Radio Shack 5-in-1 Family Favorites Remote Control
2.6
based on 14 reviews
from
Ratings Distribution
5 star
3
4 star
3
3 star
0
2 star
1
1 star
7
Category Average
4.2
Pros
  • Easy setup (5)
  • Nice button configuration (3)
  • Ergonomic design (2)
  • Good value (2)
  • Easy to use (1)
  • Good performance (1)
  • Nice features (1)
  • Reliable (1)
  • Strong signal (1)
See less See more
Cons
  • Incompatible (4)
  • Weak signal (2)
  • Dark button-no backlight (1)
  • Instructions make no sens (1)
  • Not pvr friendly (1)
  • Stops working (1)
  • Too many buttons (1)
Best Uses
  • Replacement (5)
  • Paper weight (1)
Provided by RadioShack
Conveniently control up to five audio/video components with this single remote.
Specification Description
Model 15-2200
Accessory Indicator Yes
Benefits Controls most TVs, VCRs, DVD players, DVRs, cable boxes and satellite receiversBacklit buttons so you can easily make selections in t
Capacity UOM mAh
Country Of Origin China
Description Header Simplify your life.
Display Catalog Number 15-2200
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 15-2200
New Date Sun Jan 07 00:00:00 CST 2007
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 7.5
Product Length 0.07
Product Type Pushbutton remotes
Product Weight 8
Product Weight UOM ounces
Product Width 2.5
Required to function AAA Batteries (2)
Required to function SKU 2300877
Supported Languages English
Radio Shack 5-in-1 Family Favorites Remote Control Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 5-in-1 Family Favorites Remote Control
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 14, 2008
Radio Shack 5-in-1 Family Favorites Remote Control Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[1 of 2 customers found this review helpful]
4.0
So far so good!
"We have an almost 4 year old Toshiba TiVo/DVD (SD-H400) and the original remote is failing. The buttons that we use the most are becoming harder and harder to activate. We couldn't even buy a replacement from Toshiba and were considering buying a whole new DVR ($300+). Instead we found this remote [...]. It was easy to set up and we got it working for the TV and DVR quickly. We can't seem to be able to prog..." Read Full Review »
Oct 28, 2007 by LuckeyDuckey
See more positive Radio Shack 5-in-1 Family Favorites Remote Control reviews
1.0
How do you program it?
"Thought I got a good deal on this thing. Took it out of the package and went to program it and the instructions talk about a LED that blinks when you program it. Well there isn't any LED on this remote. I even went into a dark room and changed the batteries thinking maybe it was an LED under the buttons. I even tried to guess program it. But no, its as if the instructions are for an entirely different remot..." Read Full Review »
Feb 14, 2008 by Dragon
See more negative Radio Shack 5-in-1 Family Favorites Remote Control reviews
Displaying 1 - 5 of 14 Reviews
Show
Sort by
So far so good!
4.0
    Pros
  • Easy To Set Up
  • Nice Button Configuration
    Cons
    Best Uses
  • Replacement
"We have an almost 4 year old Toshiba TiVo/DVD (SD-H400) and the original remote is failing. The buttons that we use the most are becoming harder and harder to activate. We couldn't even buy a replacement from Toshiba and were considering buying a whole new DVR ($300+). Instead we found this remot …"  Read Full Review »
Was this Remote Control review on the Radio Shack 5-in-1 Family Favorites Remote Control helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 28 2007
LuckeyDuckey
SoCal
I am:
  • Gearhead
Reviewed at:
1.0
    Pros
  • None
    Cons
  • Incompatible
    Best Uses
  • None
"Thought I got a good deal on this thing. Took it out of the package and went to program it and the instructions talk about a LED that blinks when you program it. Well there isn't any LED on this remote. I even went into a dark room and changed the batteries thinking maybe it was an LED under the …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Feb 14 2008
Dragon
Washington
I am:
  • Practical
  • Tech Savvy
Reviewed at:
great cheap replacement remote for Tivos
4.0
    Pros
  • Easy To Set Up
  • Ergonomic Design
  • Nice Features
    Cons
  • None
    Best Uses
  • Replacement
"Great inexpensive remote for controlling PVRs like Tivo and similar units. Has PVR/Tivo specific buttons. I have two, one would not work until I adjusted battery contacts. (manufacturing quality questionable???) Works great for controlling odd old devices like Toshiba Tivo/DVD recorder units. [...] "
Aug 15 2008
Jayhawk on the left coast
Silicon Valley
I am:
  • Tech Savvy
Reviewed at:
[0 of 1 customers found this review helpful]
This Sucks
1.0
    Pros
  • None
    Cons
  • Incompatible
  • Weak Signal
    Best Uses
  • None
"I bought this unit because I lost my original remote during my move. This remote is difficult to program, easy to screw up and has a limited (about 5 foot) range. Looks like I will have to buy another remote that is made better. I am totally frustrated with this purchase. "
 Report Abuse  (0)  (1)  0 comments
Jul 3 2007
Tom the cowboy
Fort Worth
I am:
  • Tech Savvy
Reviewed at:
All Show - No Go !!!
1.0
    Pros
  • Easy To Set Up
    Cons
  • Incompatible
  • Not PVR Friendly
    Best Uses
  • Paper Weight
"I was looking for a remote that also controlled my PVR (Tivo). After programming the PVR codes (all of them) several of the PVR control buttons don't do anything near what they are supposed to! "
Dec 6 2007
Strawman
Greenwich, CT
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
