Radio Shack 8-in-1 Universal Remote Control with LCD Display
#140
3.6
based on 63 reviews
Ratings Distribution
5 star
20
4 star
21
3 star
7
2 star
6
1 star
9
Category Average
4.2
$32.99 at RadioShack
Find it at Amazon
Find it at Ebay
$32.99
from 1 store
Pros
  • Easy setup (36)
  • Nice button configuration (32)
  • Nice features (29)
  • Durable (27)
  • Ergonomic design (25)
  • Strong signal (18)
  • Easy to program (13)
  • Highly compatible (5)
  • All keys light up (1)
  • Controls 8 devices (1)
See less See more
Cons
  • Incompatible (15)
  • Not enough features (7)
  • A bit large and heavy (1)
  • Bit of a learning curve (1)
  • Can't program exit-key (1)
  • Can't program left-key (1)
  • Code search very difficul (1)
  • Codes missing (1)
  • Design flaws (1)
  • Difficlult to set up (1)
Best Uses
  • Replacement (31)
  • Upgrade (23)
  • High-end equipment (19)
  • Clutter reduction (1)
  • Consolidate all remotes (1)
  • Custom macros (1)
  • Extra control for devices (1)
  • I don't - i returned it (1)
  • Low-end (1)
  • Put all in one remote (1)
Provided by RadioShack
This 8-in-1 remote simplifies your home theater and controls up to eight devices.
Specification Description
Model 1500100
Accessory Indicator Yes
Battery Type Product
Benefits Control up to 8 devices including your DVD player, TV, CD player, VCR and moreMacro Power button lets you turn on your entire system
Capacity UOM mAh
Chemistry Alkaline
Country Of Origin China
Description Header All for one and all in one.
Display Catalog Number 15-100
Included in the Box Universal remoteUser guide
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 1500100
Operating Temperature UOM ° F
Product Type Pushbutton remotes
Required to function AAA batteries (4)
Required to function SKU 2300877
Size AA
Supported Languages English
Radio Shack 8-in-1 Universal Remote Control with LCD Display Questions
Questions and Answers
Where to Buy
$32.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 1, 2009
Radio Shack 8-in-1 Universal Remote Control with LCD Display Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Very good, and even better when on sale!
"I refer to the manual in this review. For easy reference, it is on Radioshack's product support tab, or copy this URL to your browser: http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500100_PM_EN.pdfI'm a pessimist, so here come the "cons" first:--- CONS: ---1. Something utterly ridiculous: you can't reprogram ("learn") certain standard keys (left arrow, exit, etc.). But if you can live with it, ..." Read Full Review »
Mar 30, 2009 by omaticman
See more positive Radio Shack 8-in-1 Universal Remote Control with LCD Display reviews
3.0
Not enough
"This unit is very average but then again it doesn't have a high end price tag. It has nice features but there is never enough memory to really do a good job. I desperately needed something that would do timed macros to allow my DVR to speak the same language as my digital converter box and it works great but you can only program one event. That is one event, both weekly and daily, so that would be one or the ..." Read Full Review »
Oct 30, 2009 by OldRelayer
See more negative Radio Shack 8-in-1 Universal Remote Control with LCD Display reviews
Displaying 1 - 5 of 63 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Program
  • Good code library
  • Lots of memory
  • Nice button feel
  • Strong Signal
    Cons
  • Has no CC button
  • Has no Eject key
    Best Uses
  • Clutter reduction
  • Replacement
  • Upgrade
"I refer to the manual in this review. For easy reference, it is on Radioshack's product support tab, or copy this URL to your browser: http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500100_PM_EN.pdfI'm a pessimist, so here come the "cons" first:--- CONS: ---1. Something utterly ridic …"  Read Full Review »
Was this Remote Control review on the Radio Shack 8-in-1 Universal Remote Control with LCD Display helpful to you?
Mar 30 2009
omaticman
Milwaukee, WI
I am:
  • Devastatingly handsome
  • Professional
  • Tech Savvy
Reviewed at:
Price: $32.99
Doesn't support my 3-yr old Vizio TV
4.0
    Pros
  • Durable
  • Easy To Program
  • Easy To Set Up
  • Nice Features
    Cons
  • Incompatible
    Best Uses
  • High-End Equipment
"The user manual says that it has "largest and most efficient group of IR remote control codes for virtually every current brand and make." This is a gross exaggeration, as witnessed by several other reviews and my own experience. I bought my 42" Vizio HDTV three years ago and it should be supporte …"  Read Full Review »
Oct 30 2009
Silverfox
San Francisco, CA
I am:
  • Gearhead
Reviewed at:
Price: $32.99
Not enough
3.0
    Pros
  • Nice display
  • Plenty of devices
  • Programmable sort of
    Cons
  • Not Enough Features
  • Not enough memory
    Best Uses
  • Replacement
  • Upgrade
"This unit is very average but then again it doesn't have a high end price tag. It has nice features but there is never enough memory to really do a good job. I desperately needed something that would do timed macros to allow my DVR to speak the same language as my digital converter box and it work …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 30 2009
OldRelayer
Central Maine
I am:
  • Tech Savvy
Reviewed at:
Price: $32.99
Three major things wrong with this
2.0
    Pros
  • Easy To Program
  • Easy To Set Up
  • Ergonomic Design
  • Nice Button Configuration
  • Nice Features
    Cons
  • Incompatible
  • No back lighted buttonsw
  • No way to select TV input
    Best Uses
"I have three big gripes about this remote.
First, I like to watch movies and TV with the lights out at night and that means that I need the buttons to be backlit so that I can see them.
Second, there is no way to change the input signal into the TV from DVD to Cable, for example. This is 20 …"  Read Full Review »
Oct 29 2009
Silverfox
San Francisco, CA
I am:
  • Gearhead
Reviewed at:
Price: $32.99
[3 of 3 customers found this review helpful]
Great remote but one SERIOUS design flaw
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Ergonomic Design
  • Nice Features
  • More »
    Cons
  • Design Flaws
    Best Uses
  • Low-end
"Excellent remote. Plenty of memory for learning and plenty of device codes. I hardly needed the learning for that.
However, there is one SERIOUS design flaw. The left-arrow and the exit buttons are not learn-able. They are used as remote-internal functions to exit out of the lcd menu. This is kin …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Sep 25 2008
tjs
hamilton, nj
I am:
  • Gearhead
  • Professional
Reviewed at:
Price: $32.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
