Radio Shack 12V/5000mAh Sealed Lead- Acid Rechargable Battery
#591
2.7
based on 15 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
0
2 star
3
1 star
6
Category Average
3.9
$34.99 at RadioShack
Find it at Amazon
Find it at Ebay
$34.99
from 1 store
Pros
  • Reliable (6)
  • Long lasting (3)
  • Charges quickly (2)
  • Easy to use (2)
  • Good performance (2)
  • Exact duplicate (1)
  • Good value (1)
  • Powerful (1)
See less See more
Cons
  • Short life (4)
  • Wrong battery and power (1)
Best Uses
  • Emergency equipment (2)
  • Alarm system (1)
  • Alarm system back up (1)
  • High-end equipment (1)
  • Portable electronics (1)
Provided by RadioShack
This 12V 5000mAh rechargeable lead-acid battery powers many scooters and is the ideal backup power source for your alarm control center.
Specification Description
Model 23-289
Accessory Indicator Yes
Battery Finder Indicator Yes
Battery Type Product
Benefits Can be recharged hundreds of times for long usePowers many scootersAlarm control power backup
Capacity 4000
Capacity UOM mAh
Chemistry Sealed Lead Acid
Country Of Origin United States
Description Header Scooter power, alarm battery backup and more.
Display Catalog Number 23-289
Equivalent to Panasonic LC-R125P, LCR125P, LCR12V5P, Powersonic PS-1250-F1, PS1250F1, RadioShack 960-0460, 960-1213, Union MX12040, Yuasa NP4-12, NP412, NP5-12, NP5
Features Size: 4.09 x 3.54 x 2.75
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 23-289
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 4.09
Product Length 2.75
Product Type 12V
Product Weight 3.8
Product Weight UOM pounds
Product Width 3.54
Rechargeable Yes
Recommended Use Panasonic LCR125P, LCR12V5P, Powersonic PS1250,
Size Specialty
Supported Languages English
Voltage 12
Voltage UOM Volts
Radio Shack 12V/5000mAh Sealed Lead- Acid Rechargable Battery Questions
Questions and Answers
Where to Buy
$34.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: May 4, 2009
Radio Shack 12V/5000mAh Sealed Lead- Acid Rechargable Battery Reviews
Most helpful positive review
Most helpful negative review
[1 of 2 customers found this review helpful]
4.0
excellent purchase
"This battery was a duplicate of an orignal radio shack rechargeable battery for a house alarm system. The alarm system was put in 14 years ago. I was really surprised that Radio shack still carried the exact model, Amp rating, voltage etc. after14 years. I was really surprised that the originall battery lasted 14 years!..." Read Full Review »
May 04, 2009 by jjmonty
See more positive Radio Shack 12V/5000mAh Sealed Lead- Acid Rechargable Battery reviews
1.0
Buy a charger for SLA battery first
"I'm sure this battery would be great if I could find a way to charge it. Radioshack doesn't sell battery chargers for this type of battery. Just something to consider if you want actually use the battery.The battery says not to use an automotive/marine type charger for this battery...." Read Full Review »
Jan 20, 2008 by techie guy
See more negative Radio Shack 12V/5000mAh Sealed Lead- Acid Rechargable Battery reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
excellent purchase
4.0
    Pros
  • Exact duplicate
  • Reliable Performance
    Cons
  • None of the above
    Best Uses
  • Emergency Equipment
  • High-End Equipment
"This battery was a duplicate of an orignal radio shack rechargeable battery for a house alarm system. The alarm system was put in 14 years ago. I was really surprised that Radio shack still carried the exact model, Amp rating, voltage etc. after14 years. I was really surprised that the originall b …"  Read Full Review »
Was this Battery review on the Radio Shack 12V/5000mAh Sealed Lead- Acid Rechargable Battery helpful to you?
May 4 2009
jjmonty
Agoura HIlls, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $34.99
Very nice 5AH battery.
5.0
    Pros
  • Long Lasting
    Cons
  • None
    Best Uses
  • Portable Electronics
"I have three in parrall diode separated on both charging and output side. They have worked well for over 8 years. Two have now failed, one is still going strong.
The failure was terminal corrosion which indicates sealing/outgassing problems. Planning to replace with same. "
Dec 24 2007
Paul
San Jose, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $34.99
1.0
    Pros
  • None Yet
    Cons
  • None yet
    Best Uses
  • alarm system
"I'm sure this battery would be great if I could find a way to charge it. Radioshack doesn't sell battery chargers for this type of battery. Just something to consider if you want actually use the battery.The battery says not to use an automotive/marine type charger for this battery. "
 Report Abuse  (1)  (1)  0 comments
Jan 20 2008
techie guy
Alabaster,AL
Reviewed at:
Price: $34.99
5.0
    Pros
  • Charges Quickly
  • Long Lasting
  • Powerful
    Cons
  • None
    Best Uses
  • None
"This is the third time I've replaced my alarm battery with this type. The previous two
lasted about well over five years. No problems with it and it's cheaped then having the alarm system technician come and replace the battery. "
Sep 5 2007
Tom Cat
Little Rock, AR
I am:
  • Quality Oriented
Reviewed at:
Price: $34.99
Dies out early
2.0
    Pros
  • None
    Cons
  • Short Life
    Best Uses
"Every time I have to replace one of these the life gets shorter-The origional lasted 5 years the second was good for 2 years the last one only lasted 9 months, perhaps the chinese acid is lower quality "
Apr 4 2008
Disappointed
Detroit, MI
I am:
  • Quality Oriented
Reviewed at:
Price: $34.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
