Radio Shack 2.4GHz Wireless Audio/Video Sender with IR Extender
#2261
2.8
based on 33 reviews
from $99.99
Ratings Distribution
5 star
5
4 star
10
3 star
2
2 star
5
1 star
11
Category Average
4.1
$99.99 at RadioShack
Find it at Amazon
Find it at Ebay
More Images
Pros
  • Consistent performance (7)
  • Good length (7)
  • Easy setup (5)
  • Versatile (5)
  • Easy to use (3)
  • Rugged (3)
  • Attractive design (2)
  • Compact (2)
  • Easy to install (2)
  • Great sound quality (2)
See less See more
Cons
  • Inconsistent signal (12)
  • Poor sound quality (3)
  • Incompatible (2)
  • Could not clear static (1)
  • Easily interfered by body (1)
  • Interference w some wifi (1)
  • Ir extender did'nt work (1)
  • Noisy (1)
  • Not the best quality (1)
  • Only one receiver (1)
Best Uses
  • Dorm room (3)
  • Basic systems (2)
  • High-end equipment (2)
  • Anywhere (1)
  • Camcorders (1)
  • Control dvr (1)
  • Entertainment (1)
  • Extending broadband tv (1)
  • Extra room or patio (1)
  • Not in a classroom (1)
Provided by RadioShack
Transmit any A/V signal to anywhere in your home up to 250 feet away.
Specification Description
Model 15-126
Benefits Send and control an A/V signal to any room in your house up to 250 feet awayUse your existing remote to control a device in another r
Cables Included Audio/Video Cable (2)
Capacity UOM mAh
Cordless/Wireless Yes
Country Of Origin Taiwan
Description Header Transmit A/V signals to any room in your home.
Display Catalog Number 15-126
End Product Indicator Yes
Included in the Box TransmitterReceiver w/ Built-in IR SensorIR ExtenderAC Adapter (2)Audio/Video Cable (2)User's Gui
Inputs 1 x RCA(Video (Transmitter)), 2 x RCA(Audio (Transmitter)), 1 x S-Video(S-Video (Transmitter))
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model 15-126
New Date Tue Sep 25 00:00:00 CDT 2007
Operating Temperature UOM ° F
Outputs 1 x RCA(Video (Receiver)), 2 x RCA(Audio (Receiver)), 1 x S-Video(S-Video (Receiver))
Product Dimensions UOM inches
Product Height 3.8
Product Length 5
Product Type Signal sender/receiver
Product Weight 0.5
Product Weight UOM pounds
Product Width 1.48
Radio Frequency Range 2.4 - 2.4835 GHz
Supported Languages English
Radio Shack 2.4GHz Wireless Audio/Video Sender with IR Extender Questions
Questions and Answers
Where to Buy
$99.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 17, 2009
Radio Shack 2.4GHz Wireless Audio/Video Sender with IR Extender Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Very pleased, works with Comcast DVR!
"I was looking for something to replace my slingbox. I love slingbox, but am tired of watching my cable box on my laptop all the time - wanted to control my Comcast DVR and watch on-demand without paying another $10-$15/month on my bedroom 27" LCD. Pros: It does what it's supposed to. Remote works great after I got the transmitter piece properly pointing at the cable box. The audio and video transmit great. Con..." Read Full Review »
Mar 23, 2009 by Scott
See more positive Radio Shack 2.4GHz Wireless Audio/Video Sender with IR Extender reviews
2.0
So far so good.
"Using about 80 ft away from each other and through 3 walls with no problems. I also live in an apartment and expected interference with all the other close apartments to me and it had none what so ever. However the receiver unit felt hot after 1 hr and I used a temp probe to check the temperature and it is above its max operating temp of 104F sitting on a cold shelf. Measured it at 109F and its still gaining...." Read Full Review »
Oct 18, 2008 by BigB
See more negative Radio Shack 2.4GHz Wireless Audio/Video Sender with IR Extender reviews
Displaying 1 - 5 of 33 Reviews
Show
Sort by
So far so good.
2.0
"Using about 80 ft away from each other and through 3 walls with no problems. I also live in an apartment and expected interference with all the other close apartments to me and it had none what so ever. However the receiver unit felt hot after 1 hr and I used a temp probe to check the temperature …"  Read Full Review »
  • Using Product
Was this Audio Visual Cable & Connector review on the Radio Shack 2.4GHz Wireless Audio/Video Sender with IR Extender helpful to you?
 Report Abuse  (1)  (0)  0 comments
Oct 18 2008
BigB
Waterford, MI
I am:
  • Casual User
Reviewed at:
Price: $99.99
5.0
    Pros
  • It works
    Cons
  • Took some fine tuning
    Best Uses
  • Control DVR
Pros: It does what it's supposed to. Remote works …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Mar 23 2009
Scott
NH
I am:
  • Power User
Reviewed at:
Price: $99.99
Outstanding!
4.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
"I have a 2.4Ghz modem on one of my computers that sends wireless signals to 2 other computers on my home network. I also have a 2.4Ghz wireless home security monitor system, 3 wireless telephones (5Ghz)on 3 levels in my house, and a 2.4Ghz wireless doorbell that rings in my basement. I was apprehe …"  Read Full Review »
Mar 5 2009
Gina, a TV addict
Fort Wayne, Indiana
I am:
  • Power User
Reviewed at:
Price: $99.99
Good video-but clobbers WiFi, Sound Pops
2.0
    Pros
  • Video Performance
    Cons
  • Sound Quality
    Best Uses
  • Residental
"I needed a TV in the bathroom and this was the best way to run a repeater off of my satellite receiver.
The picture is excellent... The sound has a lot of background noise no matter what I do including turning off every other wireless device in the house. Channel selection and antenna position do …"  Read Full Review »
Sep 15 2009
DC
Central Texas
I am:
  • Power User
Reviewed at:
Price: $99.99
Wipes out WiFi
1.0
    Pros
  • None
    Cons
  • Inconsistent Signal
    Best Uses
  • None
"In addition to being very inconsistant ansd hard to get set up, I found out the hard way that 2.4ghz wipes out WiFi signals. Better off looking for wired solutions. "
Nov 17 2009
Pulling out what hairI have left
Michigan
I am:
  • Casual User
Reviewed at:
Price: $99.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
