Radio Shack 2-Pin Wall Plate with ADSL Filter
#854
2.3
based on 6 reviews
from $18.99
Ratings Distribution
5 star
0
4 star
0
3 star
4
2 star
0
1 star
2
Category Average
4.1
$18.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Durable (1)
  • Improves performance (1)
  • Works as intended (1)
See less See more
Cons
  • Limited compatibility (2)
  • Retrofitting needed (1)
Best Uses
Provided by RadioShack
Get quick and dependable phone and internet connections with this wall plate with ADSL filter.
Specification Description
Model 279-SRS
Accessory Indicator Yes
Benefits Compatible with G.Lite, Full-Rate and HomePNA
Body Material Plastic
Cable Length Under 1 ft.
Cable Type Networking
Capacity UOM mAh
Country Of Origin China
Description Header Hassle-free cable networking.
Display Catalog Number 279-104
Features Modular RJ-11 jackBuilt-in ADSL filterScrews included
Included in the Box Wall Plate filterMounting hardware - Coin Screw x 2, Screw x 2, Nut x 2
Inputs 1 x RJ11(Input)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 279-SRS
Operating Temperature UOM ° F
Outputs 1 x RJ11(Input)
Product Type Networking
Supported Languages English
Radio Shack 2-Pin Wall Plate with ADSL Filter Questions
Questions and Answers
Where to Buy
$18.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Apr 10, 2008
Radio Shack 2-Pin Wall Plate with ADSL Filter Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Warning - Not Standard Size
1.0
    Pros
  • Durable construction
    Cons
  • Limited Compatibility
    Best Uses
  • None
"Great concept, but 3/8" too wide for a standard one gang mud ring. Only buy it if you have additional wall thickness that can be removed, you're mounting it over an access hole you just made in the wall, or if you want to grind out the ring sides. Hopefully [...] will revise the design so the PCB is …"  Read Full Review »
Was this Computer Cable & Connection review on the Radio Shack 2-Pin Wall Plate with ADSL Filter helpful to you?
Nov 2 2007
JT
East Dundee, Il
I am:
  • Quality Oriented
Reviewed at:
Price: $18.99
Installation - 0, functionality - 5
3.0
    Pros
  • works as intended
    Cons
  • None
    Best Uses
  • None
"The DSL filter assembly on the back of the faceplate does not fit in a standard single gang plastic electrical box. The filter on the back is approx 1/8" too wide. I was able to install it because I mounted the box to a stud wall in my basement, and I was able to force the filter into the electric …"  Read Full Review »
Apr 10 2008
Mike
Mason, Michigan
Reviewed at:
Price: $18.99
Got it to work
3.0
    Pros
  • Improves Performance
    Cons
    Best Uses
  • None
"I was able to get it to mount to a "Wiremold" on-wall PVC outlet box. You can get one that's 1 inch thick. I got a metal box first, but like the other comments said, it the back of this wall plate doesn't fit with many outlet boxes.
The tricky part was getting it installed. Now that it's in, i …"  Read Full Review »
Feb 12 2008
Dave
San Leandro, CA
Reviewed at:
Price: $18.99
Previous review stated ...
3.0
"Previous review stated the filter was same width as metal elec. box. That's true. Had to notch out the electrical box with a dremel metal cutting wheel to get it to fit. Also did not work when phone wires were connected to the filter. Left the wires where they were and attached to jumper wires …"  Read Full Review »
Aug 15 2006
John F
St. Paul
Reviewed at:
Price: $18.99
does NOT work in place of ...
1.0
"does NOT work in place of a regular wall jack. save your money! "
Oct 19 2006
annemarie b
delaware
Reviewed at:
Price: $18.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
