Radio Shack 25-Ohm 3-Watt Rheostat
#614
4.4
based on 8 reviews
Ratings Distribution
5 star
4
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.1
$3.99 at RadioShack
Find it at Amazon
Find it at Ebay
$3.99
from 1 store
Pros
  • Consistent performance (4)
  • Good length (2)
  • Good performance (2)
  • Good value (2)
  • Reliable (2)
  • Rugged (2)
  • Easy to use (1)
  • Versatile (1)
See less See more
Best Uses
  • Built my own amp (works) (1)
  • High-end equipment (1)
  • Low power audio mixer (1)
Provided by RadioShack
25-ohm ±20% tolerance wirewound 3-watt variable resistor.
Specification Description
Model 271-265
Accessory Indicator Yes
Body Material Metal
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Your source for component parts.
Display Catalog Number 271-265
Included in the Box 25-Ohm 3-Watt Rheostat
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Max Operating Temperature 158 Fahrenheit
Min Operating Temperature 14 Fahrenheit
Model 271-265
Operating Temperature UOM ° F
Product Type Potentiometers
Supported Languages English
Radio Shack 25-Ohm 3-Watt Rheostat Questions
Questions and Answers
Where to Buy
$3.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Jul 1, 2009
Radio Shack 25-Ohm 3-Watt Rheostat Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
Great Part But Very Overpriced
3.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
    Cons
  • None
    Best Uses
  • None
"Great part works fine, it is hard to find wire wound rheo's around this value (25 ohm) and I think Radio Shack knows this so they have the price jacked up sky high. If you only need to buy one of these for a project the price is not to bad but when you use 20 a week... "
Was this Audio Visual Cable & Connector review on the Radio Shack 25-Ohm 3-Watt Rheostat helpful to you?
Jul 1 2009
Amp Man
Florida
I am:
  • Power User
Reviewed at:
Price: $3.99
It works great!
5.0
    Pros
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Low Power Audio Mixer
"It works exactly as I intended in the audio mixer I designed and built. I use it at church all the time. I use it to monitor myself on the piano and still hear the monitor mix. "
Jan 17 2009
Tuneguy
Colorado
I am:
  • Power User
Reviewed at:
Price: $3.99
perfect description. t
5.0
    Pros
    Cons
  • None
    Best Uses
  • None
"I build homemade guitar amps and guitars. This is a key component to my amp design and would like to find out about bulk ordering. "
May 26 2009
Ben
Wasilla, AK
I am:
  • Enthusiast
Reviewed at:
Price: $3.99
[0 of 1 customers found this review helpful]
Easy to use. Wire it as ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Easy to use. Wire it as any rheostat. Generates low heat (I'm using it in a 12v, 0.16A circuit). "
 Report Abuse  (0)  (1)  0 comments
Jul 13 2006
Oliver B
Bethesda, MD
Reviewed at:
Price: $3.99
[1 of 1 customers found this review helpful]
This rheostat wires as ...
5.0
"This rheostat wires as does any typical pot. The middle is the wiper like on pots, and the two ends are the respective ends. It seems to work very well as part of my attenuator circuit (low power section). "
 Report Abuse  (1)  (0)  0 comments
Jun 8 2007
Rick w
Dickinson
Reviewed at:
Price: $3.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
