#1
based on 184 reviews
Ratings Distribution
| 5 star |
115 |
| 4 star |
53 |
| 3 star |
7 |
| 2 star |
2 |
| 1 star |
7 |
Category Average
$34.99
from 1 storePros
Cons
Best Uses
Where to Buy
BizRate Rating
Good 8.6
$34.99 |
at
RadioShack
Product Reviews
[1 of 1 customers found this review helpful]
[0 of 1 customers found this review helpful]
"I wanted to boost the UHF reception on our old antenna array. This system must be at least 30 years old. Dispite having 2 separate UHF antennas along with a VHF antenna on the mast I could only recive VHF channels. Given this antenna was only [$] and had great reviews I decided to give it a shot. Dew to how steep my roof is I was only able to mount this antenna in place of the lowest UHF antenna. After some aim..." Read Full Review »
Jul 10, 2007 by madmatt2024
See more positive Radio Shack 40" Boom Length, 17 Elements Outdoor Antenna for UHF-Only reviews
"Was told to buy this for the new digital signals. Wrong choice for my area. Had to CONSTANTLY rotate for signal. Did find better results when I added an amplifier (though signals are less than 30 mi)and if when I tilted about 20/25 degrees from being vertical... tried 90 degrees - no work. Did not get all of the "old" channels as on analog. May be a great unit.... but not for my area - too much work to adjust f..." Read Full Review »
Feb 19, 2009 by Mr. NO FIX
See more negative Radio Shack 40" Boom Length, 17 Elements Outdoor Antenna for UHF-Only reviews
Displaying 1 - 5 of 184 Reviews
Radio Shack 40" Boom Length, 17 Elements Outdoor Antenna for UHF-Only Review
Pros
Cons
Best Uses
"I wanted to boost the UHF reception on our old antenna array. This system must be at least 30 years old. Dispite having 2 separate UHF antennas along with a VHF antenna on the mast I could only recive VHF channels. Given this antenna was only [$] and had great reviews I decided to give it a shot. D …" Read Full Review »
Pros
Cons
Best Uses
"Tried several antennae and the U 75 is tops for signal/size. Small enough for my attic. and the price is great. "
[3 of 3 customers found this review helpful]
Pros
Cons
Best Uses
"DTV conversion of Phoenix OTA stations shifted most local channels to UHF, and our 40 year old, Radio Shack VHF antenna didn't pick up many of them. This new UHF antenna was value priced and complimented our existing roof-top antenna.Some have complained that the box didn't include a matching transf …" Read Full Review »
[2 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"This antenna is your classic directional "beam"-style antenna that has been used for decades. It is designed to pull in signals best in the direction it is pointed. This is a much better solution than using a small UHF antenna with an amplifier. This antenna is meant to be mounted in the attic or ou …" Read Full Review »
[3 of 4 customers found this review helpful]
Pros
Cons
Best Uses
"The Antenna was simple to set up and worked well in an attic under architectured asphalt shingles. The purpose of the antenna was to eliminate nuisance pixilation while watching HTV using a broken set of rabbit ears. It was also hoped that we could get more channels and consistent performance. Th …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.6
$34.99 |
at
RadioShack
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
