based on 5 reviews
Ratings Distribution
| 5 star |
2 |
| 4 star |
2 |
| 3 star |
0 |
| 2 star |
0 |
| 1 star |
1 |
Category Average
Where to Buy
at Amazon.com | ||||
eBay listings for: 50-Watt Foreign AC Converter for Electronic Equipment
See all eBay results |
at eBay.com | |||
Product Reviews
Displaying 1 - 5 of 5 Reviews
[6 of 6 customers found this review helpful]
Radio Shack 50-Watt Foreign AC Converter for Electronic Equipment Review
Pros
Cons
Best Uses
"Provides ample power for small electronics.
Should not be used with most laptops which do require over 150-Watts. Also requires plug adapters 273-1405 to fit a euro outlet properly.
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"If you don't want to bring a whole set of adapters to fit the plug of the country you are going to, the instructions list and show exactly which adapter is needed for which country. For instance, travel to most European countries requires the "B" adapter with two circular plugs and small enough to f …" Read Full Review »
Pros
Cons
Best Uses
"This device, like all travel converters, works well within its designed contraints. This device cannot be used with a load greater than 50W. Also keep in mind that not all 220/240v outlets are the same. Make sure you know what configuration your destination countries use. And finally, unplug the …" Read Full Review »
Pros
Cons
Best Uses
"got this product after i was told that Nikon's battery charger cable is not rated for Europe's voltage. Product worked great. The only problem is as mentioned by others some hotels have recessed outlets and so you should bring additional adapter (they're only like [$]) to extend this one.Loved it. "
[5 of 8 customers found this review helpful]
"German outlets are 220V ROUND RECESSED. This is only for flush foreign receptacles.
it sat in the suitcase & I used the Hotel's adapter.
not worth the $$$
Email Address: (required)
Comments:
or Cancel
Where to Buy
at eBay.com | |||
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
