based on 27 reviews
Ratings Distribution
| 5 star |
6 |
| 4 star |
12 |
| 3 star |
0 |
| 2 star |
4 |
| 1 star |
5 |
Category Average
Pros
Cons
Best Uses
Where to Buy
at Amazon.com | ||||
eBay listings for: 6-in-1 Kameleon Touch-Screen Universal Remote
See all eBay results |
at eBay.com | |||
Product Reviews
"After disabling the motion sensor on this remote the batteries will last much longer. You can get directions how to do that with a web serch it is very easy. But with the motion sensing on I would give this remote 2 stars since it's motion sensing is very sensitive draining batteries very quickly. If you walk near it will light up, forget sleeping near it with the motion sensor on since the batteries will last l..." Read Full Review »
Aug 22, 2007 by David
See more positive Radio Shack 6-in-1 Kameleon Touch-Screen Universal Remote reviews
"Waste of money, (Edited by moderator.). Simply does not work as advertised. Custom programming only works for a handful of keys, and then not reliably. With this in mind, you basically have an expensive remote that will turn your TV on and off and control the volume, but very little else. Entering the manufacturer code for my satellite receiver resulted in only a few operable keys. Following the instructions..." Read Full Review »
Apr 29, 2007 by John H
See more negative Radio Shack 6-in-1 Kameleon Touch-Screen Universal Remote reviews
Displaying 1 - 5 of 27 Reviews
Radio Shack 6-in-1 Kameleon Touch-Screen Universal Remote Review
Pros
Cons
Best Uses
"After disabling the motion sensor on this remote the batteries will last much longer. You can get directions how to do that with a web serch it is very easy. But with the motion sensing on I would give this remote 2 stars since it's motion sensing is very sensitive draining batteries very quickly. I …" Read Full Review »
Pros
Cons
Best Uses
"This is a great remote especially for the [$] price. It was nearly $100.00 when I baught mine and it was worth it then. Battery life will not be an issue if you use common sense. 1) turn the brightness all the way down, still easy to see in day and night. 2) Set it on the coffee table when not i …" Read Full Review »
Pros
Cons
Best Uses
"This is the best remote I've ever owned. If you don't mind buying a JP1 cable and using IR.exe on Windows, you can make this one do anything IR. You can build and upload your own IR codes and assign macros to accomplish tasks that remotes costing much more can't. For example, one touch to turn on …" Read Full Review »
Pros
Cons
Best Uses
"Great remote if you know your way around electronics. If not, you might want something a little easier to set-up. The motion sensor on this remote is WAAAAY too sensitive. I opened up the circut board on mine and cut off the motion switch so now it turns on when you press any key (great feature). …" Read Full Review »
Pros
Cons
Best Uses
"I have owned this great product since they came out 3 years ago. At first I despised it as any movement caused it to light up, thus killing my batteries. I conducted an online search and found instructions on removing the motion sensing part. Since removing that, the remote is awesome. I always have …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
at eBay.com | |||
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
