Radio Shack 5.8GHz Analog Phone with Answering System and Extra Handset
2.4
based on 16 reviews
Ratings Distribution
5 star
1
4 star
5
3 star
1
2 star
1
1 star
8
Category Average
3.8
Pros
  • Easy setup (9)
  • Nice features (9)
  • Comfortable handset (6)
  • Nice sound (6)
  • Strong signal (3)
  • Compact design (2)
  • Big range (1)
  • Integrated answering mach (1)
See less See more
Cons
  • Weak signal (7)
  • Limited range (6)
  • Poor sound quality (6)
  • Caller id doesn't work (1)
  • Cuts out (1)
  • Lighted key pad on base u (1)
  • Needs backlight key pad (1)
  • Not durable (1)
  • Setup complicated (1)
  • Static disconnects (1)
Best Uses
  • Everyday (9)
  • Small spaces (3)
  • Leave at store (1)
  • Outdoors (1)
Provided by RadioShack
Get Caller ID, an answering system and an extra handset.
Radio Shack 5.8GHz Analog Phone with Answering System and Extra Handset Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 5.8GHz Analog Phone with Answering System and Extra Handset
See all eBay results
  at eBay.com
Product Reviews
Last update: Oct 1, 2008
Radio Shack 5.8GHz Analog Phone with Answering System and Extra Handset Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Great Phone
"I dont know what all the negatives are about, Works well all over the house, even upstairs and the base downstairs. I think people should READ the instructions, and follow them, before badmouthing a product. About 5 minutes into the charging, got first call, worked flawlessly. Easy to set up. Register both handsets to the base unit and good to go. Answer machine works great too. Does what its suppose to, at a fr..." Read Full Review »
Apr 30, 2008 by Gregg
See more positive Radio Shack 5.8GHz Analog Phone with Answering System and Extra Handset reviews
2.0
Very bad first impression!
"I've had many cordless phones before, but the packaging of this one is the worst. The battery was inserted into its compartment, but the connector was not inserted into its socket... I only noticed this after attempting a 20-hour first charge. If they had no intention of connecting the battery, they should not have packed it into its compartment! I cannot imagine any other cordless or mobile phone packaged th..." Read Full Review »
Dec 09, 2007 by The Victim
See more negative Radio Shack 5.8GHz Analog Phone with Answering System and Extra Handset reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
Great Phone
4.0
    Pros
  • Comfortable Handset
  • Easy To Set Up
  • Good Sound
  • Nice Features
  • Strong Signal
    Cons
    Best Uses
  • Everyday Use
"I dont know what all the negatives are about, Works well all over the house, even upstairs and the base downstairs. I think people should READ the instructions, and follow them, before badmouthing a product. About 5 minutes into the charging, got first call, worked flawlessly. Easy to set up. Regist …"  Read Full Review »
Was this Cordless Telephone review on the Radio Shack 5.8GHz Analog Phone with Answering System and Extra Handset helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 30 2008
Gregg
Ohio
I am:
  • Value Oriented
Reviewed at:
Read Directions
4.0
    Pros
  • Easy To Set Up
  • Good Sound
  • Nice Features
  • Strong Signal
    Cons
    Best Uses
  • Everyday Use
  • Outdoors
"I see negative reviews, which were probably a result of not reading the directions about plugging in the battery and/or not charging the unit as described in the directions. Unit works great at all locations on my medium size lot. Works better than my Linksys wireless for my computer. For the pri …"  Read Full Review »
Feb 10 2008
Nonya Business
Reno, NV
I am:
  • Value Oriented
Reviewed at:
2.0
    Pros
  • None
    Cons
  • Silly misleading setup
    Best Uses
  • None
"I've had many cordless phones before, but the packaging of this one is the worst. The battery was inserted into its compartment, but the connector was not inserted into its socket... I only noticed this after attempting a 20-hour first charge. If they had no intention of connecting the battery, t …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Dec 9 2007
The Victim
Boston, MA
I am:
  • Quality Oriented
Reviewed at:
bad use
1.0
    Pros
  • Nice Features
    Cons
  • Cuts out
  • Poor Sound Quality
  • Weak Signal
    Best Uses
  • Everyday Use
"I will not prefer this to a friend or a relative. This phone caller id had stopped working after like a week of use. It goes staticy inside/outdoors.It also shuts off after a certin amount of minutes. The other handset charger doesn't charge at all! I wouldn't buy this item. "
Apr 20 2008
cristiansmomma
Roseville ca
I am:
  • Quality Oriented
Reviewed at:
Great Buy
5.0
    Pros
  • Big Range
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Nice Features
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
"This was definitely a great buy. Setup was extremely easy and both handsets immediately began to receive calls. After charging the handsets overnight, I was very impressed with the clarity of the calls made/received. I was only able to find one ringtone, but this is not a concern for me. "
Nov 24 2007
Z-m@n
Houston, TX
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
