Close Login Module
Join
Radio Shack 6" Heat-Shrink Tubing (12-Pack)
#1090
2.8
based on 4 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
1
2 star
0
1 star
2
Category Average
4.1
$5.49
from 1 store
Pros
  • Reliable (1)
See less See more
Cons
  • Only partially shrinks (1)
Best Uses
Where to Buy
$5.49
Product Reviews
Last update: Nov 3, 2009
Radio Shack 6" Heat-Shrink Tubing (12-Pack) Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Assume this has a 2:1 shrink ratio
3.0
"I was using this for audio cables on 1/4" TRS plugs. My cable is much narrower than typical mic/line cables so I needed to be able to have a pretty high shrink ratio. This product doesn't list it, so I took a chance. Appears it's only a 2:1 which wasn't nearly enough. If my audio cable was thick …"  Read Full Review »
Jul 3 2008
dschrammie
Denver, CO
I am:
  • Quality Oriented
Reviewed at:
Price: $5.49
Didn't work well...
1.0
    Pros
  • None
    Cons
    Best Uses
  • None
"Heat shrink only went to about half then quit shrinking. This might work for larger items, but did not shrink to fit the diodes for my truck. I could pull the diodes right back out after "shrinking". "
Jul 22 2007
MoAv
P.Bluff, MO
I am:
  • Quality Oriented
Reviewed at:
Price: $5.49
Works just great for me! ...
5.0
"Works just great for me! You do need a good heat gun, and I have mine set at 450 degrees Farenheit. I used the very small stuff to insulate LED leads right up against the LED itself without any problem. "
Apr 29 2007
David B
Colorado Springs
Reviewed at:
Price: $5.49
[1 of 4 customers found this review helpful]
It doesn't shrink at all.
1.0
"It doesn't shrink at all. "
Dec 8 2006
David L
NewYork
Reviewed at:
Price: $5.49
Email Address: (required)
Comments:
or Cancel
Where to Buy
$5.49
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
