Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
Displaying 1 - 5 of 5 Reviews
Radio Shack 9-Position Female Crimp D-Sub Connector Review
Pros
Cons
Best Uses
"I tried the "solder" version of the 9pin connector and it was very difficult to solder onto the pins.
So I went and got the crimp version. If you use 18awg is will be too big or 22awg and it will be too small. If the wire comes lose, there is no way to remove the pin and try again. You have to th
Read Full Review »
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Radio Shack part 276-1428
This same part is sold as both male and female in separately labeled bags.
It is not possible to use as female and the male setup is loose.
Recommend to avoid this part and get the soldered versions instead. 276-1538.
Does not include the tall nuts and/or bolts for the
Read Full Review »
[0 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"second one and i still cant figure it out, no instructions, pins dont fit in holes, just very bad product "
Pros
Cons
Best Uses
"Works good as a damaged replacement "
"wish it has good instructions "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
