Radio Shack 25-Amp Switching DC Power Supply
4.3
based on 42 reviews
from
Ratings Distribution
5 star
25
4 star
11
3 star
2
2 star
0
1 star
4
Category Average
3.9
Pros
  • Reliable (33)
  • Powerful (18)
  • Easy to use (4)
  • Good performance (4)
  • Good value (4)
  • Long lasting (2)
  • 25 amps baby (1)
  • Binding posts (1)
  • Compact design (1)
  • Great buy for sure (1)
See less See more
Cons
  • Unreliable (2)
  • 0 (1)
  • Birdies (1)
  • Fan (1)
  • Fan always on (1)
  • Generates noise birdies (1)
  • Inconsistent performance (1)
  • No indicator light when (1)
  • Noisey cooling fan (1)
Best Uses
  • Portable electronics (13)
  • Travel (12)
  • Emergency equipment (9)
  • Having around the house (9)
  • High-end equipment (6)
  • Ham radio (1)
  • Ham radio icom ic-706mkii (1)
  • Ham transceivers (1)
  • I use it with my 2m radio (1)
  • Office (1)
Provided by RadioShack
Power your DC devices using any wall outlet.
Specification Description
Model 22-510
Benefits Works as a high-power bench power supplyLighted on/off switch, circuit breaker, overheating protectionEquipped with a 6-foot
Body Material Multi
Cables Included 6V AC Cord
Capacity UOM mAh
Country Of Origin China
Description Header DC power anywhere you need it.
Display Catalog Number 22-510
Enclosure Color Black
End Product Indicator Yes
Features Fan speed controlWith red/black terminal post outputsProvides 13.8VDC at up to 25 amps continuous
Included in the Box Power Supply6V AC CordOwner's Manual
Inputs 1 x (AC Plug)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 22-510
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Outputs 1 x Post Terminal(Positive Binding Post), 1 x Post Terminal(Negative Binding Post)
Power Device AC Power Cord
Product Depth 7.312
Product Dimensions UOM inches
Product Height 2.156
Product Length 7.312
Product Type DC power supplies
Product Weight 3.37
Product Weight UOM pounds
Product Width 7.812
Protect your investment. Yes
Required to function AC House Current
Supported Languages English
Radio Shack 25-Amp Switching DC Power Supply Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 25-Amp Switching DC Power Supply
See all eBay results
  at eBay.com
Product Reviews
Last update: Aug 1, 2009
Radio Shack 25-Amp Switching DC Power Supply Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
RS 22-510 25 Amp Switching Power Supply
"I have both this and the SEC 1223 12v switching power supply. I have had them both for about 4 years now.[...]Since I have two similar units, I have to say I like the fact that the RS unit has binding posts with banana jacks whereas the SEC 1223 has crummy screw terminals for output.The RS supply is indeed capable of sourcing a full 25 amps, but the voltage drops considerably (11.9 volts) when so loaded. This ..." Read Full Review »
Mar 28, 2009 by CyberMike
See more positive Radio Shack 25-Amp Switching DC Power Supply reviews
1.0
Usesless for HF
"Connected this PS to my Yaesu FT-900 and immediately noticed that the noise floor was about an S-7 on 40m with no antenna connected. Even more annoying is the PSK31 'type' of howling noises being generated by the PS across the entire HF spectrum. When I connect the FT-900 to an analog PS (a Kenwood PS30), the noise level dropped to an S2 on the same 40m frequency and the PSK31 type of QRN completely disappeared...." Read Full Review »
Sep 13, 2007 by J&B
See more negative Radio Shack 25-Amp Switching DC Power Supply reviews
Displaying 1 - 5 of 42 Reviews
Show
Sort by
4.0
    Pros
  • Binding Posts
  • Reliable Performance
    Cons
  • Fan always on
    Best Uses
  • RC Charging HAM radio
"I have both this and the SEC 1223 12v switching power supply. I have had them both for about 4 years now.[...]Since I have two similar units, I have to say I like the fact that the RS unit has binding posts with banana jacks whereas the SEC 1223 has crummy screw terminals for output.The RS supply i …"  Read Full Review »
Was this Battery review on the Radio Shack 25-Amp Switching DC Power Supply helpful to you?
 Report Abuse  (1)  (0)  0 comments
Mar 28 2009
CyberMike
Milwaukee, WI
I am:
  • Quality Oriented
Reviewed at:
[3 of 3 customers found this review helpful]
How can Radio Shack do this?
5.0
    Pros
  • Powerful
    Cons
  • NONE
    Best Uses
  • Ham radio Icom IC-706MKII
"I was surprised with the price and amps that this unit was advertised for. I thought I would order one to try out on my new Icom IC-706MKII transceiver for use the house. I just spent a bunch of money for the transceiver and didn't have $150.00 or more for a power supply from the usual Ham stores. …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jun 4 2009
Doc Cross
Ferndale, Washington
I am:
  • Quality Oriented
Reviewed at:
[2 of 2 customers found this review helpful]
Fine supply, no noise!
5.0
    Pros
  • Powerful
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Office
  • Portable Electronics
  • Travel
"I have three of these things. I use two to power a Kenwood TS-480HX amateur radio, no problems and the the third to power my Yeasu FT-897 (also to charge the onboard 897 batteries). No noise, seemingly bulletproof. Great value to me. "
 Report Abuse  (2)  (0)  0 comments
Jul 20 2008
Doc
Central Wisconsin
I am:
  • Quality Oriented
Reviewed at:
power for auto trap
5.0
    Pros
  • Powerful
    Cons
  • None
    Best Uses
  • None
"Im using it to power a aerial assault auto trap (throws clays for sport shooting) it requires 22 amps 12 volts. Ive used it several times to power the unit and its performed great. supplies plenty of power is easy to setup and operate. If you need to power any equipment similar to this id rec. it. "
Feb 3 2009
Rick
new bern n.c.
I am:
  • Quality Oriented
Reviewed at:
Wonderful product, lots of power!!
5.0
    Pros
  • 25 amps baby
  • Powerful
    Cons
  • NONE
    Best Uses
  • Having Around The House
  • RC chargers
  • Travel
"I bought this power supply to feed the 12V requirement for the battery chargers that we use for our radio control models. We us a lot of Li-po (lithium Polymer) batteries in our models and the chargers require up to 10 amps of current at times. This power supply fit the bill perfectly and was priced …"  Read Full Review »
May 29 2009
Team JR Rick
Tennessee
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
