Close Login Module
Join
Radio Shack 1/8" Stereo Phone Plug (2-Pack)
#2176
2.3
based on 8 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
1
2 star
1
1 star
4
Category Average
4.1
$3.99
from 1 store
Pros
  • Cheap (1)
  • Consistent performance (1)
  • Good length (1)
  • Skill needed (1)
  • Think b 4 u try install (1)
  • Versatile (1)
  • Works (1)
See less See more
Cons
  • Wears out quickly (4)
  • Inconsistent signal (3)
  • Cheap (1)
  • Constructed poorly (1)
  • Flimsy (1)
  • Poor quality (1)
  • Weak terminal insulators (1)
Best Uses
  • Broken items (1)
  • Dorm room (1)
  • High-end equipment (1)
  • Home projects (1)
Where to Buy
$3.99
Product Reviews
Last update: Jul 21, 2009
Radio Shack 1/8" Stereo Phone Plug (2-Pack) Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
Use your head!!!
4.0
    Pros
  • Consistent Performance
  • Versatile
  • Works
    Cons
  • Cheap
  • Wears Easily
    Best Uses
  • Broken Items
  • Dorm Room
  • High-End Equipment
"This was my first time soldering and my friend and I got my Sony's to work on the first try. Headphones sound good as new.
Couple notes for you geniuses out there.
1.) There is insulation on the audio wires, burn it off with the solder iron otherwise you can't make a connection. This can take …"  Read Full Review »
Feb 17 2009
Matt
Upper Nowhere, NY
I am:
  • Enthusiast
Reviewed at:
Price: $3.99
In a 2 pack for a reason !!!
3.0
    Pros
  • Skill needed
  • Think B 4 U Try Install
    Cons
    Best Uses
  • home projects
"Audio Patch and Headphone Extention Cables: I find this product works fine, but be careful not to subject plugs to pulls and angular tugs (remember, plastic breaks easily)
When assembling plan your work, use a good pencil iron and use heat sparingly w/.062 solder... the first time. Damage will occ …"  Read Full Review »
May 22 2009
Retired Professional
Memphis, TN
I am:
  • Enthusiast
Reviewed at:
Price: $3.99
Complete Garbage
1.0
    Pros
  • None
    Cons
  • Constructed Poorly
  • Inconsistent Signal
  • Wears Easily
    Best Uses
  • None
"Very shoddy construction. White plastic insulating material between terminals melts after applying only modest heat to achieve a good solder joint.
Flimsy and floppy to handle while soldering.
The good ones have phenolic, fiber board, or teflon insulators. These seem to be a cheap white plastic …"  Read Full Review »
Jul 1 2009
ad7bz
Syracuse, UT
I am:
  • Enthusiast
Reviewed at:
Price: $3.99
Not your usual quality component
1.0
    Pros
  • None
    Cons
  • Low Quality
    Best Uses
  • None
"It used to be that 15-25W soldering iron was pretty much standard for repair work, now you need something smaller to not burn the insulator separating the connecting rings and tip. Sand paper the connecting pins to help with solder adhesion and pre-tin the wires. Have someone hold the tip with a …"  Read Full Review »
Jul 21 2009
old school electronics engineer
West Milford, NJ
I am:
  • Power User
Reviewed at:
Price: $3.99
[1 of 1 customers found this review helpful]
Piece of junk
1.0
"I bought a pack of these to repair a pair of broken Sennheiser PMX 60s, and they failed very easily with incredibly inferior plastic interior construction. The terminals lost contact with the plug sections, seemingly just by sensing a soldering iron within a foot. If you plan on doing any sort of so …"  Read Full Review »
Oct 5 2008
Legoguy
Gurnee, IL
I am:
  • Power User
Reviewed at:
Price: $3.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$3.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
