Radio Shack 800MHz Scanner Antenna
#5
4.5
based on 60 reviews
Ratings Distribution
5 star
41
4 star
12
3 star
4
2 star
0
1 star
3
Category Average
3.6
$19.99 at RadioShack
Find it at Amazon
Find it at Ebay
$19.99
from 1 store
More Images
Pros
  • Durable (44)
  • Easy to use (27)
  • Good reception (25)
  • Strong signal (25)
  • Good value (24)
  • Easy setup (20)
  • Fine-tuning (8)
  • Attractive design (2)
  • Boosts signal ~50 (1)
  • Cheap (1)
See less See more
Cons
  • Poor reception / weak antenna (2)
  • Failed 2 ft drop test (1)
  • Flimsy (1)
  • Very narrow banded (1)
Best Uses
  • Portable devices (16)
  • Living room (7)
  • Anywhere (2)
  • Office (2)
  • Small rooms (2)
  • Bedroom (1)
  • Cruising around (1)
  • Everywhere (1)
Provided by RadioShack
Ideal for use with scanners monitoring 800MHz trunked radio systems used by police, fire and emergency services.
Specification Description
Model 20-283
Accessory Indicator Yes
Benefits Compact: 7" in heightMale BNC connector
Body Material Multi
Capacity UOM mAh
Country Of Origin China
Description Header Find what you need to come in loud and clear.
Display Catalog Number 20-283
Enclosure Color Black
Included in the Box Antenna
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 20-283
Model No model information available
Operating Temperature UOM ° F
Outputs 1 x BNC(Connector)
Product Dimensions UOM inches
Product Length 7
Product Type Scanner/HAM
Supported Languages English
Radio Shack 800MHz Scanner Antenna Questions
Questions and Answers
Where to Buy
$19.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Oct 13, 2009
Radio Shack 800MHz Scanner Antenna Reviews
Most helpful positive review
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Love this antenna
"I use this for my Pro-96 handheld scanner & it out performs the oringinal rubber ducky antenna. Whats great is that it helps bring in better reception on the 800 Mhz rang...." Read Full Review »
Jul 23, 2008 by IBN123-NH Feed
See more positive Radio Shack 800MHz Scanner Antenna reviews
1.0
Pretty useless
"I bought this to improve 800Mhz trunking on my new GRE PSR500 (the most amazing scanner ever made, BTW). I live 20 miles outside of Boston and wanted to pick up digital and conventional trunking signals. While it slightly improved reception on conventional VHF-Hi/UHF frequencies, it offered no improvement at all on 800Mhz, and, in most cases, missed signals that the standard rubber duckie picked up. Returned thi..." Read Full Review »
Apr 04, 2008 by Suzie
See more negative Radio Shack 800MHz Scanner Antenna reviews
Displaying 1 - 5 of 60 Reviews
Show
Sort by
Love this antenna
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"I use this for my Pro-96 handheld scanner & it out performs the oringinal rubber ducky antenna. Whats great is that it helps bring in better reception on the 800 Mhz rang. "
My Pro-96 & Pro-2096 scanners
  • Using Product
  • Picture of Product
Was this Antenna review on the Radio Shack 800MHz Scanner Antenna helpful to you?
Jul 23 2008
IBN123-NH Feed
Nashua, NH
I am:
  • Gearhead
  • Practical
  • Professional
Reviewed at:
Price: $19.99
Antenna gives me a 48% boost over OEM
4.0
    Pros
  • Boosts Signal ~50
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • Failed 2 ft Drop Test
    Best Uses
  • Cruising around
  • Living Room
  • Portable Devices
"This is a great antenna, and as mentioned provides a 48% boost over the stock antenna. I was surprised though when I accidentally bumped the scanner (PRO-196) and it hit the floor from a height of 18" or so... The antenna took a beating and bent >30 degrees, and then didn't work so well even after s …"  Read Full Review »
Oct 13 2009
enochian/raVen
Boise, ID
I am:
  • Enthusiast
Reviewed at:
Price: $19.99
Pretty useless
1.0
    Pros
  • None
    Cons
  • Poor Reception
    Best Uses
  • None
"I bought this to improve 800Mhz trunking on my new GRE PSR500 (the most amazing scanner ever made, BTW). I live 20 miles outside of Boston and wanted to pick up digital and conventional trunking signals. While it slightly improved reception on conventional VHF-Hi/UHF frequencies, it offered no impro …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Apr 4 2008
Suzie
Boston
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Reviewed at:
Price: $19.99
[1 of 1 customers found this review helpful]
GREAT SCANNER ANTENNA!!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Portable Devices
"This 800 MHZ antenna was designed to double the reception strength of this band only..however..I have found that it works just as well (living within a major city) with the VHF-High band, the entire UHF band, and of course, the 800 MHZ band. And yes, believe the reviewers who verify that the signal …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 11 2009
ScannerFanatic
Houston, Texas
I am:
  • Power User
Reviewed at:
Price: $19.99
Works Great on 800MHz
5.0
    Pros
  • Attractive Design
    Cons
  • none
    Best Uses
  • Portable Devices
"I wanted an antenna designed for 800MHz. This little antenna does a fine job of local and not-so-local digital systems. I was pleasantly surprised to discover that local VHF high band performance was still good. This antenna even picked up the same NOAA weather stations that the scanner's original …"  Read Full Review »
May 16 2009
Scanner Fan
NW Ohio
I am:
  • Enthusiast
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
