Radio Shack 12-Position Male Interlocking Connector
#1591
3.7
based on 3 reviews
Ratings Distribution
5 star
0
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.1
$2.79 at RadioShack
Find it at Amazon
Find it at Ebay
$2.79
from 1 store
Pros
  • Durable (1)
  • Easy to configure (1)
  • Versatile (1)
See less See more
Cons
  • No extra pins (1)
Best Uses
  • Low current connections (1)
  • Oem mfg (1)
Provided by RadioShack
Polarized to assure correct hookup, this adaptable connector lets you create your own unique plug.
Specification Description
Model 274-232
Accessory Indicator Yes
Benefits Versatile plug fits any cable and prevents accidental start-upsPolarized for correct hookupPins can be soldered or crimped
Body Material Multi
Cable Length Under 1 ft.
Cable Type 12-position
Capacity UOM mAh
Country Of Origin United States
Description Header Theres no going back!
Display Catalog Number 274-232
Enclosure Color White
Features Crimp terminals: 0.093"Contact resistance: 0.0025 ohmMaximum current per circuit: 8 ampsMaximum voltage circuit: 25
Included in the Box 12-Position Interlocking Connector (Male)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 12 Position Male Interlocking Connector
Model 274-232
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Product Diameter 0
Product Height 0
Product Length 0
Product Type 12 position
Product Weight 0
Product Width 0
Supported Languages English
Radio Shack 12-Position Male Interlocking Connector Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 21, 2008
Radio Shack 12-Position Male Interlocking Connector Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Not bad
4.0
    Pros
  • Versatile
    Cons
  • None
    Best Uses
"You can remove the pins, but you need a pin extractor. Radioshack sell the required extractor, you can also find them in kits for automotive applications etc.. For the price they are good connectors. I use them for general apps, also have some inside my race car for engine input's and outputs to th …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack 12-Position Male Interlocking Connector helpful to you?
Mar 5 2008
Just me
Amarillo, Tx
I am:
  • Gearhead
  • Professional
  • Tech
  • Tech Savvy
Buy more than you need
3.0
    Pros
  • Durable
  • Easy To Configure
    Cons
  • No extra pins
    Best Uses
  • OEM mfg
"WARNING: If you need just one, buy three. There are no extra just-in-case pins. If you lose one or make a mistake and place the wrong pin in the opposite mating socket, there is no way to retrieve the pin. Always buy extra. If you need 5, buy 30. "
Jul 6 2007
Soldering Man
Mooresville, NC
I am:
  • Gearhead
  • Practical
  • Professional
  • Tech Savvy
Soldering
4.0
"I put together a circuit using this connecter. When testing the output, I wasn't getting a signal on one of the pins. When tracing it down, the signal stopped at the connector (even though the solder joint looked good). Resoldering that joint fixed the problem.
Conclusion: When soldering, give it p …"  Read Full Review »
Sep 21 2008
Mike
Anderson, IN
I am:
  • Enthusiast
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
