#919
based on 19 reviews
Ratings Distribution
| 5 star |
10 |
| 4 star |
4 |
| 3 star |
0 |
| 2 star |
0 |
| 1 star |
5 |
Category Average
$36.99
from 1 storePros
Cons
Best Uses
Where to Buy
BizRate Rating
Good 8.6
$36.99 |
at
RadioShack
Product Reviews
[1 of 1 customers found this review helpful]
"I just installed it on 32-bit Vista using an HP 4L printer. Vista has built-in drivers for both the printer and this adapter. The only con is it's USB 1.1 and not high speed. But it's not like this old printer could run any faster. Windows reports it uses 0.1 amps from the USB bus. That's not much. It's also a great value with gold plated centronics and usb connectors. It is actually 6'5" from tip to tip...." Read Full Review »
Sep 15, 2007 by impala
See more positive Radio Shack 6 Ft. (1.8m) USB-to-Parallel Port Printer Cable reviews
"I spent about three hours trying everything possible to make this work between my old HP Deskjet 970 Cse and my new Toshiba Satellite with Vista. I would have given up much sooner if I hadn't read several examples here of how easy it is. I also tried it with my iMac running Leopard. No luck there either...." Read Full Review »
Nov 01, 2008 by Elle Jay
See more negative Radio Shack 6 Ft. (1.8m) USB-to-Parallel Port Printer Cable reviews
Displaying 1 - 5 of 19 Reviews
Radio Shack 6 Ft. (1.8m) USB-to-Parallel Port Printer Cable Review
Pros
Cons
Best Uses
"I just installed it on 32-bit Vista using an HP 4L printer. Vista has built-in drivers for both the printer and this adapter. The only con is it's USB 1.1 and not high speed. But it's not like this old printer could run any faster. Windows reports it uses 0.1 amps from the USB bus. That's not m …" Read Full Review »
Pros
Cons
Best Uses
"Installed on computer running Windows XP with an HP LaserJet 4 printer. No need to use the CD that came with the new USB/Parallel cable as Windows 2000/XP has the driver pre-installed. Also did not need to use the Add New Hardware Wizard to install the driver software as the cable's instructions i …" Read Full Review »
[3 of 3 customers found this review helpful]
Pros
Cons
Best Uses
"Initially, I could not get this to work with Vista. Then I changed the port from LPT to USB and it worked fine. I have Vista Home Premium and am using the cable with a Laser Jet 4. "
Pros
Cons
Best Uses
"I installed the cable to my old HP694C, {which works like a champ}, and to my new DFI motherboard. Using XP Pro, at first it did not pick-up as play and go upon reboot. I went from start to the 'Printer and Faxes' and simply click on to 'Add a Printer'. At this stage you will have the options to us …" Read Full Review »
Pros
Cons
Best Uses
"New desktops and some laptops do not have a 25 pin parallel printer port. This cable is supposed to allow you to connect a 25 pin printer to a USB port on your new computer. I found you have to do two additional things or it will never work. 1. Buy a POWERED USB hub and connect the cable to the U …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.6
$36.99 |
at
RadioShack
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
