Radio Shack 1/8" Mini Stereo Phone Plug
#2171
3.8
based on 13 reviews
from $3.99
Ratings Distribution
5 star
5
4 star
5
3 star
1
2 star
0
1 star
2
Category Average
4.1
$3.99 at RadioShack
Find it at Amazon
Find it at Ebay
Pros
  • Rugged (6)
  • Versatile (6)
  • Consistent performance (4)
  • Good length (4)
  • Awesome (1)
  • Great part (1)
  • Well built / quality construction (1)
See less See more
Cons
  • No instructions (3)
  • Confusing at first (1)
  • Heavy / bulky (1)
  • Instructions lacking (1)
Best Uses
  • High-end equipment (3)
  • Travel (2)
  • Headphone repair (1)
  • Repairs (1)
Provided by RadioShack
Make a solid audio connection with this mini phone plug.
Specification Description
Model 274-869
Benefits Corrosion-resistantProvides a stronger signal
Body Material Metal
Cable Length Under 1 ft.
Cable Type Phone plugs & jacks
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Fast and simple connections.
Display Catalog Number 274-869
Enclosure Color Gold
End Product Indicator Yes
Features Stereo 3-conductor1/8" solderless gold-plated
Included in the Box 1/8" Mini stereo plug with gold plating
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 274-869
Operating Temperature UOM ° F
Product Diameter 0.37
Product Dimensions UOM inches
Product Length 2.11
Product Type Phone plugs & jacks
Product Weight 0.02
Product Weight UOM pounds
Supported Languages English
Radio Shack 1/8" Mini Stereo Phone Plug Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 3, 2009
Radio Shack 1/8" Mini Stereo Phone Plug Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
fixed my 100 dolar headphones!
"this fixed a nice set of etymotic headphones. earbud headphones come with such thin wires/cables that it's so easy to rip em apart. i was accidentally standing on a part of the wire when i stood up, ripping the wire apart. The funny thing is that the earbuds were still in my ears after they ripped. don't let the other bad reviews fool you about this being a bad product because of a lack of instructions. ther..." Read Full Review »
Jan 15, 2008 by a nonomous hack
See more positive Radio Shack 1/8" Mini Stereo Phone Plug reviews
3.0
C'mon, geeks!
"I needed a long RCA-to-stereo mini cable. Oddly, there is no such thing, & using adapters created a noisy signal. I agree there needs to be SOME documentation here to explain where each terminal connects on the jack--tip, sleeve, etc. There's zero reason for that to be a trial & error process, "general part" or not...." Read Full Review »
Nov 03, 2009 by whatever
See more negative Radio Shack 1/8" Mini Stereo Phone Plug reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
5.0
    Pros
  • Versatile
    Cons
  • None
    Best Uses
  • None
"this fixed a nice set of etymotic headphones. earbud headphones come with such thin wires/cables that it's so easy to rip em apart. i was accidentally standing on a part of the wire when i stood up, ripping the wire apart. The funny thing is that the earbuds were still in my ears after they rippe …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the Radio Shack 1/8" Mini Stereo Phone Plug helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jan 15 2008
a nonomous hack
pullman, wa
[1 of 1 customers found this review helpful]
Very good product
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Travel
"This product does its job perfectly. I got a pair of Cobra microTALK Li7599-2WX EVP Radios and a Handheld Clip-On Speaker/Microphone to go with them. Bad news was the plug on the Microphone wasn't the same one as the radios. This little plug is the solution to all of your problems ;). As for the ot …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 31 2007
Jared Thomson
Albion, NY
I am:
  • Gearhead
  • Professional
  • Tech Savvy
Okay with no instructions..
4.0
    Pros
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • None
"It is a trial/error process, but most enthusiasts enjoy tinkering and learning. Definitely pull your wire throught the spring, plastic sheath and the screw-on connector before attaching wires.
The long gold wire is the ground and should go to longest end of three piece interior connectors, red the …"  Read Full Review »
Sep 19 2009
Tricia
Tampa, FL
I am:
  • Enthusiast
C'mon, geeks!
3.0
I agree there needs to be SOME documentation here to explain where each terminal connects on the jack--tip, sleeve, etc. There's zero reason for that to be a trial & error process, "g …"  Read Full Review »
Nov 3 2009
whatever
Truckee, CA
I am:
  • Casual User
Works like a [...] miracle.
5.0
    Pros
  • Awesome
  • Good Length
    Cons
  • Confusing at First
    Best Uses
  • Headphone Repair
"The product worked like a [...] miracle! The only possible problem is inexperience. I used this to repair my Bose Around-ear headphones, and it couldn't have worked better! To all those out there who need help figuring out how to do that though, Screw the gold/copper wires into the long screw hole, …"  Read Full Review »
Aug 24 2009
FullOfWinAndGod
Portland, Oregon
I am:
  • Enthusiast
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
