Quantaray 10.4-inch Digital Frame with Remote Control (Rosewood)
2.0
based on 11 reviews
from
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
1
1 star
7
Category Average
3.7
More Images
Pros
  • Attractive design (7)
  • Clear image (3)
  • Easy to use (2)
  • Quality construction (2)
  • Aspect ratio (1)
See less See more
Cons
  • Difficult to use (3)
  • Blurry image (2)
  • Blurry images (1)
  • Flimsy (1)
  • Need memory card (1)
  • No long display option (1)
  • No memory (1)
  • Poor instructions (1)
  • Screen did not work (1)
  • Very limited function (1)
Best Uses
  • Desk (3)
  • Digital photos (3)
  • Home decor (3)
  • Don't use this (1)
  • Gift not keep (1)
Provided by WolfCamera.com
  • 10.4-inch TFT-LCD Display
  • Beautiful Rosewood look Frame
  • SD, MMC, Memory Stick and Compact Flash Memory Cards Compatible
  • Easy Remote Control Operation
  • Automatic Slide Show
  • Variable Image Display Intervals
  • Play JPEG, MPEG Movies or MP3 Music
  • Built-in Speakers
  • Adjustable Video Settings
  • Multi-language Support
Quantaray 10.4-inch Digital Frame with Remote Control (Rosewood) Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 10.4-inch Digital Frame with Remote Control (Rosewood)
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 4, 2009
Quantaray 10.4-inch Digital Frame with Remote Control (Rosewood) Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Very Satisfied
"Very good product. I recently bought this one. I also own a Kodak frame. I think these are the two best frames on the market. The frame itself is attractive - many others are cheap looking. The Quantaray picture quality is better than many others - contrast, sharpness, color rendition are all very good. Additionally, the shape of many frames now is widescreen. The Quantaray has more traditional dimensions..." Read Full Review »
Dec 03, 2007 by john
See more positive Quantaray 10.4-inch Digital Frame with Remote Control (Rosewood) reviews
2.0
not as good as others out there
"I planned to use this myself, bought it set it up and was happy. However... it didn't last long! I went to a friend's house with another brand that these guys are selling called Portable something. I couldn't find it in the store when i got mine. anyway...[...] the Portable one had a better manual...it has memory inside it which means you can save files onto the frame and take your card out and use it again...it..." Read Full Review »
Dec 09, 2007 by kempo dan
See more negative Quantaray 10.4-inch Digital Frame with Remote Control (Rosewood) reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
Very Satisfied
5.0
    Pros
  • Attractive Design
  • Clear Image
  • Easy To Use
  • Quality Construction
    Cons
    Best Uses
  • Desk
  • Digital Photos
  • Home Decor
"Very good product. I recently bought this one. I also own a Kodak frame. I think these are the two best frames on the market. The frame itself is attractive - many others are cheap looking. The Quantaray picture quality is better than many others - contrast, sharpness, color rendition are all v …"  Read Full Review »
Was this Digital Picture Frame review on the Quantaray 10.4-inch Digital Frame with Remote Control (Rosewood) helpful to you?
 Report Abuse  (2)  (0)  0 comments
Dec 3 2007
john
Pennsylvania
I am:
  • Quality Oriented
Reviewed at:
2.0
    Pros
  • Attractive Design
  • Easy To Use
    Cons
  • No memory
    Best Uses
  • gift not keep
"I planned to use this myself, bought it set it up and was happy. However... it didn't last long! I went to a friend's house with another brand that these guys are selling called Portable something. I couldn't find it in the store when i got mine. anyway...[...] the Portable one had a better manual.. …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 9 2007
kempo dan
windy city
I am:
  • Quality Oriented
Reviewed at:
Great aspect ratio, picture, and w/USB
4.0
    Pros
  • Aspect ratio
  • Attractive Design
  • Clear Image
    Cons
  • Need memory card
    Best Uses
  • Desk
  • Digital Photos
  • Home Decor
"Most cameras do not take letterbox size pix. This frame has an excellent aspect ratio that fits and frames without modification almost all digital pictures. The pictures are sharp with higher resolution. And you can use a USB jump drive as well as camera card for your photos. Only negative is no …"  Read Full Review »
Feb 24 2008
Ron
Chicago
I am:
  • Quality Oriented
Reviewed at:
Looks good wish it worked well
1.0
    Pros
  • Attractive Design
    Cons
  • Hard To Use
    Best Uses
  • None
"This frame is worthless.
It Wont read supported cards.
The on board menu freezes.
Only 3 buttons on the remote would get any response from the unit.
Im returning it. "
Nov 30 2007
Picture Hunter
DC
I am:
  • Quality Oriented
Reviewed at:
Don't waste your $
1.0
    Pros
  • None
    Cons
  • Blurry Image
  • Flimsy Construction
    Best Uses
  • None
"I purchased the product as a Christmas gift. I could not get the unit to power up, so I returned it for repair under warranty, as the 30-day return for refund period had expired. [...]the unit came back, and I was able to get it working. The picture quality is mediocre, probably due to the low sc …"  Read Full Review »
Feb 23 2008
Kins
Leesburg, VA
I am:
  • Value Oriented
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
