Shack Adjustable-Voltage Regulator LM317T
#420
4.2
based on 10 reviews
Ratings Distribution
5 star
5
4 star
4
3 star
0
2 star
0
1 star
1
Category Average
4.1
$2.29 at RadioShack
Find it at Amazon
Find it at Ebay
$2.29
from 1 store
Pros
  • Consistent performance (7)
  • Versatile (6)
  • Good length (3)
  • Rugged (3)
  • Durable (1)
See less See more
Cons
  • Confusing data on package (1)
  • Confusing pin-out diagram (1)
  • Pin outs (1)
  • Will not go to zero volts (1)
Best Uses
  • Dorm room (1)
  • High-end equipment (1)
  • Hobby projects (1)
  • Model railroad circuits (1)
  • Special power supply uses (1)
  • Special voltage needs (1)
  • Travel (1)
  • When regulated volt neede (1)
Provided by RadioShack
Want options for your output voltage? This regulator has an adjustable range from +1.2 to 37VDC. May require heatsink in some applications.
Specification Description
Model LM317T
#per pack 1
Body Material Multi
Capacity UOM mAh
Country Of Origin Malaysia
Description Header Your headquarters for voltage regulators.
Display Catalog Number 276-1778
Enclosure Color Black/Silver
End Product Indicator Yes
Features Type LM317TCase Style: TO-220Maximum Output Current: 1.5A
Included in the Box Type LM317T adjustable voltage voltage regulator - case TO-220 (1)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model LM317T
Mounting Kit Case style: TO-220
Operating Temperature UOM ° F
Product Type IC-Analog
Required to function May require heatsink in some applications
Supported Languages English
Radio Shack Adjustable-Voltage Regulator LM317T Questions
Questions and Answers
Where to Buy
$2.29
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 3, 2009
Radio Shack Adjustable-Voltage Regulator LM317T Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[0 of 2 customers found this review helpful]
5.0
LM317T allows special power supply needs
"A very useful device for special power supply needs. Internal protection makes this voltage regulator almost bullet-proof. The pin-out diagram on [...] packaging can be confusing, due to the dotted-line reference to the back of the unit; it isn't clear as to whether the diagram refers to the front view or the back view. Try dowloading a datasheet from the manufacturer. The one that I used was made by ST Microele..." Read Full Review »
Aug 28, 2007 by goggomobil
See more positive Radio Shack Adjustable-Voltage Regulator LM317T reviews
1.0
Product Good, Failed on packaging
"Showing a pic on the back that implies to me a view of the back not the front, saying face-view would help even with the drawing looking as a back or drawing the view in 3D would help, but as it is there labeling sucks, other wise it is a good product! Recomend the product yes, but only if it has a data sheet online with the product, currently unavailable. Lee..." Read Full Review »
Aug 14, 2008 by Lee
See more negative Radio Shack Adjustable-Voltage Regulator LM317T reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
5.0
    Pros
  • Consistent Performance
  • Durable
  • Versatile
    Cons
    Best Uses
"A very useful device for special power supply needs. Internal protection makes this voltage regulator almost bullet-proof. The pin-out diagram on [...] packaging can be confusing, due to the dotted-line reference to the back of the unit; it isn't clear as to whether the diagram refers to the front v …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack Adjustable-Voltage Regulator LM317T helpful to you?
 Report Abuse  (5)  (0)  0 comments
Aug 28 2007
goggomobil
Detroit, MI
I am:
  • Practical
Reviewed at:
Price: $2.29
[1 of 2 customers found this review helpful]
Great item, bad data on back of package.
4.0
    Pros
  • Rugged
  • Versatile
    Cons
    Best Uses
"This is a must have for your parts drawer. If you need ANY voltage between 1.5 and 37 volts at up to 1.5 amps, this will do it for you.
The pinout and the schematic on the back of the blister package is fairly useless. The drawing is oddly presented with the back side up, the dotted lines make it …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Nov 3 2009
2N107
Hickory Ridge, MI
I am:
  • Casual User
Reviewed at:
Price: $2.29
[2 of 2 customers found this review helpful]
Confusing Schematic
4.0
    Pros
    Cons
  • None
    Best Uses
  • Hobby projects
"The schematic is confusing. The device requires two external resistors, one between the output and the adjust terminals, the other between the adjust terminal and ground. However, the connection of the capacitors is ambiguous. The drawing shows the capacitors joined end to end connecting the inpu …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 10 2007
Jack
Detroit
I am:
  • Tech Savvy
Reviewed at:
Price: $2.29
Couldn't be easier
5.0
    Pros
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Travel
"Too much unnecessary fuss about the case orientation. Since there is a transverse line visible (which is the top of the black chip) roughly halfway between the top and the pins, the view must be of the front. The back side of the case is flush, no such line would display there.
Quite easy to cr …"  Read Full Review »
Jul 3 2009
DogFather
Azusa, CA
I am:
  • Enthusiast
Reviewed at:
Price: $2.29
[1 of 1 customers found this review helpful]
Works fine and lasts a long time.
5.0
    Pros
  • Versatile
    Cons
  • None
    Best Uses
  • when regulated volt neede
"Schematic is OKWith meter on output and output shorted, voltage drops to 0 in a second with no sparks.Nice shutdown.Use a heat sink. If left off and unit is used on another project with a higher current need, it will blow.I bought out the whole supply of them in 3 [...] stores.They are needed for le …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 23 2007
Tekno
Phoenix
I am:
  • Gearhead
  • Technician
Reviewed at:
Price: $2.29
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
