Radio Shack 80" Boom Length, 32-Element Antenna
4.3
based on 107 reviews
from
Ratings Distribution
5 star
65
4 star
26
3 star
4
2 star
2
1 star
10
Category Average
3.6
More Images
Pros
  • Easy setup (74)
  • Strong signal (65)
  • Durable (29)
  • Fine-tuning (21)
  • Easy to use (16)
  • Good performance (16)
  • Good value (16)
  • Reliable (16)
  • Attractive design (3)
  • Almost sets itself up (1)
See less See more
Cons
  • Flimsy (15)
  • Unattractive design (12)
  • Poor reception / weak antenna (8)
  • Hard to set up (2)
  • Assembly instruct weak (1)
  • Center of balance "off" (1)
  • Cheap (1)
  • Cheap transformer (1)
  • Fell apart after 1 year (1)
  • Just ok vhf reception (1)
Best Uses
  • Living room (23)
  • Attic/roof mount (17)
  • Bedroom (17)
  • Small rooms (11)
  • Office (10)
  • Portable devices (6)
  • Attic antenna (4)
  • Roof mount (4)
  • Attic (2)
  • 60' high tower (1)
Provided by RadioShack
Ideal for the city or suburbs, this antenna is a must have. The 80" Boom Length, 32-Element Antenna is built with high-tensile strength aluminum for long life.
Specification Description
Model VU-90 XR
Accessory Indicator Yes
Benefits Recommended for city or suburb use HDTV ready Instant "snap-open" assembly
Body Material Multi
Capacity UOM mAh
Country Of Origin United States
Description Header Hog all the good signals
Display Catalog Number 15-2152
Features Mounts on roof or attic VHF range: 90 miles UHF range: 70 miles FM range: 70 miles
Included in the Box 80" Antenna300 to 75 OHM TranformerMast Mounting HardwareOwner's Manual
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model VU-90 XR
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Outputs 2 x Screw Terminal(Lead-in Terminal)
Product Dimensions UOM inches
Product Disclaimer Estimated range, based on outdoor reception over flat and open terrain.
Product Height 32
Product Length 80
Product Type UHF/VHF
Product Weight 5.33
Product Weight UOM pounds
Product Width 95
Required to function Lead-in cableTV/VCR/FM Receiver
Supported Languages English
Radio Shack 80" Boom Length, 32-Element Antenna Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 80" Boom Length, 32-Element Antenna
See all eBay results
  at eBay.com
Product Reviews
Last update: Jun 20, 2009
Radio Shack 80" Boom Length, 32-Element Antenna Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Best Reception!!
"Very strong reception even antenna is not mounted on the pole, just placed it inside the attic on top of the insulation. ABC, CBS, NBC, FOX lowest signal are 82...." Read Full Review »
Jan 23, 2009 by Dat
See more positive Radio Shack 80" Boom Length, 32-Element Antenna reviews
1.0
Inconsistant signals...do not buy.
"I am so very disappointed with this antenna. I had fun putting it together, but my enthusiasm didn't last long. With all of my local San Francisco stations being only 11.4 miles away and all at the same tower (Sutro Tower), it could not pick up signals consistantly. The signals would spike and fade and disappear altogether with no rhyme or reason. With me by the TV monitoring the signals and my partner on th..." Read Full Review »
Oct 23, 2008 by Kent
See more negative Radio Shack 80" Boom Length, 32-Element Antenna reviews
Displaying 1 - 5 of 107 Reviews
Show
Sort by
Best Reception!!
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • none
    Best Uses
  • Living Room
"Very strong reception even antenna is not mounted on the pole, just placed it inside the attic on top of the insulation. ABC, CBS, NBC, FOX lowest signal are 82. "
Was this Antenna review on the Radio Shack 80" Boom Length, 32-Element Antenna helpful to you?
 Report Abuse  (5)  (0)  0 comments
Jan 23 2009
Dat
Garland, Texas
I am:
  • Casual User
Reviewed at:
[1 of 1 customers found this review helpful]
In Chicago, it's perfect.
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • Cheap transformer
    Best Uses
  • Put it on roof
"If you put this antenna on a roof and have an ATSC QAM tuner in you television, you are GOOD TO GO FOR HI DEFINITION programs on the Southeast side of Chicago. You will get 14 digital channels and STUNNING HI DEFINITION programming. You will also get about 24 analog programs. It is so good, some peo …"  Read Full Review »
Opening antenna
Opening antenna
  • Picture of Product
 Report Abuse  (1)  (0)  0 comments
Jan 15 2008
Mississippi Jimmy
Southeast Side Chicago
I am:
  • Tech Savvy
Reviewed at:
[3 of 3 customers found this review helpful]
30 Year Old Antenna still delivers
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"We bought this VU-90 35 years ago, before cable, before satellite, probably before you were even born. Once cable TV came into the neighborhood, about 22 years ago, we subscribed and left this antenna up there on a mast strapped to our chimney not doing anything. It has been hit by lightning and ele …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Nov 7 2008
Eddie
Indian Trail, NC
I am:
  • Enthusiast
Reviewed at:
[4 of 4 customers found this review helpful]
Pulls in HD Channels Fine
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"Easy to setup. You assemble it using bolts and wing nuts. No special tools needed. A wrench is needed to tighten the nuts on the U-shaped bolt to a mast. A 7/16 in wrench, adjustable wrench, or pliars works fine.
I live in Brooklyn NY, about 8-10 miles SSW of the Empire State Building from wher …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Dec 17 2008
Retired Signal Corp Officer
Brooklyn NY
I am:
  • Enthusiast
Reviewed at:
Picks up Orlando channels from 50+ miles
5.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • On The Roof
"I live in Palm bay, FL about 54 miles south east from all of the Orlando transmission towers. My house is pretty much surrounded by 50ft pine trees, no other obstructions. I mounted it on the roof, about 25 feet off the ground, for best reception and it was SUPER EASY to set up. Did research on a …"  Read Full Review »
Nov 14 2007
Rob
Palm Bay, FL
I am:
  • Gearhead
  • Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
