QSC RMX2450 Power Amplifier
#85
4.8
based on 9 reviews
Ratings Distribution
5 star
7
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.3
Low Price:
$558.99 at Overstock.com
 Trusted:
$599.95 at B&H Photo Video
Find it at Amazon
$558.99 - $699.99
from 8 stores
More Images
Pros
  • Great sound quality (10)
  • Durable (7)
  • Easy setup (7)
  • Good power output (7)
  • Accurate controls (5)
  • Compact (1)
  • Looks great (1)
See less See more
Cons
  • Heavy / bulky (3)
  • Its great (1)
  • Weight (1)
Best Uses
  • Large rooms (7)
  • Audiophiles (3)
  • Basic systems (3)
  • Smaller rooms / apartments (3)
  • Entertainment (1)
  • Good speakers (1)
  • Home (1)
  • Home theater (1)
  • Live sound (1)
  • Pro audio / dj / mixing (1)
Provided by Sam Ash
The RMX Series amplifiers give you clean, dynamic power with the legendary QSC sound quality and reliability that pros depend on. The RMX Series deliver unmatched performance at a new breakthrough price. The power supply is the heart of an amplifier, converting raw AC power from the wall to clean DC for the audio circuitry. The RMX uses a powerful high-current toroidal transformer and ample filter capacitance to ensure generous energy reserves. This makes a critical difference in sound quality, allowing the amp to effortlessly punch out high level transients, even when driving abusive 2-ohm speaker loads. RMX amplifiers deliver true studio-quality sound. A full complementary output circuit using the highest-grade linear output devices delivers ultra-low distortion (<0.05% THD) & a ruler-flat frequency response. SMT (Surface Mount Technology) triples small-signal component density, enabling us to pack up to 2400 watts of power in a chassis only 2 rack spaces & less than 16" deep. And unlike other designs, RMX output devices are direct-mounted to the heat sink for optimum thermal coupling & cooling. The RMX Series is packed full of professional features that increase performance and flexibility: Independent defeatable clip limiters reduce distortion without sacrificing peak performance. Selectable low-frequency filters boost system response, protect speakers and ensure low-end tightness by more precisely matching the amplifier's range to the loudspeakers. Barrier strip, XLR and 1/4" balanced inputs plus Speakon and binding post outputs provide easy connections. Low-noise variable speed fans with rear-to-front air flow keep amplifiers and racks cool. With over 30 years of building amplifiers for the largest touring companies and venues around the world, you can count on QSC's reputation for designing the most reliable amps available. The RMX-2450 delivers 500 watts @ 8 ohms, 750 watts @ 4 ohms, 1200 watts @ 2 ohms and 1500 watts bridge mono (8 ohms).
Specification Description
Model QRMX2450X, QSC-RMX2450, RMX2450
UPC 684284003720
Audio Connections Barrier strip, XLR and 1/4 in. balanced inputs plus Speakon and binding post outputs
Damping Greater than 300 at 8 ohms
Dimensions 19 x 15.9 x 3.5
Distortion Less than 0.02%
Fan Yes
Indicators LED
Model RMX2450 Power Amplifier
Power Output 500W/750W/1200W/1500W
Power Output (8/4/2 ohms/Bridged Mono) 500W/750W/1200W/1500W
Power Output (@ 8ohms) 401 to 550
Product Weight 44.5
Rear Air Intake Yes
Sensitivity 1.23V (+4.0 dBu)
Series RMX Series
Signal to Noise Ratio 100 dB
Voltage 7A 120V
QSC RMX2450 Power Amplifier Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Feb 19, 2009
QSC RMX2450 Power Amplifier Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Recommended to anyone with the budget
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Larger Rooms
"I use this powering two 15" JBLs for a 40x25 foot room. This amp is perfect, runs cool, easy to setup, well-explained features written out in the manual with exactly what you want for your application. This is not just for Professionals!
One of the best purchase decisions in the whole audio sys …"  Read Full Review »
In the rack
In the rack
  • Picture of Product
  • Using Product
Was this Amplifier, Receiver & Equalizer review on the QSC RMX2450 Power Amplifier helpful to you?
Apr 30 2008
Munch
Santa Barbara, CA
I am:
  • Tech Savvy
Reviewed at:
This Power amp is Awesome.
4.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • Heavy
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
"I had a pair of these amps and was sad the day I let them go. They have great power and great amount of usability for any purpose. On top of that they are inexpensive and for the price still put out great clean sound. They're also crazy durable.
Two of these in a rack will both break your rack an …"  Read Full Review »
Dec 19 2007
Yives
Littleton, CO
I am:
  • Mobile DJ
  • Practical
  • Professional
So much Good Power on a Good Price
5.0
    Pros
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • Heavy
    Best Uses
  • Good Speakers
"I use this with Cerwin vegas. I have this amp for 3 years. my speakers nor my Amp have gone out. Im a Streat Dj For my Spanish station for the southern Cali. and let me tell you this bumps for out doors. But make sure you have good speakers, because they are freaken powerful. good price for this am …"  Read Full Review »
Mar 24 2008
Mario Pera
Santa Ana,CA
I am:
  • Professional
Qsc Is The Best
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • Kind Of Heavy
    Best Uses
  • Larger Rooms
  • Smaller Rooms
"I use this amp to power two cerwin vega el36b subs in bridge mono this amp laughs as it pumps the power out these subs hit hard with this setup "
Nov 25 2008
Dj Jammin John
Chicago,Illinois
I am:
  • DJ
  • Professional
BEST AMP BEST POWER
5.0
    Pros
  • Accurate Controls
  • Clean Sound
  • Durable
  • Easy To Set Up
  • Good Power
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"Qsc keep up the good work and tech suport,this is why I got this amp. Service is hard to find this day and time "
Nov 24 2008
Boogie boy, Richard
SAVANNAH GA. The dirty south
I am:
  • Audiophile
  • Musically Inclined
  • Practical
  • Professional
  • Tech Savvy
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
