Close Login Module
Join
Radio Shack 15-Range Digital Multimeter
#2217
3.0
based on 32 reviews
Ratings Distribution
5 star
7
4 star
7
3 star
4
2 star
7
1 star
7
Category Average
4.1
$19.99
from 1 store
Pros
  • Consistent performance (7)
  • Easy to use (6)
  • Good performance (6)
  • Good value (6)
  • Reliable (6)
  • Versatile (3)
  • Good length (2)
  • Cheap (1)
  • Rugged (1)
  • Sensitive (1)
See less See more
Cons
  • Difficult to configure (2)
  • Wears out quickly (2)
  • Battery con (1)
  • Battery cost (1)
  • Battery not included (1)
  • Case design poor (1)
  • Cords wont fit in case an (1)
  • Cumbersome (1)
  • Expensive battery (1)
  • Hard to find battery (1)
Best Uses
  • Travel (3)
  • Battery testing (1)
  • Carboat (1)
  • Convenience (1)
  • Dorm room (1)
  • Electronics hobby (1)
  • Hobby (1)
  • In the car (1)
  • Low end shop work (1)
  • Military/government (1)
Where to Buy
$19.99
Product Reviews
Last update: Sep 1, 2009
Radio Shack 15-Range Digital Multimeter Reviews
Most helpful positive review
[5 of 6 customers found this review helpful]
Most helpful negative review
[4 of 4 customers found this review helpful]
5.0
Easy to use, good price.
"For my science fair project I tested the voltage of three fruits. This multimeter didn't say 0 V. It gave me hundredths. That's pretty sensitive I would say. Overall, Very good price. Works great!..." Read Full Review »
Dec 13, 2008 by Me
See more positive Radio Shack 15-Range Digital Multimeter reviews
3.0
Great all-purpose multimeter
"This multimeter is great for most hobbyists, DIY-ers, and electricians. It's easy to use, and is accurate. I don't like how the meter itself is molded into the case. The case can also be hard to close since the wires get in the way, and is tricky to open. Also, I had to make a trip back to the store since it requires an obscure battery. Other than that, it works great...." Read Full Review »
Mar 13, 2009 by Bob the electrician
See more negative Radio Shack 15-Range Digital Multimeter reviews
Displaying 1 - 5 of 32 Reviews
Show
Sort by
OK for the price- but . . .
2.0
    Pros
  • None
    Cons
  • Case design poor
  • No battery included
  • Wears Easily
    Best Uses
  • Carboat
"It's an OK VOM for the price, and a good backup for the car / boat. The case is attached to the meter and is an unnecessary appendage as it is cheap and can't easily store the probes & cables.
Neither the pachage or sales staff flagged that it needs a battery that you can't easily find at most st …"  Read Full Review »
Jul 10 2009
Tony the Tiger
'Bama
I am:
  • Casual User
Reviewed at:
Price: $19.99
3.0
    Pros
  • Cheap
  • Easy to use
  • Versatile
    Cons
  • Cumbersome
  • Requires special battery
    Best Uses
  • None
"This multimeter is great for most hobbyists, DIY-ers, and electricians. It's easy to use, and is accurate. I don't like how the meter itself is molded into the case. The case can also be hard to close since the wires get in the way, and is tricky to open. Also, I had to make a trip back to the store …"  Read Full Review »
Mar 13 2009
Bob the electrician
Somewhereville
I am:
  • Enthusiast
Reviewed at:
Price: $19.99
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Sensitive
    Cons
  • None
    Best Uses
  • School
"For my science fair project I tested the voltage of three fruits. This multimeter didn't say 0 V. It gave me hundredths. That's pretty sensitive I would say. Overall, Very good price. Works great! "
Dec 13 2008
Me
Kansas City, Kansas
I am:
  • Casual User
Reviewed at:
Price: $19.99
[1 of 1 customers found this review helpful]
Poor usability
2.0
    Pros
  • None
    Cons
  • None
    Best Uses
  • Dorm Room
"The unit, probes and case are all permanently attached to each other, which is fine except that there isn't enough room in the case to hold the probes and their wires. I gave up trying to repack the probes inside the case and just cut a hole in the side. Now the probes dangle outside but at least I …"  Read Full Review »
Sep 1 2009
El Zagna
Austin, TX
I am:
  • Casual User
Reviewed at:
Price: $19.99
[1 of 2 customers found this review helpful]
4 Years and running
4.0
    Pros
  • Good Length
  • Versatile
    Cons
  • None
    Best Uses
  • Convenience
  • Travel
"I have had this meter for over 4 years now. I use it on and off from hobby to work and I am just replacing my first battery. I have never run in to any issues with this and would recommend it over and over again to anyone. YES, it does require a special battery, but in my opinion well worth it. This …"  Read Full Review »
Sep 21 2007
SLO_life
San Luis Obispo
I am:
  • Professional
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$19.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
