Close Login Module
Join
Radio Shack 10k-Ohm Wheel Potentiometer
#2181
3.0
based on 5 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
4
2 star
0
1 star
1
Category Average
4.1
$1.99
from 1 store
Pros
  • Consistent performance (1)
  • Does what it should (1)
  • Size price (1)
  • Versatile (1)
See less See more
Cons
  • Incompatible (2)
  • Cost (1)
  • Inadequate description (1)
  • Lack of pin out diagram (1)
  • No pin-out diagram (1)
  • Pricy (1)
Best Uses
  • Custom project (1)
  • Low voltagecurrent jobs (1)
Where to Buy
$1.99
Product Reviews
Last update: Nov 3, 2009
Radio Shack 10k-Ohm Wheel Potentiometer Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[12 of 12 customers found this review helpful]
Pin diagram (SOLVED- read comments)
3.0
    Pros
  • Size price
    Cons
    Best Uses
  • Custom project
"For those who wish there was more info about wiring up this thing, I got this with a meter and pencil and some deductive reasoning. It was easy once I found the 3 pins that showed 11, 11, and 22K (20% tolerance, ugh) in three combinations-- the two rails have a common endpoint. Of course by that tim …"  Read Full Review »
Dec 8 2008
Hardware Hacker
Ohio
I am:
  • Enthusiast
Reviewed at:
Price: $1.99
[1 of 1 customers found this review helpful]
does what it should
3.0
    Pros
  • Consistent Performance
    Cons
  • Cost
    Best Uses
"I actually used the product many times as a volume attenuator in a homemade acoustic guitar piezo pickup, small speaker setup, and even for various LED (ranging from 4-6 VDC) projects as a dimmer.
This product works as it should and performed great, seems a bit pricey, but that's life sometimes. …"  Read Full Review »
Jun 25 2009
EEstudent
San Luis Obispo, CA
I am:
  • Enthusiast
Reviewed at:
Price: $1.99
works, but no specs or pin-outs
3.0
    Pros
  • None
    Cons
  • no pin-out diagram
    Best Uses
  • None
"If you get this, there are no pin-outs for it, and so you'll have to figure out what pins do what. I don't have them all figured out! Also, the pins are not spaced for a standard breadboard, so you'll have to solder to use it. "
May 2 2008
Dan
Indianapolis
Reviewed at:
Price: $1.99
Hard to use
1.0
    Pros
  • None
    Cons
  • Incompatible
    Best Uses
  • None
"Doesn't fit a standard board.
No pin-out information. "
Oct 4 2008
Jonathan
San Diego,CA
I am:
  • Casual User
Reviewed at:
Price: $1.99
Should work OK
5.0
"Use a ohm meter to find pin out. "
Sep 1 2008
estook
Jamestown,NC
I am:
  • Tech Savvy
Reviewed at:
Price: $1.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
$1.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
