Radio Shack 3.6V/750mAh Ni-MH Cordless Phone Battery
2.4
based on 29 reviews
from
Ratings Distribution
5 star
5
4 star
5
3 star
2
2 star
1
1 star
16
Category Average
3.9
Pros
  • Easy to use (6)
  • Good performance (3)
  • Reliable (3)
  • Easy setup (2)
  • Good value (2)
  • Comfortable handset (1)
  • Durable (1)
  • Fantastic (1)
  • It was a battery (1)
  • Lightweight (1)
See less See more
Cons
  • Not durable (4)
  • Short battery life (3)
  • Dead battery in 90 min (1)
  • Trashjunkwast of money (1)
  • Used less than 60 day (1)
Best Uses
  • Everyday (9)
  • Home use (4)
  • Effective (1)
  • Good for agravation (1)
Provided by RadioShack
This 3.6-volt, rechargeable phone battery uses a Type “C” connector and works with RadioShack and Uniden models.
Specification Description
Model 230-0961
Accessory Indicator Yes
Battery Finder Indicator Yes
Battery Type Product
Body Material Metal
Capacity 750
Capacity UOM mAh
Chemistry Ni-MH
Country Of Origin China
Description Header Talk up a storm.
Display Catalog Number 23-961
Enclosure Color WHITE
Equivalent to Dantona BATT-446, BATT-909, Gold Peak 80AAALH3BMX, GP80AAALH3BMX, 75AAALH3BMZ, GPI BT446, RadioShack CS90261, CS90660, 12452843, Toshiba ATTBAT4126, U
Included in the Box battery
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 230-0961
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 0.375
Product Length 1.625
Product Type 3.6V Ni-MH
Product Width 1.375
Recommended Use RadioShack 43-113, 43-141, 43-142, 42-143, 43-144, 43-3529, 43-3538, 43-3570, 43-3571, 43-3580, 43-3581, 43-3597, 43-3598, 43-3703, 43-3704, 43-3705,
Size Pack
Supported Languages English
Voltage 3.6
Voltage UOM Volts
Radio Shack 3.6V/750mAh Ni-MH Cordless Phone Battery Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 3.6V/750mAh Ni-MH Cordless Phone Battery
See all eBay results
  at eBay.com
Product Reviews
Last update: May 12, 2009
Radio Shack 3.6V/750mAh Ni-MH Cordless Phone Battery Reviews
Most helpful positive review
[0 of 1 customers found this review helpful]
Most helpful negative review
5.0
Its all about the charging process!!!
"Most people dont understand the battery charging process. You cant leave your phone on charge at all times. Taking it off when you talk and putting it back on after your finished isnt cutting it. You must leave your phone off until its time to charge it. Normaly take it off during the day and charge it at night. try these tips before giving these batteries a bad grade. I have had my battery for over 2 years by d..." Read Full Review »
Feb 25, 2008 by Road Runner
See more positive Radio Shack 3.6V/750mAh Ni-MH Cordless Phone Battery reviews
3.0
Replacement battery for Uniden BT-446
"General Comments: First replacement battery for this phone. The OEM battery pack is physically larger (3 X 5/4 AAA's) and rated at a higher capacity (3.6V @ 800mAh), than this replacement (3 X AAA's, and 3.6V @ 750mAh). We live in the country, with several detached buildings from the house (garage, sheds, barn, etc.), and have no neighbors withing 3500+ ft, line of sight. The handset (Uniden Mod. TRU8865-2), ..." Read Full Review »
Mar 15, 2008 by Rockne Rancher
See more negative Radio Shack 3.6V/750mAh Ni-MH Cordless Phone Battery reviews
Displaying 1 - 5 of 29 Reviews
Show
Sort by
3.0
"General Comments: First replacement battery for this phone. The OEM battery pack is physically larger (3 X 5/4 AAA's) and rated at a higher capacity (3.6V @ 800mAh), than this replacement (3 X AAA's, and 3.6V @ 750mAh). We live in the country, with several detached buildings from the house (garage …"  Read Full Review »
Was this Battery review on the Radio Shack 3.6V/750mAh Ni-MH Cordless Phone Battery helpful to you?
Mar 15 2008
Rockne Rancher
Bastrop County, Texas
I am:
  • Quality Oriented
Reviewed at:
[1 of 1 customers found this review helpful]
Died within 2 months
1.0
    Pros
  • None
    Cons
  • Not Durable
    Best Uses
  • Everyday Use
"I used the stock BT-446 batteries on my Uniden phone for about 3 or 4 years. The phone would reboot after a couple of minutes of talk time so I decided it was time to replace the batteries. I went to Radio Shack and these were suggested by the sales lady. I had my doubts because of its lower capa …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Oct 19 2008
time2believe
East Bay, CA
I am:
  • Value Oriented
Reviewed at:
5.0
    Pros
  • Durable
    Cons
  • Nothing
    Best Uses
  • Everyday Use
"Most people dont understand the battery charging process. You cant leave your phone on charge at all times. Taking it off when you talk and putting it back on after your finished isnt cutting it. You must leave your phone off until its time to charge it. Normaly take it off during the day and charge …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Feb 25 2008
Road Runner
New York
I am:
  • Value Oriented
Reviewed at:
Unfit for duty
1.0
    Pros
  • None
    Cons
  • Poor Battery Life
    Best Uses
  • None
"The OEM batteries are quality. 1 of 2 OEM batteries is still going after six years of use. I replaced the other one with this battery. This Radio Shack battery is not worth the packaging it comes in. After only a few months it provides less than 15 minutes of talk time. I switched it in the pho …"  Read Full Review »
Dec 13 2008
Former Radio Shack Customer
Spring, Tx
I am:
  • Quality Oriented
Reviewed at:
Zero stars would be my rating
1.0
    Pros
  • Supposed to last 7 hours
    Cons
    Best Uses
  • None
"I bought this battery for both my Uniden phones [...] and charged it for almost 2 days to be safe. In less that 60 days the phones began dying after only 90 minutes of talk time despite my being assure it would last 6-7 hours. I have a backup cordless unit in case of a dying handset, but I had used …"  Read Full Review »
Aug 27 2007
Tired of the hype
New York, NY
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
