Radio Shack 900MHz Wireless Indoor/Outdoor Mono Speaker
4.6
based on 16 reviews
Ratings Distribution
5 star
11
4 star
3
3 star
2
2 star
0
1 star
0
Category Average
4.4
Pros
  • Great sound quality (9)
  • Easy to use (6)
  • Good appearance (6)
  • Easy to connect (5)
  • Good value (5)
  • Attractive design (4)
  • Compact (2)
  • Powerful (1)
See less See more
Cons
  • Little big and heavy (1)
  • Range is too short (1)
Best Uses
  • Basic systems (3)
  • Audiophiles (1)
  • Larger rooms (1)
  • Portable (1)
  • Smaller rooms (1)
Provided by Buzzillions.com
This 900MHz speaker brings music or TV sound from your A/V system just about anywhere, indoors or out, without running speaker wire!
Radio Shack 900MHz Wireless Indoor/Outdoor Mono Speaker Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 900MHz Wireless Indoor/Outdoor Mono Speaker
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 29, 2007
Radio Shack 900MHz Wireless Indoor/Outdoor Mono Speaker Reviews
Most helpful positive review
Most helpful negative review
4.0
Great for taking the music outside.
"This was the most attractive of the outdoor wireless speaker systems I found - not much into the speakers encased in fake rocks. I bought two units and placed them outside in the courtyard. Hooked up one transmitter to my Pioneer receiver - BOTH units recieve the signal from the SINGLE transmitter and work fine at a distance of ~35 feet. No extra cords or splitters necessary. The sound is pretty good given the p..." Read Full Review »
Jun 30, 2007 by Winston
See more positive Radio Shack 900MHz Wireless Indoor/Outdoor Mono Speaker reviews
3.0
Speakers work well until ...
"Speakers work well until there is 30 seconds of silence and the transmitter automatically turns off. Then you get static pops until the player produces sound again to turn the transmitter back on. If there were a way to keep the transmitter from turning off after 30 seconds of silence, I would recommend it, however mine is going back to the store since this isn't an option...." Read Full Review »
May 31, 2007 by Mark B
See more negative Radio Shack 900MHz Wireless Indoor/Outdoor Mono Speaker reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
    Cons
  • NONE
    Best Uses
  • Basic Systems
"This was the most attractive of the outdoor wireless speaker systems I found - not much into the speakers encased in fake rocks. I bought two units and placed them outside in the courtyard. Hooked up one transmitter to my Pioneer receiver - BOTH units recieve the signal from the SINGLE transmitter a …"  Read Full Review »
Was this Speaker & Subwoofer review on the Radio Shack 900MHz Wireless Indoor/Outdoor Mono Speaker helpful to you?
Jun 30 2007
Winston
Louisiana
I am:
  • Musically Inclined
Reviewed at:
Perfect for my needs
5.0
    Pros
  • Easy To Connect
    Cons
    Best Uses
  • Basic Systems
  • Portable
"I wanted to take the audio from my computer and audio system anywhere in my house or outside on my three acre property. I just wanted sports play-by-play or background music, so a single mono speaker was perfect. The sound quality is very good and transmit distance is excellent. The unit is a lit …"  Read Full Review »
Aug 7 2007
Dr Bruce
Finksburg, MD
I am:
  • Practical
  • Tech Savvy
Reviewed at:
good product
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • range is too short
    Best Uses
  • None
"I have two of these units hooked up to computer. As long as you have the transmitter and the speakers set to same channel they work great!
I wish it had more range but it works. I plan on adding 2 more so i can have music completely around my building with out wiring!! "
Aug 10 2007
staledoe
Wichita Kansas
I am:
  • Tech Savvy
Reviewed at:
Excellent Quality, Simple to Use
5.0
    Pros
  • Attractive Design
  • Easy To Connect
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I purchased this product to use with my computer for internet radio listening around the house. It performs even better than I hoped with excellent sound quality and complete ease of use.
I am 100% satisfied! "
Jul 1 2007
Mike
Virginia
I am:
  • Audiophile
  • Practical
  • Tech Savvy
Reviewed at:
Bought this unit last ...
5.0
    Pros
  • Easy to use
  • Good appearance
  • Good sound quality
  • Good Value
    Cons
  • None
    Best Uses
  • None
"Bought this unit last May, and I've been completely satisfied with it. I've hooked it up to a ROKU Soundbridge for listening to the internet radio and it's performing perfectly. I'm trying to find out if I can purchase just another speaker to work with my existing one to put in another area at the …"  Read Full Review »
Aug 23 2006
Joe H
Rochester, New York
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
