Radio Shack 1/8" Stereo Jack to 3/32" Stereo Plug Adapter
#1956
3.5
based on 12 reviews
Ratings Distribution
5 star
3
4 star
5
3 star
1
2 star
1
1 star
2
Category Average
4.1
$5.99 at RadioShack
Find it at Amazon
Find it at Ebay
$5.99
from 1 store
More Images
Pros
  • Consistent performance (3)
  • Easy to use (3)
  • Reliable (3)
  • Good performance (2)
  • Good value (2)
  • Versatile (2)
  • Fits jacks as described (1)
  • Good length (1)
  • Rugged (1)
  • Works (1)
See less See more
Cons
  • Bulky (2)
  • Could be shorter (1)
  • Incompatible (1)
  • Is too long (1)
  • Wears out quickly (1)
Best Uses
  • On the go people (1)
  • Travel (1)
Provided by RadioShack
This stereo-to-mono inline audio adapter accepts a 1/8" stereo plug and fits a 3/32" mono jack.
Specification Description
Model 274-0381, 274-373
Accessory Indicator Yes
Benefits Accepts 1/8" stereo plugFits 3/32" mono jackKnurled metal housing
Benefits Accepts 1/8" stereo plugFits 3/32" stereo jackLets you use lightweight stereo headphones with a PDA or small audio device
Body Material Metal
Body Material Plastic
Cable Length Under 1 ft.
Cable Type Audio adapters
Capacity UOM mAh
Country Of Origin Japan
Country Of Origin Taiwan
Description Header Adapt lightweight headphones for your PDA.
Description Header Highly adaptable.
Display Catalog Number 274-373
Display Catalog Number 274-381
Enclosure Color BLACK
Enclosure Color SILVER
Included in the Box Inline Adapter
Inputs 1 x Phone 3/32"(Phone Plug)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Max Altitude Operating UOM Feet
Model 274-0381
Model 274-373
Offer Disclaimer (Pricing and availability may vary outside the contiguous 48 United States.)
Operating Temperature UOM ° F
Outputs 1 x Phone 1/8"(Phone Jack)
Outputs 1 x Phone 1/8"(Stereo Phone Jack), 1 x Phone 3/32"(Stereo Phone Plug)
Product Dimensions UOM inches
Product Length 1.375
Product Type Audio adapters
Product Width 0.375
Supported Languages English
Radio Shack 1/8" Stereo Jack to 3/32" Stereo Plug Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 9, 2009
Radio Shack 1/8" Stereo Jack to 3/32" Stereo Plug Adapter Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
5.0
This is a GREAT product ...
"This is a GREAT product to buy in order to use normal headphones or car tape adapters (or other divices with an 1/8" audio plug) with a cell phone that has a built-in MP3 player such as the i870 from NEXTEL...." Read Full Review »
Sep 30, 2006 by BA M
See more positive Radio Shack 1/8" Stereo Jack to 3/32" Stereo Plug Adapter reviews
2.0
i930 compatible
"I've been trying to use my i930 phone as an mp3 player connected to my car reciever. Since the i930 is mono and the reciever is stereo, this plug and a 1/8" stereo wire is required. after 3 visits to 3 different Radioshacks, 3 different compatability guaratantees from clerks and 3 different fittings later, I finally found this. The only problem is you cannot insert the plug all the way, it will not work. Thr..." Read Full Review »
Jan 02, 2008 by james p gardner
See more negative Radio Shack 1/8" Stereo Jack to 3/32" Stereo Plug Adapter reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
5.0
    Pros
  • Easy to use
  • Good performance
  • Good Value
  • Reliable
    Cons
  • None
    Best Uses
  • None
"This is a GREAT product to buy in order to use normal headphones or car tape adapters (or other divices with an 1/8" audio plug) with a cell phone that has a built-in MP3 player such as the i870 from NEXTEL. "
Was this Audio Visual Cable & Connector review on the Radio Shack 1/8" Stereo Jack to 3/32" Stereo Plug Adapter helpful to you?
 Report Abuse  (3)  (0)  0 comments
Sep 30 2006
BA M
Dearborn Michigan
i930 compatible
2.0
"I've been trying to use my i930 phone as an mp3 player connected to my car reciever. Since the i930 is mono and the reciever is stereo, this plug and a 1/8" stereo wire is required. after 3 visits to 3 different Radioshacks, 3 different compatability guaratantees from clerks and 3 different fittin …"  Read Full Review »
Jan 2 2008
james p gardner
naples, fl
I am:
  • Tech Savvy
[2 of 2 customers found this review helpful]
Great add-on for TREO's
5.0
    Pros
  • Consistent Performance
    Cons
  • None
    Best Uses
  • On The Go People
  • Travel
"It works perfectly for the Palm Treo 755p. The only negative aspect is the design of the product. It's a bit longer than I would like it, but otherwise a great functioning adapter. "
 Report Abuse  (2)  (0)  0 comments
Jul 11 2007
Roger
San Diego, Ca
I am:
  • Professional
This works with my Palm Centro
4.0
    Pros
  • Works
    Cons
  • None
    Best Uses
  • None
"This works with my Palm Centro. Had to trim off some of the outer plastic to get it to go in all the way (phone design issue). It sticks out a little far, but it works. "
Mar 6 2008
Jim
Chicago, IL
I am:
  • Tech Savvy
Works well for purpose. Big for mobility
4.0
    Pros
  • Good Length
  • Versatile
    Cons
  • Bulky
    Best Uses
  • None
"Works well to convert my cell phone's audio jack to standard headphones for mp3 player, but too large to keep plugged in while mobile. "
Feb 21 2009
Dr. Drew
Muncie, IN
I am:
  • Power User
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
