Radio Shack 120VAC 4" Fan
#252
3.8
based on 24 reviews
Ratings Distribution
5 star
8
4 star
11
3 star
1
2 star
0
1 star
4
Category Average
4.3
$24.99 at RadioShack
Find it at Amazon
Find it at Ebay
$24.99
from 1 store
Pros
  • Reliable (15)
  • Easy to install (10)
  • Easy to use (7)
  • Energy efficient (6)
  • Good performance (6)
  • Good value (6)
  • Quiet (4)
  • Build quality (1)
  • Reliability (1)
  • Strong (1)
See less See more
Cons
  • Noisy (9)
  • Unreliable (3)
  • Weak (2)
  • A little noise (1)
  • Intermittent vibration (1)
  • Junk (1)
  • No ac plug on cord (1)
Best Uses
  • Multimedia (5)
  • Gaming (2)
  • Upgrade (2)
  • Cabinet cooling (1)
  • Case/cabinet cooling (1)
  • Cooing for mig welder (1)
  • Enclosed system (1)
  • General application (1)
  • Reef tank (1)
  • Replacement (1)
Provided by RadioShack
Avoid hot spots by spot cooling with this powerful 120VAC 4” cooling fan. It's perfect for home, hobby and various electronic projects.
Specification Description
Model 273-241
Accessory Indicator Yes
Benefits Powerful 65CFM (cubic feet per minute) airflow22 watts
Body Material Multi
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Stay cool.
Display Catalog Number 273-241
Included in the Box 120V AC 4" Fan (1)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 273-241
Operating Temperature UOM ° F
Product Height 1.5
Product Length 4.69
Product Type Standard case fans
Product Width 4.69
Recommended Use Hobbyist
Required to function 115 V AC Power
Supported Languages English
Radio Shack 120VAC 4" Fan Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 15, 2009
Radio Shack 120VAC 4" Fan Reviews
Most helpful positive review
Most helpful negative review
4.0
10+yr service as great exhaust fan
"I installed this in my ranch attic to exhaust the hot air from the utility room below (gas-fired HWH & furnace). Until I installed it, super hot air from the attic would rush into my living space below every Summer. This fan made an appreciable difference to my comfort level and cooling bill as soon as I put it into service! I mounted it atop the fresh-air feed (for combustion) 4" pipe, tied into my gable-ven..." Read Full Review »
May 28, 2009 by Professor Randy in Cincinnati
See more positive Radio Shack 120VAC 4" Fan reviews
3.0
Somewhat noisy fan, no AC plug
"[...].I previously purchased a PQ Fan for my entertainment center which is exceptionally quiet and has an attached two prong plug on the cord for easy installation. They even have an available thermostat, though there are many other plug in thermostats available.This unit is more difficult to install, quite a bit louder though it is less expensive. If you are looking for a quieter option, look at the PQ Fan. ..." Read Full Review »
Jun 17, 2009 by Doc
See more negative Radio Shack 120VAC 4" Fan reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
4.0
    Pros
  • Easy To Install
  • Energy Efficient
  • Quiet
  • Reliable
  • Strong
    Cons
  • None
    Best Uses
  • Upgrade
Until I installed it, super hot air from the attic would rush into my living space below every Summer. This fan made an appreciable difference to my comfort level and cooling bill as …"  Read Full Review »
Was this Computer Fan & Cooling System review on the Radio Shack 120VAC 4" Fan helpful to you?
May 28 2009
Cincinnati, OH
I am:
  • Frequent User
[1 of 1 customers found this review helpful]
HEAVY DUTY RELIABLE FAN
4.0
    Pros
  • Build Quality
  • Easy To Install
  • Reliability
    Cons
  • A little Noisy
    Best Uses
  • Multimedia
  • Reef Tank
"I have used these fans for years in my reef tanks. The tanks have several hundred watts of lighting on them that are on for 12 hours per day. I have used these fans for about 15 years and they last forever. I am not sure if it was the bearings that went out or all of the dust that built up on my …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 15 2009
AaronT
Knoxville, TN
I am:
  • Heavy Duty User
GREAT LITTLE FAN
4.0
    Pros
  • Easy To Install
  • Energy Efficient
  • Reliable
    Cons
  • A LITTLE NOISE
    Best Uses
  • GENERAL APPLICATION
"I USED THIS PRODUCT NOT JUST FOR COOLING DOWN MY ELECTRONIC EQUIPMENT BUT I FOUND ALOT OF OTHER USES FOR THIS FAN LIKE TO DRAW AWAY FUMES AND SMOKE WHEN I WOULD USE MY SOLDERING IRON ( FANTASTIC PERFORMANCE) I MADE A BATHROOM POWERED VENTALATOR FOR MY TRAILER, AND THE LIST GOES ON AND ON WHAT THIS I …"  Read Full Review »
Nov 6 2007
DUCKIE OF CAILIFORNIA
HESPERIA, CA. 92345
I am:
  • Heavy Duty User
Great airflow and quiet
5.0
    Pros
  • Quiet
  • Reliable
    Cons
  • None
    Best Uses
  • Gaming
  • Multimedia
  • Replacement
  • Upgrade
"My use is with an under the desk installation. The desk has a front skirt, which trapped the air under the desk. My computer sits under my desk and the heat built up under the desk and flowed right out in front of me. I cut a hole in the top of the skirt and installed the fan under the desk (with a …"  Read Full Review »
Apr 5 2008
Mark SH
New York
I am:
  • Heavy Duty User
3.0
    Pros
  • None
    Cons
  • Loud
  • No AC plug on cord
    Best Uses
  • Cabinet cooling
"[...].I previously purchased a PQ Fan for my entertainment center which is exceptionally quiet and has an attached two prong plug on the cord for easy installation. They even have an available thermostat, though there are many other plug in thermostats available.This unit is more difficult to insta …"  Read Full Review »
Jun 17 2009
Doc
East Bay, CA
I am:
  • Frequent User
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
