Radio Shack 6-in-1 Easy Setup Voice Remote
3.9
based on 28 reviews
Ratings Distribution
5 star
13
4 star
7
3 star
3
2 star
2
1 star
3
Category Average
4.2
Pros
  • Good value (12)
  • Good performance (11)
  • Reliable (11)
  • Easy to use (10)
  • Nice features (8)
  • Easy setup (6)
  • Ergonomic design (6)
  • Nice button configuration (6)
  • Durable (5)
  • Strong signal (3)
See less See more
Cons
  • No eject button for dvd (1)
  • Won't change menu (1)
Best Uses
  • Replacement (8)
  • High-end equipment (6)
  • Upgrade (5)
  • All-in-one (1)
  • Hauppauge media mvp (1)
  • On-off only (1)
Provided by RadioShack
Combine all your remotes into one with this 6-in-1 Easy Setup Voice Remote. Let voice prompts guide you step-by-step through the setup process.
Radio Shack 6-in-1 Easy Setup Voice Remote Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 6-in-1 Easy Setup Voice Remote
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 26, 2008
Radio Shack 6-in-1 Easy Setup Voice Remote Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Best Remote Ever
"This is the best remote ever, especially for the price. It controls my very complicated home theater system with projector, over the air HD tuner with DVR and DVD player, & Pioneer receiver. It learns features easily for the few buttons that the codes don't automatically input, the macro's work perfectly and the voice prompts make programming easy! It's also very ergonomic and much easier to use than those an..." Read Full Review »
Dec 13, 2007 by in2deep
See more positive Radio Shack 6-in-1 Easy Setup Voice Remote reviews
1.0
I am extremely ...
"I am extremely disappointed in this remote. I purchased it for a sight-limited family member, under the impression is was a voice-response learning remote. the store staff knew 0 about this particular model, and it's not voice response, it's just voice-giuded setup. on top of that, none of the listed codes work and neither did code search. code search stepped thru all the codes and suggested i try again . a..." Read Full Review »
Feb 10, 2007 by Ian C
See more negative Radio Shack 6-in-1 Easy Setup Voice Remote reviews
Displaying 1 - 5 of 28 Reviews
Show
Sort by
Best Remote Ever
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Ergonomic Design
  • Nice Button Configuration
  • Nice Features
  • More »
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Replacement
  • Upgrade
It learns features easily for the few buttons that the codes don't automatically input, the macro's work …"  Read Full Review »
Was this Remote Control review on the Radio Shack 6-in-1 Easy Setup Voice Remote helpful to you?
 Report Abuse  (1)  (0)  0 comments
Dec 13 2007
in2deep
austin, tx
I am:
  • Practical
  • Tech Savvy
Reviewed at:
excellent product!
4.0
    Pros
  • Easy To Set Up
  • Ergonomic Design
  • Nice Features
    Cons
    Best Uses
  • Replacement
  • Upgrade
"I replaced a harmony remote with this remote. I spent two days trying to program the harmony even with technical help from harmony We couldn't program the remote. I tried this remote because of the reviews it got. An I'm glad I did. I had this remote programed in less than an hour. It has all the fu …"  Read Full Review »
Jan 2 2008
Gill
voorhees NJ
I am:
  • Tech Savvy
Reviewed at:
I had returned an RCA ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
    Cons
  • None
    Best Uses
  • None
"I had returned an RCA Learning remote because even with its learning, it did not do what I want. Since I had a Coupon, I bought this - $10 less than the RCA after the coupon. The first one of these I got was dead on arrival. Radio Shack exchanged it easily, but it did up my concerns about this remot …"  Read Full Review »
Aug 20 2006
S M
H
Reviewed at:
great learning remote with backlight
4.0
    Pros
  • Durable
  • Easy To Set Up
  • Ergonomic Design
  • Learning
  • More »
    Cons
  • None
    Best Uses
  • All-In-One
  • Replacement
  • Upgrade
"This is a fantastic remote that is great for anyone. A learning remote with back lighting and voice-prompt setup that can't be beat. This is my second remote of this model I'm buying, this time for home use. The other one works great at work. If you have one of those TV's that other universal remote …"  Read Full Review »
Feb 23 2008
Tim the geek
Tampa Bay Area, FL
I am:
  • Professional Geek
Reviewed at:
It's Talks!
5.0
    Pros
  • Durable
  • Easy to program
  • Easy To Set Up
  • Ergonomic Design
  • More »
    Cons
  • None
    Best Uses
  • Hauppauge Media MVP
  • Replacement
  • Upgrade
"I've had purchased one on Friday then went back and picked up the rest making it 5 in all! Need them for 5 TVs and 5 of everything per set.. Talking female voice is a good guide and let's yo know if the learn mode codes where excepted! "
Oct 27 2007
tipstir
Connecticut
I am:
  • Networking Coordinator
  • Professional
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
