Radio Shack 4" Antenna Mast Wall Mount
#128
3.0
based on 7 reviews
Ratings Distribution
5 star
1
4 star
3
3 star
0
2 star
1
1 star
2
Category Average
3.6
$13.99 at RadioShack
Find it at Amazon
Find it at Ebay
$13.99
from 1 store
Pros
  • Durable (3)
  • Easy setup (2)
  • Strong signal (2)
  • Made in the usa (1)
See less See more
Cons
  • Pricey (2)
  • Hard to set up (1)
  • Heavy / bulky (1)
  • Not corrosion resistant (1)
Best Uses
  • Attic/roof mount (2)
  • Outdoors (1)
Provided by RadioShack
The 4” wall mount secures a mast 4” away from the side of a building to allow it to clear eaves. The wall mount holds masts up to 1¼" in diameter
Specification Description
Model 15-0883
Accessory Indicator Yes
Benefits Rust resistantGalvanized steel 1¼" in diameter
Body Material Metal
Capacity UOM mAh
Country Of Origin United States
Description Header Your mount for clearing eaves with ease
Display Catalog Number 15-883
Enclosure Color SILVER
Features Mounting Hardware Included12" Stand OffGalvanized Steel Brackets
Included in the Box 4" Antenna Mast Wall Mounts (2)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 15-0883
Operating Temperature UOM ° F
Product Type Mounting hardware
Supported Languages English
Radio Shack 4" Antenna Mast Wall Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 16, 2009
Radio Shack 4" Antenna Mast Wall Mount Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Works great
4.0
    Pros
  • Strong Signal
    Cons
  • Bulky
  • Hard To Set Up
    Best Uses
  • Attic/Roof Mount
"I live 40 miles NW of Albany NY. When the switch to digital happened I lost half the channels I used to receive. I finally broke down and boutht a roof top antennae. Once I got the antennae up it was amazing how clear the channels came in. I receive much more channels than I did before. I recommend …"  Read Full Review »
Was this Antenna review on the Radio Shack 4" Antenna Mast Wall Mount helpful to you?
Sep 16 2009
Mike
Ephratah, NY
I am:
  • Casual User
Exactly what was advertised
5.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
"This product is described accurately; and priced exactly the same in the store as on the website. I read the description before I went to the store and knew what I was buying. The big box hardware stores don't even deal in antenna mounting hardware; and the true "hardware" stores are few and far b …"  Read Full Review »
May 31 2009
28270
Charlotte, NC
I am:
  • Enthusiast
[3 of 7 customers found this review helpful]
Should be made of better material
1.0
    Pros
  • Easy To Set Up
  • Strong Signal
    Cons
  • Expensive
  • Not Corrosion Resistant
    Best Uses
  • None
"This product is made out of galvanized steel, which can and does rust. A product that is designed to be used outside should be made of a corrosion resistant material such as titanium. If this product were made from titanium, it would be a good bargan at its admittedly high price. Since it is made …"  Read Full Review »
 Report Abuse  (3)  (4)  0 comments
Mar 19 2009
Dave
I am:
  • Power User
[2 of 3 customers found this review helpful]
Pricey But USA Made Quality!
4.0
    Pros
  • Durable
  • MADE IN THE USA
    Cons
  • Pricey
    Best Uses
  • Outdoors
"Others are hammering this mount as being to expensive & I questioned the price as well when I saw it in the store BUT the mount is of high quality & comes with every piece of hardware needed for a successful installation. The fact that its made here in the good ol USA makes justifies the price tag:- …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Jul 16 2008
ALRUI
Smokies
I am:
  • Gearhead
  • Tech Savvy
[0 of 2 customers found this review helpful]
Sturdy, and clears shingles
4.0
    Pros
  • Durable
    Cons
  • None
    Best Uses
  • None
"Galvanized items such as this are used all the time outside, and yes it will develop some rust in a few years, but not enough to compromise its strength; paint it if still concerned. This bracket stands out from the side of the building so that the mast readily clears the edges of concrete roofing …"  Read Full Review »
 Report Abuse  (0)  (2)  0 comments
Apr 8 2009
Dudmc3
Roseville, California
I am:
  • Power User
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
