Radio Shack 100K-Ohm Linear-Taper Potentiometer
#1515
3.0
based on 2 reviews
from $2.99
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.1
$2.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Consistent performance (1)
  • Rugged (1)
See less See more
Cons
  • Resistance was bad (1)
Best Uses
Provided by RadioShack
Wattage rating of 0.5W. Tolerance 20%. 6mm shaft. Mounting capabilities in a 5/16”-diameter hole, 1-11/16" long x 1/4" diameter round shaft is easily cut to fit your application.
Specification Description
Model 271-092
Accessory Indicator Yes
Body Material Metal
Capacity UOM mAh
Country Of Origin China
Description Header Your source for component parts.
Display Catalog Number 271-092
Included in the Box 100K-Ohm Linear Taper Potentiometer (1)Nut (1)Washer (1)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Max Operating Temperature 70 Fahrenheit
Min Operating Temperature -55 Fahrenheit
Model 271-092
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° C
Product Disclaimer For projects and replacement. Mount in a 5/16"-diameter hole, include nut and washer. 1 11/16" long x 1/4" diameter round shaft is easily cut to fit y
Product Length 0
Product Type Potentiometers
Supported Languages English
Radio Shack 100K-Ohm Linear-Taper Potentiometer Questions
Questions and Answers
Where to Buy
$2.99
$10 Off Orders Of Orders Over $85 + Free Shipping
Product Reviews
Last update: May 8, 2008
Radio Shack 100K-Ohm Linear-Taper Potentiometer Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Poor Performance from a Simple Product
1.0
    Pros
  • None
    Cons
    Best Uses
  • None
"The potentiometer did not change its resistance for the first 1/3rd of its rotation. This caused a "wild goose chase" to find what was wrong with the circuit when it was just defective pots. By the way, we used (2) in the assembly. They both had the same defect. Normally I would consider the bra …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack 100K-Ohm Linear-Taper Potentiometer helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jan 4 2008
Professional reviewer
Chicago, IL
I am:
  • Professional
Reviewed at:
Price: $2.99
worked fine
5.0
    Pros
  • Consistent Performance
  • Rugged
    Cons
  • None
    Best Uses
  • None
"I bought one of these variable resistors and it worked fine. The resistance increased and decresaed nomally when rotated back and fourth. "
May 8 2008
Jim
I am:
  • Tech Savvy
Reviewed at:
Price: $2.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
