Radio Shack 7-Channel SAME Desktop Weather Radio w/ Alarm
#153
1.8
based on 12 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
1
1 star
9
Category Average
3.8
$69.99 at RadioShack
Find it at Amazon
Find it at Ebay
$69.99
from 1 store
Pros
  • Lightweight (4)
  • Great sound quality (3)
  • Great reception (2)
  • Blue backlight (1)
  • Durable (1)
  • Good battery life (1)
  • Limits alerts to local (1)
  • Loud alert sound (1)
  • Nice display (1)
See less See more
Cons
  • Poor reception (2)
  • Poor sound quality (2)
  • A challenge to program (1)
  • Bulky (1)
  • Check op message (1)
  • Died after 18 mos (1)
  • Does not warn me (1)
  • Fails to alarm (1)
  • Poor battery life (1)
  • Says check op (1)
Best Uses
  • Home use (6)
  • Everyday (5)
  • Not for storm warning (1)
Provided by RadioShack
Use this desktop weather radio from RadioShack to stay informed about the weather.
Specification Description
Model 12-521
# of AM/FM Tuner Presets 7
Antenna Type Telescopic
Battery Type Product
Benefits Receives all 7 NOAA weather channelsPublicAlert Certified, meaning it meets the rigorous standards set by NOAAComes preprogr
Built-in Clock Yes
Capacity UOM mAh
Channel Scan Yes
Connections Power (1)RCA (1)
Controls Menu, Weather/Snooze, left, right, up, down, clock, alarm on/alarm off/snooze
Country Of Origin China
Description Header Know what's coming.
Display Catalog Number 12-521
Display Information Alert
End Product Indicator Yes
Frequency Range 162.400-162.550MHz
Included in the Box Weather radioAC/DC adapter
Includes NOAA Weather Channels Yes
Includes SAME Alerts Yes
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 12-521
New Date Sun May 24 00:00:00 CDT 2009
Operating Temperature UOM ° F
Placing / Mounting Desktop
Power Device 9V battery
Product Depth 7.1
Product Dimensions UOM inches
Product Height 1.6
Product Type Weather radios
Product Weight 5.76
Product Weight UOM ounces
Product Width 6
Radio System Type Desktop
Rechargeable Yes
Size 9 Volt
Supported Languages English
Type LCD
Weather Alert Yes
Radio Shack 7-Channel SAME Desktop Weather Radio w/ Alarm Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Radio Shack 7-Channel SAME Desktop Weather Radio w/ Alarm Reviews
Most helpful positive review
Most helpful negative review
5.0
great!!
"Had this radio for over 2 years and it works great. easy to set up codes already set just had to set area and time...." Read Full Review »
Nov 17, 2009 by TC
See more positive Radio Shack 7-Channel SAME Desktop Weather Radio w/ Alarm reviews
1.0
Didn't Last, Hard to Program
"I purchased this radio in January, 2008. We go north for the summer, so the unit was only in use for about 12 months. When we returned in Sept. the clock didn't work. Without the clock, the alerts never ended! I decided to try a different brand. Have been through 2 Midlands and an external antenna. Their sound quality stinks. I plan to purchase the more expensive Radio Shack model and try it. It has good..." Read Full Review »
Nov 13, 2009 by Dave
See more negative Radio Shack 7-Channel SAME Desktop Weather Radio w/ Alarm reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
Impossible to setup
1.0
    Pros
  • Loud alert sound
    Cons
  • Poor Sound Quality
    Best Uses
  • Daily Use
  • Home Use
"You'd better be a Navaho Code Talker, otherwise, you'll never interpret the poorly written instructions to setup this unit. Menu items and sequencing is the most NON-intuitive that I have encountered in more than 50 years. IF you get it setup, don't ever lose power or move it, because it will take y …"  Read Full Review »
Was this Portable Radio review on the Radio Shack 7-Channel SAME Desktop Weather Radio w/ Alarm helpful to you?
Nov 11 2009
Pops
Orlando, Florida
I am:
  • Gearhead
1.0
    Pros
  • Good Sound Quality
  • Great Reception
  • Lightweight
    Cons
  • Died after 18 mos
    Best Uses
  • Daily Use
  • Home Use
"I purchased this radio in January, 2008. We go north for the summer, so the unit was only in use for about 12 months. When we returned in Sept. the clock didn't work. Without the clock, the alerts never ended! I decided to try a different brand. Have been through 2 Midlands and an external ante …"  Read Full Review »
Nov 13 2009
Dave
Venice, FL
I am:
  • Frequent Traveler
  • Practical
Good and Bad
2.0
    Pros
    Cons
  • Check op message
    Best Uses
  • None
"Works fine for a month or two then we get a check ops message. It says you only get it after ten days BUT not true. Test on Wed. and check op on Sat. Clearing it can be easy or a long process.
Alerts are all fine and we do feel safer with the radio.
There has to be an easier to program r …"  Read Full Review »
Nov 16 2009
Jim M
Middle GA
I am:
  • Practical
great!!
5.0
    Pros
    Cons
  • Bulky
    Best Uses
  • Home Use
"Had this radio for over 2 years and it works great. easy to set up codes already set just had to set area and time. "
Nov 17 2009
TC
Greenwood, SC
I am:
  • Practical
[0 of 1 customers found this review helpful]
to loud of siron
1.0
    Pros
  • None
    Cons
  • Short Battery Life
    Best Uses
  • Home Use
"I would sleep through severe weather and when it went off I would seek shelter. It has a very loud siron. I would say half the time it does not recieve the alert. It also gets not so great reception and will beep very lould when it looses its reception. Would never give this to a friend "
 Report Abuse  (0)  (1)  0 comments
Sep 28 2009
kw
3138 W 400 S
I am:
  • Practical
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
