#670
based on 14 reviews
Ratings Distribution
| 5 star |
10 |
| 4 star |
3 |
| 3 star |
1 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
Pros
Cons
Best Uses
Where to Buy
| $10 Off Orders Of Orders Over $85 + Free Shipping |
BizRate Rating
Good 8.7
Product Reviews
[4 of 5 customers found this review helpful]
[2 of 2 customers found this review helpful]
"I needed a 5 volt supply to run my PDA on the go, so I chose a pack of AA batteries and a 7805. I let my friend use it to charge his PSP on a trip but he hooked it up backwards and fried the 7805. I have to take off one star because these things die if connected backwards. I ended up building a new power supply using 2 of these (to regulate 2 amps instead of just 1, my PDA is rated at 2.4A) and added a 3A dio..." Read Full Review »
May 22, 2009 by CalcProgrammer1
See more positive Radio Shack +5V Fixed-Voltage Regulator 7805 reviews
"Very useful when you need a high current regulated 5 volts, and needs no external electronic components besides two small decoupling capacitors (one on the input, one on the output) to regulate the voltage. It does get hot under a heavy load current, though, and is a bit overpriced...." Read Full Review »
Oct 09, 2008 by b1p0l4r_Tr4ns1st0r
See more negative Radio Shack +5V Fixed-Voltage Regulator 7805 reviews
Displaying 1 - 5 of 14 Reviews
Radio Shack +5V Fixed-Voltage Regulator 7805 Review
Pros
Cons
Best Uses
Read Full Review »
[3 of 4 customers found this review helpful]
Pros
Cons
Best Uses
"When you bend the leads, leave about 1/8" to 1/4" closest to the plastic body unbent. That way if the leads break off (usually after repeated bending, not recommended), you still have 1/8" leads that you can solder longer lead wires to. This holds true for any component - think what the consequence …" Read Full Review »
Pros
Cons
Best Uses
[3 of 3 customers found this review helpful]
Pros
Cons
Best Uses
"This thing is great, I used it to make an Ipod charger that runs off a nine volt battery. It gives out a constant voltage of 5.02 volts, It's perfect! "
Pros
Cons
Best Uses
"Used it as an instrument voltage regulator for the gauges in my 1966 Mustang. The original Ford units go bad often and this worked great. Use a heat sink and I used capacitors on the input and out to ground as filters. Need to be careful to not break off the legs by using stress relieve on the wires …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
