Radio Shack 4" Cooling Fan
#228
3.6
based on 7 reviews
Ratings Distribution
5 star
1
4 star
4
3 star
0
2 star
2
1 star
0
Category Average
4.3
$19.99 at RadioShack
Find it at Amazon
Find it at Ebay
$19.99
from 1 store
Pros
  • Easy to install (5)
  • Reliable (4)
  • Quiet (3)
  • Energy efficient (2)
  • Big in diameter (1)
  • Spins fast (1)
  • Storng casing (1)
See less See more
Cons
  • Noisy (4)
  • Blades are not protected (1)
  • Wiring (1)
Best Uses
  • Multimedia (3)
  • Cooling (2)
  • Upgrade (2)
  • Projects (1)
  • Replacement (1)
  • Rv condenser cooling fan (1)
Provided by RadioShack
Avoid hot spots by spot cooling with this 4” cooling fan. It's perfect for home, hobby and various electronic projects.
Specification Description
Model 273-238
Accessory Indicator Yes
Benefits Brushless DC motor-tops for mobile gear4.2 watts
Body Material Multi
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Beat the heat.
Display Catalog Number 273-238
Features 12VDC85cfm
Included in the Box 4" Cooling Fan (1)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 273-238
Operating Temperature UOM ° F
Product Height 1.5
Product Length 4.75
Product Type Standard case fans
Product Width 4.75
Recommended Use Computer
Supported Languages English
Radio Shack 4" Cooling Fan Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 13, 2009
Radio Shack 4" Cooling Fan Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Heavy on Amps and Noise but a work horse
2.0
    Pros
  • Easy To Install
    Cons
  • Loud
    Best Uses
  • Multimedia
"I have 6 of these fans, 3 series sets of 2 parallel for cooling my external hard drives and all the networking equipment. They cool everything off, but the noise from them is just too much. Just wish that they gave you the db level of them and whether or not they are 2 or 3 wire for rpm status. I …"  Read Full Review »
Being a Geek
  • Harddrives
  • Computers
  • Using Product
  • Made with Product
  • Mybook
  • Nerds
  • Geeks
  • Geek
  • Nerd
Was this Computer Fan & Cooling System review on the Radio Shack 4" Cooling Fan helpful to you?
Jun 3 2009
queball4u
wmass
I am:
  • Frequent User
[1 of 1 customers found this review helpful]
Nice, solid fan.
4.0
    Pros
  • Energy Efficient
  • Quiet
  • Reliable
    Cons
  • Wiring
    Best Uses
  • Cooling
"Very powerful little fan. It stays very quiet if anchored tight. I didn't need rubber dampers to quiet them. Used continuously, 24 hours a day for 6 months, no problems. Only uses 20 Watts. The only thing I didn't like was having to wire them to an AC plug so I could use them. But, that did al …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Mar 21 2009
David the Gnome
Bland Crapids, Michigan
I am:
  • Heavy Duty User
Good Fan
4.0
    Pros
  • Easy To Install
    Cons
  • Loud
    Best Uses
  • RV Condenser cooling Fan
"I use this fan in my RV to draw air through the condenser for my Dometic absorption refrigerator.I don't think many people think of using this fan for that purpose but it works great. Fan is a little noisy & I wish it had a higher CFM.Works great for this use. "
Jul 4 2009
Jack
Gardnerville, NV
I am:
  • Heavy Duty User
Nice quiet fan
4.0
    Pros
  • Easy To Install
  • Energy Efficient
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • Multimedia
"This fan worked very well to cool off a hot 42" Dell plasma TV that I had to mount in a cabinet, along with the other electronic stuff. I would have given it 5 stars if it boosted more than 85 cfm, but this was more than adequate for my purposes. "
Dec 1 2008
Doc
Sonoma, CA
I am:
  • Frequent User
3000 rpm!
4.0
    Pros
  • Big in diameter
  • Easy To Install
  • Quiet
  • Reliable
  • Spins fast
  • More »
    Cons
    Best Uses
  • Cooling
  • Projects
  • Replacement
  • Upgrade
"It works great to just cool yourself off. Does not weigh much. Has many uses. Simple hook-up (red & black wires) "
Sep 13 2009
Fan Works Great!!!
I am:
  • Heavy Duty User
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
