Radio Shack 12-Position European-Style Terminal Strip
#1192
4.7
based on 3 reviews
Ratings Distribution
5 star
2
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$3.69 at RadioShack
Find it at Amazon
Find it at Ebay
$3.69
from 1 store
More Images
Pros
  • Consistent performance (3)
  • Rugged (2)
  • Versatile (2)
  • Better insulation (1)
  • Good length (1)
See less See more
Best Uses
  • Connecting projects (1)
  • Diy projects (1)
  • High-end equipment (1)
  • Making modules (1)
  • Versatile (1)
Provided by RadioShack
This 12-position, Euro-style terminal strip holds 10- to 22-gauge wire and is rated up to 30 amps.
Specification Description
Model 274-677, 274-679
Accessory Indicator Yes
Benefits Rated up to 30 amps600 volts maximum per circuitRecessed-screw design helps prevent accidental contact with terminals
Benefits Rated up to 35 amps600 volts maximum per circuitRecessed-screw design helps prevent accidental contact with terminals
Body Material Multi
Cable Length Under 1 ft.
Cable Type Terminal strip
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Put wires in their place!
Display Catalog Number 274-677
Display Catalog Number 274-679
Enclosure Color Silver
Features 12-position blockHolds 10- to 22-gauge wireEuro-style terminal strip
Features 12-position terminal stripRated up to 35 amps
Included in the Box 12-Position European-Style Terminal Strip
Included in the Box 12-Position European-Style Terminal Strips
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 274-677
Model 274-679
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Offer Disclaimer Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 0.625
Product Length 0.75
Product Type Wire Connectors
Product Width 4.562
Supported Languages English
Radio Shack 12-Position European-Style Terminal Strip Questions
Questions and Answers
Where to Buy
$3.69
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: Nov 12, 2008
Radio Shack 12-Position European-Style Terminal Strip Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Advantages over USA style terminal strip
5.0
    Pros
  • Better insulation
  • Consistent Performance
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • Versitile
"We use these any place we need to join multiple wires -- in sound systems, lighting systems, as AC terminal blocks. These so-called "euro" style are superior to the traditional open screw terminal strip design in that with those the screws are always exposed. The chances of stray wires crossing th …"  Read Full Review »
Open Terminal with exposed screws which are live.
  • Picture of Product
Euro style -- safer; no live parts exposed.
Was this Audio Visual Cable & Connector review on the Radio Shack 12-Position European-Style Terminal Strip helpful to you?
 Report Abuse  (1)  (0)  0 comments
Nov 12 2008
CinemaDude
Brooklyn, NY
I am:
  • Power User
Reviewed at:
Price: $3.69
[2 of 2 customers found this review helpful]
perfect terminal strip
4.0
    Pros
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Making modules
"These are amazingly reliable and easy to use: using a 1.7mm common jeweler's screwdriver, tighten down onto wires. The pressure plates inside assure the best connection for many years to come. There's a reason that they're found in equipment.... They WORK. "
 Report Abuse  (2)  (0)  0 comments
Jul 19 2008
djscrizzle
Colorado Springs, CO
I am:
  • Expirimenter
  • Gearhead
  • Hobbyist
Reviewed at:
Price: $3.69
Cheap and useful
5.0
    Pros
  • Good Length
    Cons
  • None
    Best Uses
  • DIY Projects
"Well, it is just a terminal strip... not much that can go wrong with that, but the unique design is really nice, as is its small size compared to a few other 12 position strips I saw. Not very expensive either... If you are searching for a block for whatever your project may be, this is certainly a …"  Read Full Review »
Sep 9 2007
GRIM.657
Fredericksburg, Texas
I am:
  • Tech Savvy
Reviewed at:
Price: $3.69
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
