Radio Shack 1/4" mono Panel-Mount Audio Jack (2-Pack)
#2022
3.4
based on 7 reviews
Ratings Distribution
5 star
3
4 star
1
3 star
1
2 star
0
1 star
2
Category Average
4.1
$2.99 at RadioShack
Find it at Amazon
Find it at Ebay
$2.99
from 1 store
More Images
Pros
  • Rugged (5)
  • Consistent performance (4)
  • Good length (3)
  • Versatile (3)
See less See more
Cons
  • Incompatible (1)
  • No diagram on package (1)
  • No label (1)
  • No label on pins (1)
  • No tinning on pins (1)
Best Uses
  • High-end equipment (2)
  • Guitar equipment (1)
Provided by RadioShack
This open-frame, closed-circuit panel-mount jack is perfect for various audio/video projects.
Specification Description
Model 1/4" Open-frame open-circuit panel mount, 274-255
Accessory Indicator Yes
Benefits 1/4"-diameter2-conductor jack
Benefits Panel-mountOpen circuitPackage of 2
Body Material Metal
Cable Length Under 1 ft.
Cable Type Phone plugs & jacks
Capacity UOM mAh
Country Of Origin China
Description Header A pair of jacks.
Description Header Make the connection.
Display Catalog Number 274-252
Display Catalog Number 274-255
Enclosure Color Silver
Features Nickel platedSolder terminalsPack of 2
Included in the Box 1/4 Inch Open-frame close-circuit panel mount (2)
Included in the Box 1/4" Open-frame open-circuit panel mount (2)
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 1/4 Open-frame open-circuit panel mount
Model 274-255
Model Panel Mount
Operating Temperature UOM ° F
Product Diameter 0
Product Height 0
Product Length 0
Product Type Phone plugs & jacks
Product Weight 0
Product Width 0
Supported Languages English
Radio Shack 1/4" mono Panel-Mount Audio Jack (2-Pack) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 25, 2009
Radio Shack 1/4" mono Panel-Mount Audio Jack (2-Pack) Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
Good product
4.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • No label
    Best Uses
  • Guitar equipment
  • High-End Equipment
"Great product. Only lacking labels, but nothing a multi meter can't solve. Oh yeah, for those who can't use this product because of the lack of a diagram or labels, maybe you shouldn't be working with electronics or at least learn basics and how to use a D.V.O.M. first. "
Was this Audio Visual Cable & Connector review on the Radio Shack 1/4" mono Panel-Mount Audio Jack (2-Pack) helpful to you?
Aug 3 2009
coolchris
Phoenix , AZ
I am:
  • Enthusiast
Great product for the price
5.0
    Pros
  • Good Length
  • Rugged
    Cons
  • None
    Best Uses
  • None
"I bought several of these 1/4" jacks from Radio Shack for a project several years ago and they work fine. I recently bought some cheaper ones at wholesale store and they are not as good. These jacks have a quality nickle plating and a good sturdy construction. The price is about 25% less than some …"  Read Full Review »
Jan 28 2009
Zooman22
Dallas, TX
I am:
  • Enthusiast
[1 of 1 customers found this review helpful]
I wouldn't buy this item again
1.0
    Pros
  • None
    Cons
  • No label on pins
    Best Uses
  • Nothing
"I would use this product if Radio Shack could tell me the pin designations, but no help there. I used to be able to get some help from Radio Shack but I guess they want to be a cellphone store instead of an electronics store. Too bad I used to do a lot of business with them but I guess not anymore. "
 Report Abuse  (1)  (0)  0 comments
May 8 2009
Mr. Hershey
Savannah, Mo
I am:
  • Enthusiast
Simple - Works Great
5.0
    Pros
  • Rugged
    Cons
  • None
    Best Uses
  • None
"The other reviewer was writing about a different product. I'm using these "jacks" on custom speaker cabinets for musical instruments. Works great, very rugged, will probably never wear out.
The company I work for have been using these for 25 years on life support equipment as a data port. Never …"  Read Full Review »
Jan 15 2009
Purchasing Manager
Salt Lake City
I am:
  • Power User
Great Product
5.0
    Pros
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • None
"I have used these sockets on various projects. They are rugged, inexpensive. As far as pinout diagrams; not needed. You can see where the pins connect to the contacts. "
Jun 5 2009
Jon
Conway, Arkansas
I am:
  • Casual User
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
