Close Login Module
Join
Radio Shack 12VDC Car Power Adapter Plug with Switch
4.3
based on 3 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
3.9
Pros
  • Reliable (2)
  • Easy to configure (1)
  • Easy to use (1)
  • Good performance (1)
  • Good value (1)
  • Long lasting (1)
  • Versatile (1)
See less See more
Cons
  • Wears out quickly (1)
Best Uses
  • In the car (1)
  • Portable electronics (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 12VDC Car Power Adapter Plug with Switch
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 29, 2009
Radio Shack 12VDC Car Power Adapter Plug with Switch Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Decent but specs are a little inflated.
3.0
    Pros
  • Easy To Configure
  • Versatile
    Cons
  • Wear Easily
    Best Uses
  • In The Car
"I use this to connect a 55W light bulb. It should be able to handle the power draw but... The spring in the tip of the plug is soldered to the metal tip piece. This point tends to overheat, the solder melts and the spring looses it's spring and compresses permanently. It takes time to do this but …"  Read Full Review »
Was this Battery review on the Radio Shack helpful to you?
 Report Abuse  (1)  (0)  0 comments
Sep 18 2007
TAB
Yuma, AZ
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Good Quality
5.0
    Pros
  • Long Lasting
  • Reliable Performance
    Cons
  • NONE
    Best Uses
  • Portable Electronics
"These hold-up very well under less than ideal conditions. "
Jul 29 2009
Matt the IT guy
KY
I am:
  • Quality Oriented
Reviewed at:
Well made, has all the ...
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"Well made, has all the features I was looking for. "
Apr 19 2006
Robert G
NJ
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
$7.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
