QSC HPR153i 15-In 3-Way Powered Speaker *
#290
4.6
based on 5 reviews
from $1,199.99
Ratings Distribution
5 star
3
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Great sound quality (8)
  • Attractive design (5)
  • Easy to connect (5)
  • Powerful (4)
  • Great clarity (1)
See less See more
Cons
  • Heavy / bulky (3)
  • A bit flat on low end (1)
  • Kind of flat on low end (1)
Best Uses
  • Basic systems (3)
  • Large rooms (2)
  • Pro audio / dj / mixing (2)
  • Audiophiles (1)
  • Outdoors (1)
  • Small to medium club (1)
Provided by PSSL.com - ProSound and Stage Lighting
QSC HPR153i 15-In 3-Way Powered SpeakerThe new HPR Series offers performers the power, technology and legendary reliability of QSC amplification combined with the simplicity and convenience of powered loudspeaker systems. Whether your application is vocal reinforcement, dance music or full-tilt rock and roll sound, there's an HPR speaker configuration for you. The HPR153F 3-way loudspeaker is a great choice when the warmth, clarity and projection of a horn loaded, cone midrange system is desired. The 15" driver and larger enclosure volume provide extension down to 38 Hz making the HPR153F well suited for reinforcement of music with lots of low frequency content. Mids are handled by a 6" cone driver that seamlessly covers the critical vocal region. A 1.4" (diaphragm) compression driver delivers brilliant top end response. The 600 watt (400 LF / 100 MF / 100 HF) power module includes a 100 Hz high-pass filter (HPF) for use in subwoofer-equipped systems.Specifications:Configuration: 15" 3-way15" cone transducer with 3" voice coil6.5" horn loaded mid-range1.4" diaphragm compression driverFrequency Response (-6 dB): 42 Hz - 19 kHzFrequency Range (-10 dB): 38 Hz - 20 kHzNominal coverage, -6 dB 90? x 40?Maximum SPL (1 meter): 133 dB peakPower output: 400W LF Class H, 100W MF Class AB+B, 100W HF Class AB+BInput impedance: 22k balanced, 11k unbalancedControls: Gain, Low-cut filter, Front LED On/Off, Power, Circuit breakerIndicators: Power, Signal, LimitCooling: ConvectionAmplifier protection: Thermal and output power limitingCurrent consumption at 120 VAC (1/8 power EIA noise): 1.8AEnclosure: Painted Birch plywoodFinish: Black textured paintGrille: Powder coated 16 gauge steelConnectors: Balanced female XLR line level input, Balanced male XLR full range line level outSize: 44.75" H x 19" W x 18" DWeight: 118 lbs.Why choose powered loudspeakers?:The powered speaker has become a staple for mobile DJs, musicians and AV professionals alike. The simplicity and scalability of these systems is the big draw. After all, what could be easier than just connecting the output of your DJ or live sound mixer directly to the speaker and turning everything on? For those who have been reluctant to join the powered speaker party because you felt that powered speaker amplification fell short of rack-mount amp quality, you are officially out of excuses.Why choose QSC's HPR Series?:There's a QSC amplifier inside each HPR! Now you can get the legendary performance and reliability of QSC's rack mount amplifiers built into a powered loudspeaker. The power module is designed with the same top-quality components and rigorous standards you expect from any QSC amplifier. QSC is regarded as one of the leading amplifier manufacturers in the world. We have over 35 years experience making professional-grade amplifiers. When you buy an HPR Series powered loudspeaker, you know it is backed by the QSC quality and reliability you've come to expect.Many powered speaker amplifier modules use low-cost, consumer-grade "chip amps" to decrease costs and simplify design. The HPR Series features a professional, discrete component design, hardened to withstand abuse and engineered to deliver the best possible performance even when pushed to the limit.
QSC HPR153i 15-In 3-Way Powered Speaker * Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 23, 2009
QSC HPR153i 15-In 3-Way Powered Speaker * Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
QSC HPR153I sound review
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
    Cons
  • Heavy
    Best Uses
  • Basic Systems
  • Outdoors
"Here's a video doing a sound test of the HPR153I from QSC Audio. "
QSC HPR153I Sound Demo HD
  • Demo
  • Sound
  • QSC
  • HD
  • HPR153I
Was this Speaker & Subwoofer review on the QSC HPR153i 15-In 3-Way Powered Speaker * helpful to you?
Apr 21 2009
mike71flores
Houston, Tx
I am:
  • Audiophile
  • Tech Savvy
Hard to beat...
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • Heavy but worth it
    Best Uses
  • Small to Medium Club
"Bought these for a Mobil rig and yes as others have stated they are very heavy. However the sound these cabs produce all alone let alone with the 18in sub I have of the same series it is worth the work loading and unloading. As it turns out I am now using them in a club full time. 5 hours of solid d …"  Read Full Review »
Aug 23 2009
DJ Tank
Albany, OR
I am:
  • Tech Savvy
This is a pro speaker at a Djs price
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
    Best Uses
  • Basic Systems
  • DJ top boxes
  • Larger Rooms
"I added these speakers to my existing system and the whole thing got new life. These speakers have that professional sound that us DJs always look for. Now i'm looking to replace all of my top boxes and go exclusively with the QSC HPR53is. I love the quick connection time. "
Jun 3 2007
Dj Ace
Tallahassee, Florida
I am:
  • Professional
PRo SOund at DJ price!
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Clarity
  • Powerful
    Cons
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Perfect for DJ rig
"I bought a pair to add to my Cerwin Vega setup. They add a whole new scope to my sound. I'll keep my CV subs, but I'm going to replace all my top boxes with the QSC HPR 153i's "
Jun 4 2007
DJ Ace
I am:
  • Audiophile
  • Musically Inclined
  • Professional
  • Tech Savvy
Great Speaker
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • Heavy
    Best Uses
  • None
"I have used JBL MP415's for five years. I wanted to improve and I did just that. Amazing how crisp these things are. If you're looking for the best go no further than the QSC HPR153i. You'll love them! "
Feb 2 2009
Top Sound
Missouri
I am:
  • Professional
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
