Radio Shack 4 “AA” Battery Holder
#1687
3.7
based on 3 reviews
from $1.79
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.1
$1.79 at RadioShack
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Consistent performance (2)
  • Good length (2)
  • Rugged (2)
  • Versatile (2)
See less See more
Cons
  • Wears out quickly (1)
Best Uses
  • Personal projects (1)
Provided by RadioShack
This wire connector battery holder holds 4 “AA” batteries and color-coded wire leads.
Specification Description
Model 270-383, 270-391
Accessory Indicator Yes
Benefits Helps combine batteries for more powerHolds 4 "AA" batteriesGreat for projects or making your own battery packs
Benefits Holds 4 AA batteriesEasy connector end
Body Material Plastic
Capacity UOM mAh
Country Of Origin China
Country Of Origin Hong Kong
Description Header Get power in a snap.
Description Header Get wired for power.
Display Catalog Number 270-383
Display Catalog Number 270-391
Enclosure Color BLACK
Features Mountable battery holderColor-coded wire leads
Features Snap connectorDurable plasticEasy to use for projects
Included in the Box Battery holder for 4 AA batteries
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 270-383
Model 270-391
Operating Temperature UOM ° F
Product Type AA
Supported Languages English
Radio Shack 4 “AA” Battery Holder Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 21, 2009
Radio Shack 4 “AA” Battery Holder Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Great Product
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Personal projects
"This holder is awesome I use them for most of the projects that i do. the quick snaps work great and make it very easy and much lighter to have a six volt battery when you need one. it takes up about at most about 1/3 the space of a normal size 6 volt battery. "
Was this Audio Visual Cable & Connector review on the Radio Shack 4 “AA” Battery Holder helpful to you?
 Report Abuse  (1)  (0)  0 comments
Feb 16 2009
Chris the SA
Ridgeland, MS
I am:
  • Enthusiast
Nova-Tech Radio replacement Batt Holder
5.0
    Pros
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • None
"This is the perfect replacement battery holder for all portable vintage Nova-Tech radios and the price is right. Please Do Not use a 9v battery in them! The radios are 6 volt. "
Apr 21 2009
Don
Upland, CA
I am:
  • Enthusiast
[0 of 2 customers found this review helpful]
It melted!!
1.0
    Pros
  • None
    Cons
  • Wears Easily
    Best Uses
  • None
"It held up the first couple of days, then the batteries got hot and melted the casing. "
 Report Abuse  (0)  (2)  0 comments
Mar 13 2009
Alpha Kenny Won
NY,NY
I am:
  • Casual User
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
