Radio Shack 4-Way Audio/Video Selector Switch
#75
3.4
based on 24 reviews
Ratings Distribution
5 star
5
4 star
10
3 star
1
2 star
5
1 star
3
Category Average
3.7
$21.99 at RadioShack
Find it at Amazon
Find it at Ebay
$21.99
from 1 store
Pros
  • Easy to use (20)
  • Highly compatible (13)
  • Compact design (6)
  • High quality (6)
  • Good value (3)
  • Improves performance (3)
  • Lots of features (2)
  • Compact form factor (1)
  • Cool sleek look (1)
  • Good performance (1)
See less See more
Cons
  • Poor performance (3)
  • Not durable. (1)
  • Old school no remote (1)
  • Poor design (1)
  • Would like remote control (1)
Best Uses
  • Home movies (3)
  • Complex projects (2)
  • Studio (2)
  • Classroom audiovideo (1)
  • Doubled units amplified (1)
  • Hooking up acc wtv (1)
  • Independent films (1)
  • Varying av inputs (1)
Provided by RadioShack
Simplify your TV-audio/video source selection with this 4-way selector switch.
Specification Description
Model 15-1983
Accessory Indicator Yes
Benefits 4-in, 1-out console with contemporary stylingGold-plated connectors for superior signal transfer, high dependability and better-quali
Body Material Multi
Capacity UOM mAh
Country Of Origin China
Description Header Don't swap cables, just press a button!
Display Catalog Number 15-1983
Enclosure Color Gray
Exclusive Indicator Yes
Features 4-In 1-Out SwitchboxIncludes Device Labels for SwitchesIncludes Cable Labels for Quickly Identifying CablesComposit
Included in the Box AV Selector SwitchSelf Adhesive LabelsOwner's Manual
Inputs 4 x S-Video(Input (1,2,3, or 4) Video L/R), 4 x RCA(Input)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 15-1983
Offer Disclaimer Pricing and availability may vary outside the contiguous 48 United States.
Operating Temperature UOM ° F
Outputs 1 x S-Video(Output Video L/R), 1 x RCA(Output Video L/R)
Product Dimensions UOM inches
Product Height 2.01
Product Length 7.6
Product Type 4-way
Product Width 3.24
Protect your investment. Yes
Required to function Any four sources with RCA/phono jacks, such as VCR, satellite receiver, DVD player, video game, camcorder or other peripheral device
Supported Languages English
Radio Shack 4-Way Audio/Video Selector Switch Questions
Questions and Answers
Where to Buy
$21.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 15, 2009
Radio Shack 4-Way Audio/Video Selector Switch Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Product works great - however....
"The product worked as expected. I am happy with the item. HOWEVER - I ordered this online to be delivered to the store - unlike the competitor I had wait for the item to come in. A week later after not hearing anything from "The Shack" - I went into the store and bought the item off the shelf. A few days later I stopped by and my item had arrived - but I never received a notice. I asked to return the item when I..." Read Full Review »
Oct 07, 2009 by Allan
See more positive Radio Shack 4-Way Audio/Video Selector Switch reviews
3.0
Not bad for the price, but gamers beware
"I didn't have any picture problems like someone else mentioned. We have a HDTV and many gaming systems. It works great to organize all of your devices/cords through one output. However using the enter button on our TV remote caused the selector to revert to the left-most device (and we found no way to switch it back with the remote). I wasn't aware that there was even a sensor on the selector. I would thi..." Read Full Review »
Oct 26, 2007 by Cluttered with cords
See more negative Radio Shack 4-Way Audio/Video Selector Switch reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
4.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
  • Professional Quality
    Cons
  • None
    Best Uses
  • Complex Projects
  • Home Movies
  • In The Studio
  • Independent Films
"The product worked as expected. I am happy with the item. HOWEVER - I ordered this online to be delivered to the store - unlike the competitor I had wait for the item to come in. A week later after not hearing anything from "The Shack" - I went into the store and bought the item off the shelf. A few …"  Read Full Review »
Was this Video Switch review on the Radio Shack 4-Way Audio/Video Selector Switch helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 7 2009
Allan
Sterling, VA
I am:
  • Business Owner
Reviewed at:
Price: $21.99
Gets the job done and looks nice!
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
  • Improves Performance
    Cons
  • None
    Best Uses
  • In The Studio
"I am the AV tech at a school. I use this AV switch to run multiple sources to a one output to a closed-circuit TV channel. I also use these on multimedia carts to run multiple sources to a single LCD projector. I have bought many of these. I like this unit because it is sturdy, takes punishment from …"  Read Full Review »
May 13 2009
Danielle
Virginia
Reviewed at:
Price: $21.99
3.0
    Pros
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • None
However using the enter button on our TV remote caused the selector to revert to the left-most device (and we found …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Oct 26 2007
Milton, FL
I am:
  • Hobbyist
Reviewed at:
Price: $21.99
Just what I needed.
5.0
    Pros
  • Compact Design
  • Easy To Use
    Cons
  • None
    Best Uses
  • None
"Works great when your stereo system has only one Aux. input, but four are needed. No more changing RCA cables around for different uses. Simple to hook-up and use. "
Nov 6 2009
19nomad56
Salem, OR
I am:
  • Hobbyist
Reviewed at:
Price: $21.99
Ideal for connecting older components
4.0
    Pros
  • Easy To Use
  • Highly Compatible
  • Lots Of Features
    Cons
  • None
    Best Uses
  • None
"I was able to easily connect an older TV (with only a single S-video input) to a satellite receiver, a DVD player, and an even older VCR with only baseband video output. The video and audio quality does not seem to be compromised anywhere and the conversion from baseband to S-video is remarkably go …"  Read Full Review »
Oct 4 2007
DavidB
Colorado Springs, CO
I am:
  • Professional Engineer
Reviewed at:
Price: $21.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
