Close Login Module
Join
Radio Shack 5.8GHz Analog Phone with Answering System/2 Extra Handsets
1.7
based on 18 reviews
Ratings Distribution
5 star
1
4 star
3
3 star
0
2 star
0
1 star
14
Category Average
3.8
Pros
  • Comfortable handset (6)
  • Compact design (4)
  • Durable (4)
  • Easy setup (4)
  • Nice features (4)
  • Nice sound (3)
  • Big range (2)
  • Strong signal (2)
  • Good value (1)
  • I bought if for the price (1)
See less See more
Cons
  • Limited range (9)
  • Poor sound quality (9)
  • Weak signal (9)
  • Not durable (3)
  • Lacks features (2)
  • Caller id not work (1)
  • Pricey (1)
  • Static (1)
  • Too large and bulky (1)
  • Too much static (1)
Best Uses
  • Everyday (5)
  • As a paper weight (1)
  • Everywhere (1)
  • I can't think of one (1)
  • Outdoors (1)
  • Small spaces (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 5.8GHz Analog Phone with Answering System/2 Extra Handsets
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 22, 2008
Radio Shack 5.8GHz Analog Phone with Answering System/2 Extra Handsets Reviews
Most helpful positive review
Most helpful negative review
4.0
Know Your Home
"This phone is fine. Just like any other 5.8Ghz phone, you need to know where your placement of the phones are in your own home. If you own a large house in a big neighborhood, then you need to upgrade to 6.0Ghz. If you live in a small home in a in a spacious area, this will do just fine. My own experience is that it is great in my rooms with little electronics; if I have another phone nearby or a computer, t..." Read Full Review »
Mar 10, 2008 by Jewel
See more positive Radio Shack 5.8GHz Analog Phone with Answering System/2 Extra Handsets reviews
1.0
Caller ID does not wok
"Can't really comment on the phone, as it did not perform as expected. The caller ID did not work. Initially, as I set it up it did recognize several incoming calls. But after I set the phones in what were to be permanent locations it did not work. I swapped for another and had the same problem. I think I would have been happy if CID worked. However, I was disappointed by the sound quality of the answering..." Read Full Review »
Jun 03, 2008 by Pat a Radio Shack First Timer
See more negative Radio Shack 5.8GHz Analog Phone with Answering System/2 Extra Handsets reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Know Your Home
4.0
    Pros
  • Big Range
  • Comfortable Handset
  • Durable
  • Good Sound
  • Nice Features
    Cons
  • Weak Signal
    Best Uses
  • Everyday Use
  • Smaller Spaces
"This phone is fine. Just like any other 5.8Ghz phone, you need to know where your placement of the phones are in your own home. If you own a large house in a big neighborhood, then you need to upgrade to 6.0Ghz. If you live in a small home in a in a spacious area, this will do just fine. My own …"  Read Full Review »
Was this Cordless Telephone review on the Radio Shack helpful to you?
Mar 10 2008
Jewel
Tyler, TX
I am:
  • Quality Oriented
Reviewed at:
1.0
    Pros
    Cons
  • Caller ID not work
  • Poor Sound Quality
    Best Uses
  • None
"Can't really comment on the phone, as it did not perform as expected. The caller ID did not work. Initially, as I set it up it did recognize several incoming calls. But after I set the phones in what were to be permanent locations it did not work. I swapped for another and had the same problem. …"  Read Full Review »
Jun 3 2008
Berkeley,CA
I am:
  • Quality Oriented
Reviewed at:
Do not buy!
1.0
    Pros
    Cons
  • Limited Range
  • Weak Signal
    Best Uses
  • None
"Wish I had seen the reviews before buying. Base unit is in kitchen. With one handset in master bedroom 30 feet away it doesn't work. Static on line, person you are talking to can't hear you unless you get closer to base unit. If you plug a headset into phone they definitely cannot hear you. The …"  Read Full Review »
Aug 24 2008
cajun qm
Galliano, LA
I am:
  • Quality Oriented
Reviewed at:
A GREAT THING!!!
4.0
    Pros
  • Durable
  • Good Value
    Cons
  • Expensive
    Best Uses
  • Everywhere
"i just bought these phones...i keep the main base in the living room, and the other 2 are on my porch and in my basement by the wash machine...i think these phones work great if you get them all linked to the right channel they work great...guess the toher didnt have patience to try...but i think t …"  Read Full Review »
Oct 21 2007
George is satisfied.
long island, new york
Reviewed at:
INTERNET INTERFERENCE
1.0
    Pros
  • None
    Cons
  • Limited Range
    Best Uses
  • None
"Horrible reception for hearing. Not a phone for seniors(not user friendly for them). Terrible interference while using the internet. When the phone would ring you get booted off the internet or when doing any type of communication on the internet you are booted off. Am returning telephone tomorro …"  Read Full Review »
Mar 30 2008
The Busy Ones
Thumb area in Michigan
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
BizRate Rating Outstanding 9.0
Click for price
$20 Off Orders Over $125
$59.97
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
