Pure Digital Ultra Series 2GB 60 Minutes Pocked Sized Camcorder
#7
4.4
based on 358 reviews
Ratings Distribution
5 star
232
4 star
101
3 star
14
2 star
7
1 star
17
Category Average
4.1
Low Price:
$69.99 at ClubMac
 Trusted:
$78.95 at Adorama
$69.99 at OnSale
see all stores
$69.99 - $179.99
from 9 stores
More Images
Pros
  • Simple controls (110)
  • Comfortable to operate (105)
  • Great picture quality (68)
  • Versatile (56)
  • Durable (49)
  • Great features (49)
  • Great sound (43)
  • Easy to use (9)
  • Easy setup (5)
  • Fast (3)
See less See more
Cons
  • Poor battery life (8)
  • Poor sound quality (8)
  • Low-quality recordings (7)
  • Inadequate features (3)
  • Flimsy (2)
  • Limited zoom (2)
  • Bulky (1)
  • Complicated to operate (1)
  • Difficult to shut off (1)
  • Difficult to use (1)
Best Uses
  • Travel (80)
  • Movies/short films (54)
  • Family (52)
  • Home movies (43)
  • Special events (40)
  • Sports (19)
  • Weddings (18)
  • Editing (8)
  • Documentaries (7)
  • Hd shooting (4)
Provided by WolfCamera.com
It?s the power of video in your pocket. Capture the everyday moments that happen anywhere, and share them with family and friends everywhere. That?s idea behind the new Flip Video Ultra Series. It?s portable, simple to use and amazingly affordable. Shoot anything. Share everything.
Simple to Use
The Flip Video Ultra Series? simple, one-touch recording and compact size make it the ideal choice for shooting video on the go. Capture memories as they happen - no fiddling around with memory cards, chargers or tapes, With four buttons, it?s incredibly simple to record, zoom, playback instantly or delete your videos. Flip Video?s internal flash memory holds up to 60 minutes of high-quality video.
Quality
The new Flip Video Ultra Series line produces video that rivals that of more expensive camcorders. With 2GB of memory, a high-quality microphone and no-glare display, now anyone can make impressive videos.
Built-in FlipShare Software
Flip Ultra comes equipped with FlipShare--Flip Video's new video-sharing solution. FlipShare lets you:
Save and Organize: Watch your videos on your computer whenever you want, and create your own folders to organize your videos, or simply use the automatic date-stamp system.
Publish Online: Upload your videos instantly to YouTube, MySpace, AOL Video and many other websites, all with the click of a button. It?s never been this easy to publish online!
Email Videos: Send your videos privately to friends and family, and select from a wide assortment of included greeting cards to personalize your message.
Edit and Create Movies: Edit individual clips and create custom movies--complete with your favorite music. FlipShare even allows you to capture snapshots from your videos.
  • Simple to use, pocket-sized camcorder with one-touch recording and digital zoom
  • Holds 60 minutes of full VGA-quality video on 2GB of built-in memory; no tapes or additional memory cards required
  • Convenient USB arm plugs directly into your computer for easy viewing and sharing
  • Built-in software lets you easily e-mail videos, upload to YouTube and AOL, and capture still photos from video
  • Watch videos instantly on TV with included cable
    *Please note: Flip Ultra Camcorders manufactured before November 2008 may be pre-loaded with an older version of software. However, if you own one of these units, you?ll be prompted to download FlipShare--free of cost--the first time you connect your camcorder to a computer that is connected to the Internet. You may also download the latest version of FlipShare here: www.theflip.com/softwareupdate.
  • Specification Description
    Model 00042, 605386, 8B27D020, 8B27D220
    UPC 892684000427
    adjustable auto date/timeĀ  Yes
    Audio Recording Yes
    Auto power saveĀ  Yes
    AVI Yes
    Battery Type Product
    Benefits With 2GB of internal flash memory you can snap great videos up to 60 minutes long*1.5" (diagonal) transflective screen makes it easy
    Cables Included A/V cable
    Camera/Camcorder Color Support Yes
    Capacity UOM mAh
    Chemistry Alkaline
    Connector Type USB
    Controls / Adjustments Power, Play, Delete, Record and 4 way navigation
    Controls / Adjustments Power, Play, Delete, Record and 4-way navigation
    Controls / Adjustments Power, play, delete, record, 4 way navigation, copy/move, archive on PC
    Country Of Origin China
    date/time insert Yes
    Description Header Life now has a play button.
    Description Header What will you see today?
    Digital Still Camera Function Yes
    Digital Video Format MPEG4, AVI
    Digital Zoom 2
    Display Catalog Number 16-577
    Display Catalog Number 55026461
    Display Catalog Number 55026462
    Display Catalog Number 55026463
    Display Form Factor Built-in
    Display Size 1.5 inches
    Edit Functions Video truncation (set start/end points)Compose a new Movie Mix (including 6 movie styles)
    Enclosure Color Black
    Enclosure Color Orange
    Enclosure Color Pink
    Enclosure Color White
    End Product Indicator Yes
    Features Tripod mount for steady video recordingUp to 2.5 hour battery life with 2 "AA" alkaline batteries** and auto shut-down to conserve po
    Focal Length 0.8m to infinity
    Image Storage Minimum of 1 second, maximum of 30/60 minutes
    Image Storage Minimum of 1 second, maximum of 60 minutes
    Included in the Box Flip F260B Camcorder"AA" alkaline batteries (2)A/V cableWrist strapPouchQuickstart guide
    Included in the Box Flip F260N camcorder"AA" batteries (2)A/V cableWrist strapPouchQuickstart guide
    Included in the Box Flip F260W CamcorderAA batteries (2)A/V cableWrist strapPouchQuickstart guide
    Included in the Box Flip Video F260P camcorder"AA" batteries (2)A/V cableWrist strapPouchQuickstart guide
    Inputs 1 x USB(USB)
    Integrated Memory 2
    Integrated Memory UOM GB
    JPEG, JPG Yes
    Lens Aperture f/2.4
    Lens System Type Fixed focus
    Light Sensitivity >2.0V/lux-sec
    MAC Operating System Support Mac OS X 10.3.9
    MAC Operating System Support PowerPC G4 1.0 GHz, Intel Core with at least 512 MB of RAMMac OS X 10.3.9SVGA display (1024 x 768) monitor and video card QuickTime 7 or l
    Manufacturer Labor Warranty 90
    Manufacturer Part Number F260N
    Manufacturer Part Number F260P
    Manufacturer Part Number F260W
    Manufacturer Parts Warranty 90
    MAP Price 0.0
    Microphone Type Built-in
    Microphone Type Built-in wide range microphone
    Microphone Type Built-in wide-range microphone
    Model F260B
    Model F260N
    Model F260P
    Model F260W
    MPEG Yes
    New Date Tue Jun 17 00:00:00 CDT 2008
    Operating Temperature UOM ° F
    Optical Sensor Type 1/4" VGA CMOS sensor
    Optical Sensor Type 1\4" VGA CMOS sensor
    Optical Zoom 0
    Outputs 1 x Phone 1/8"(A/V Out), 1 x USB(USB)
    Outputs 1 x USB(USB)
    PC Operating System Support Intel Pentium 4 2.0 GHz computer with at least 512 MB of RAM, Windows XP SP2 or Windows VistaSVGA display monitor (1024x768) and video cardWin
    PC Operating System Support Windows XP SP2 or Windows Vista
    Power Device "AA" batteries (2) (1.5 Volt AA alkaline, Energizer® e2® Lithium®, 1.2 Volt NiMH rechargeable)
    Product Depth 1.25
    Product Dimensions UOM inches
    Product Disclaimer *Recording time may vary based on the recorded content. **Battery life may vary between batteries and use pattern.
    Product Height 4.17
    Product Type Flash memory
    Product Width 2.16
    Recommended Use Video greeting cardsUploading to YouTube, AOL Video, or other web sites
    Required to function PC: Intel Pentium 4 2.0 GHz computer with at least 512MB of RAMPC: Windows XP SP2 or Windows VistaPC: SVGA display monitor (
    Self Timer Yes
    Size AA
    Software Included Flip Video Program integrated into device
    Still Image Format JPG
    Still Image Format VGA
    Supported Languages English
    Time Code Yes
    Type 528x132 Transflective TFT
    Type Transflective TFT LCD (528x132)
    Video Capture 4.5Mbps
    Video Capture 4.5Mbps bitrate
    Voltage 1.5
    Voltage UOM Volts
    White Balance Auto-adaptive white/black balance and exposure
    Pure Digital Ultra Series 2GB 60 Minutes Pocked Sized Camcorder Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 5, 2009
    Pure Digital Ultra Series 2GB 60 Minutes Pocked Sized Camcorder Reviews
    Most helpful positive review
    [80 of 80 customers found this review helpful]
    Most helpful negative review
    [79 of 90 customers found this review helpful]
    4.0
    Good for quick record and spur of moment recording
    "Watch Video Here: http://www.amazon.com/review/R1RSSDPOAQGUTZ I like it because it's small and easy to carry with me and just take out and capture the moment and upload to computer in a few seconds (longer if the program has to convert avi to wma format for utube or email). I would be interested in hearing others that have tried the rca model, and the aiptek a-hd model, so we all can get user experiences compar..." Read Full Review »
    Nov 19, 2007 by richman
    See more positive Pure Digital Ultra Series 2GB 60 Minutes Pocked Sized Camcorder reviews
    1.0
    I might have gotten a bum unit, but...
    "My Flip arrived today in the mail, and I eagerly popped the included Duracell AAs in and started taping my friends. Sadly, on the 5th video, which was all of 10 seconds (the others were shorter still) the Flip froze and said that the video was unplayable. I tried to turn the unit off to restart, but no dice. I waited a few minutes, still nothing. So, I had to remove the batteries to get the thing to turn off..." Read Full Review »
    Nov 06, 2007 by Midnight Sparkle
    See more negative Pure Digital Ultra Series 2GB 60 Minutes Pocked Sized Camcorder reviews
    Displaying 1 - 5 of 358 Reviews
    Show
    Sort by
    4.0
    I would be interested in …"  Read Full Review »
    Was this Digital Camcorder review on the Pure Digital Ultra Series 2GB 60 Minutes Pocked Sized Camcorder helpful to you?
     Report Abuse  (80)  (0)  0 comments
    Nov 19 2007
    richman
    Amazon
    Reviewed at:
    Price: $149.99
    1.0
    "My Flip arrived today in the mail, and I eagerly popped the included Duracell AAs in and started taping my friends. Sadly, on the 5th video, which was all of 10 seconds (the others were shorter still) the Flip froze and said that the video was unplayable. I tried to turn the unit off to restart, b …"  Read Full Review »
     Report Abuse  (79)  (11)  0 comments
    Nov 6 2007
    Midnight Sparkle
    Seattle, WA United States
    Reviewed at:
    Price: $149.99
    [112 of 115 customers found this review helpful]
    Small, Fun and Simple Personal Camcorder
    5.0
    "Watch Video Here: http://www.amazon.com/review/R2Q0D5R9PBKW2O This is a great little camera. It is perfect for quick little movies of your kids etc and would be a nice compact item to take on a vacation. The camera is ridiculously easy to use and the built is software loads straight from the camera …"  Read Full Review »
     Report Abuse  (112)  (3)  0 comments
    Nov 6 2007
    J. A Carty
    Charlotte, NC United States
    Reviewed at:
    Price: $149.99
    [87 of 104 customers found this review helpful]
    My first video review, thanks to this simple but wonderful camcorder :)
    5.0
    "Watch Video Here: http://www.amazon.com/review/R1ODL883RFJZYI Hi :) I just received a new camcorder as a gift. Truth to be told, I'm not very good with anything that has to do with technology, but I was able to learn to use this beauty in 5 minutes, and wanted to try to make my first video review i …"  Read Full Review »
     Report Abuse  (87)  (17)  0 comments
    Oct 24 2007
    Bel Alcat
    Buenos Aires, Argentina
    Reviewed at:
    Price: $149.99
    [72 of 105 customers found this review helpful]
    I like Flip Video
    5.0
    "Watch Video Here: http://www.amazon.com/review/RNA3NY4ZXPWU7 Without needing to boot the program up with an insertion disk, but rather a flip-up USB (hence the product name), this is a very easy item to use. (And besides, it looks like something out of Star Trek.) I appreciated that the directions …"  Read Full Review »
     Report Abuse  (72)  (33)  0 comments
    Sep 29 2007
    Jedidiah Palosaari
    between the cows and the corn
    Reviewed at:
    Price: $149.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
