Close Login Module
Join
Radio Shack 3-Way HDMI Switcher
#77
2.1
based on 42 reviews
Ratings Distribution
5 star
6
4 star
4
3 star
4
2 star
5
1 star
24
Category Average
3.7
$59.99
from 1 store
Pros
  • Easy to use (22)
  • Highly compatible (9)
  • Compact design (3)
  • Improves performance (3)
  • Attractive design (1)
  • Can't come up with one . (1)
  • Changes ports (1)
  • Cheaper on long runs (1)
  • Easy setup (1)
  • Fails (1)
See less See more
Cons
  • Poor performance (17)
  • Limited compatibility (13)
  • Lacks functionality (8)
  • Difficult to use (2)
  • Cant turn off always on (1)
  • Everything (1)
  • Fails (1)
  • Junk (1)
  • Over priced in ak (1)
  • Stopped working (1)
Best Uses
  • Home movies (8)
  • Best on simple hookups (1)
  • Cable tv only (1)
  • Complex projects (1)
  • Dingy anchor (1)
  • Door stop (1)
  • Hdtvblu-rht (1)
  • Home (1)
  • Movies (1)
Where to Buy
$59.99
Product Reviews
Last update: Oct 30, 2009
Radio Shack 3-Way HDMI Switcher Reviews
Most helpful positive review
Most helpful negative review
5.0
Mine Works Great!!
"Guess I got a good one. This was the only model in the store, so I took a chance. It was easy to set up and learn the remotes of my Toshiba HD VCR and Sony HD TV. The picture and sound are excellent. This is the perfect reasonably priced solution to having only one TV HDML input!..." Read Full Review »
Jul 15, 2007 by Ed
See more positive Radio Shack 3-Way HDMI Switcher reviews
3.0
Some are good, Some are bad...
"I have had two of these, and my friend one. My friend's had poor picture quality,but everything worked well,(his PS3 & cable box). My first one, the remote was not picking it up at times, and my PS3 would not work. My second one is great, PS3 works and everything else, it responds to my remote like it should. I have connected to it a HD DVR,xbox 360, and PS3, everything looks excellent, no degredation in picture..." Read Full Review »
Feb 28, 2008 by 915
See more negative Radio Shack 3-Way HDMI Switcher reviews
Displaying 1 - 5 of 42 Reviews
Show
Sort by
3.0
    Pros
  • Easy To Use
  • Highly Compatible
  • Looks good small size
    Cons
    Best Uses
  • None
"I have had two of these, and my friend one. My friend's had poor picture quality,but everything worked well,(his PS3 & cable box). My first one, the remote was not picking it up at times, and my PS3 would not work. My second one is great, PS3 works and everything else, it responds to my remote like …"  Read Full Review »
Was this Video Switch review on the Radio Shack helpful to you?
Feb 28 2008
915
El Paso, Texas
I am:
  • Hobbyist
Reviewed at:
Price: $59.99
[2 of 2 customers found this review helpful]
I used to work for the Shack
3.0
    Pros
  • Simple
  • Small
    Cons
  • Limited Compatibility
  • Poor Performance
    Best Uses
  • Simple HDMI devices
"I have had this item for about a year now. I got it while I was working for Radioshack. It DOES work with audio (when it is working correctly... contrary to a previous reviewer) and it does work with HDMI to DVI but its a bit of a pain to get audio that way. I never really had an issue with mine unt …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 3 2008
Bob
NJ
I am:
  • Electronics Expert
Reviewed at:
Price: $59.99
[1 of 1 customers found this review helpful]
Doesn't work with Playstation 3
2.0
    Pros
  • Easy To Use
    Cons
    Best Uses
  • None
"I bought this item because I have three items to hook up to HDMI and only 2 ports on my TV. So I plugged my HD DVR into one port and I plugged this item into the other port. I hooked up an HD DVD player and that worked fine, I also hooked up a Playstation 3 and it didn't work. I tried switching c …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 29 2007
CoAsTeRDaN
Richmond, VA
I am:
  • Hobbyist
Reviewed at:
Price: $59.99
Do not buy, Doesn't work right.
1.0
    Pros
  • Easy To Use
    Cons
    Best Uses
  • Video games
"I Brought this product because my TV has only 1 hdmi port. When I first brought it i only had my 360 and PS3 hooked up to it and it worked fine. Once I upgraded my cable to HD and hooked it up through the switcher the problems started. Sometimes you get no picture other times you get no sound. I try …"  Read Full Review »
Jan 25 2009
Smoke
Queens, NY
I am:
  • Hobbyist
Reviewed at:
Price: $59.99
Has mind of its own, changes input
1.0
    Pros
  • Easy To Use
    Cons
  • Poor Performance
    Best Uses
  • Home Movies
"I planned to have my Comcast Cable/DVR and a Playstation 3 connected to the Radio Shack 3-Way HDMI Switch. It worked great for 3-4 days then started developing a mind of its own. While watching Comcast Cable the 3-Way HDMI Switch will change from Input 1 to Input 2 without any buttons being presse …"  Read Full Review »
Jan 1 2009
Jaarons
Fernandina Beach, FL
Reviewed at:
Price: $59.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$59.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
