Radio Shack 40W Reverse Voltage Converter
4.0
based on 4 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
1
1 star
0
Category Average
3.9
More Images
Pros
  • Easy to use (2)
  • Reliable (2)
  • Good performance (1)
  • Good value (1)
  • Heavy duty (1)
  • Long lasting (1)
  • Well built / quality construction (1)
See less See more
Cons
  • Cost (1)
Best Uses
  • High-end equipment (2)
  • European music instrument (1)
Provided by RadioShack
Use with motorized, heating and electronic devices.
Specification Description
Model 273-1411
Benefits Operate foreign devices in North America
Body Material Plastic
Capacity UOM mAh
Country Of Origin United States
Description Header Voltage conversion made easy.
Display Catalog Number 273-1411
Enclosure Color Black
End Product Indicator Yes
Included in the Box 40 Watt Reverse Electricity ConverterOwner's Manual
Intended Device Type Small appliances needing less than 40 watts
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 273-1411
Offer Disclaimer Pricing and availability may vary outside the contiguous 48 United States
Operating Temperature UOM ° F
Power Converter Yes
Power Device Converts standard US 110/120 VAC to foreign 220/240 VAC. Up to 40W output.
Power Type Step-up (120-to-240) AC Voltage Converter
Power Voltage AC 220/240 V
Product Disclaimer For use with motorized, electronic or heating appliances rated up to 40 watts maximum.
Product Type Converters
Supported Languages English, Spanish
Voltage Required AC 110/120 V
Radio Shack 40W Reverse Voltage Converter Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 40W Reverse Voltage Converter
See all eBay results
  at eBay.com
Product Reviews
Last update: Mar 1, 2009
Radio Shack 40W Reverse Voltage Converter Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
The best converter I ever found.........
5.0
    Pros
  • Beefy construction
  • Heavy Duty
  • Long Lasting
  • Reliable Performance
    Cons
  • None
    Best Uses
  • High-End Equipment
"I use this on a vintage Japanese electronic musical instrument (Korg VC-10 Vocoder) that has a Euro plug and it works great. It has solid construction and should last a lifetime. I can't think of any drawbacks as long as you use it as directed. Soon I'm gonna buy another one for a Euro-plugged Elect …"  Read Full Review »
My Korg VC-10 Vocoder has a Euro-style plug.
Was this Battery review on the Radio Shack 40W Reverse Voltage Converter helpful to you?
Mar 1 2009
davextwin
Gainesville, FL
I am:
  • Quality Oriented
Reviewed at:
[2 of 2 customers found this review helpful]
Great use for 50V halogen ...
4.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
    Cons
  • None
    Best Uses
  • None
"Great use for 50V halogen desk lamp(240V-50Hz). I attached a two appliance outlet to operate the lamp and a 50W desk fan (240V-50Hz). Converter operated for about a hour then failed to operate anymore. Need to use a higher voltage converter. Otherwisw a excellent product for a single appliance at …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Nov 5 2006
Vernon C
Houston, Texas USA
Reviewed at:
so so
2.0
"This product doesn't fit most european plugs. It is too big and not updated. Most plugs in Europe have round outside while this one has sharp edges. I barely got any use out of it. "
Mar 8 2008
Jellyfisher
Stamford, CT
I am:
  • Quality Oriented
Reviewed at:
[1 of 1 customers found this review helpful]
5.0
    Pros
  • Easy to use
    Cons
  • Cost
    Best Uses
"Works perfectly for converting european electronics for use with american power. "
 Report Abuse  (1)  (0)  0 comments
Feb 14 2009
Gary
Centennial Colorado
I am:
  • Quality Oriented
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
