Presidian DECT 6.0 Cordless Phone with Answering Machine
3.6
based on 12 reviews
Ratings Distribution
5 star
3
4 star
6
3 star
0
2 star
1
1 star
2
Category Average
3.8
Pros
  • Easy setup (10)
  • Nice sound (10)
  • Comfortable handset (8)
  • Compact design (8)
  • Good speakerphone (7)
  • Nice features (7)
  • Strong signal (7)
  • Wide range (7)
  • Big range (1)
  • Easy to use (1)
See less See more
Cons
  • Can't buy extra headsets (1)
  • Lacks features (1)
  • Poor battery life (1)
Best Uses
  • Everyday (10)
  • Home use (10)
  • Outdoors (3)
  • Small spaces (1)
Provided by RadioShack
Experience the difference with this DECT 6.0 cordless phone from Presidian.
Specification Description
Model 43-269
Answering System Type Digital
Battery Type Product
Belt Clip Yes
Benefits DECT 6.0 technology provides you with 1.9GHz Enhanced Cordless TelecommunicationsDigital answering system utilizes microchip technolo
Call Transfer Yes
Call Waiting Yes
Caller ID Yes
Caller ID Memory 30 Names and Numbers
Capacity UOM mAh
Chemistry Ni-MH
Conference Call Capability Yes
Connections RJ11 (1)Barrel input (1)
Cordless Phone Standard DECT
Country Of Origin Vietnam
Description Header Cordless freedom.
Dialed Calls Memory 10 Calls
Dialer Location Handset
Dialer Type Keypad
Digital Transmission Yes
Display Catalog Number 43-269
End Product Indicator Yes
Handset Locator Yes
Included in the Box Presidian cordless phoneBaseAC adapterNi-MH battery
Intercom Yes
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 43-269
New Date Mon Dec 29 00:00:00 CST 2008
Operating Temperature UOM ° F
Power Device AC adapter, Ni-MH battery
Product Depth 6.3
Product Dimensions UOM inches
Product Height 8.3
Product Type DECT phones
Product Weight 0.22
Product Weight UOM pounds
Product Width 3.97
Rechargeable Yes
Recording Capacity 18 Minutes
Ringer Control Yes
Size Specialty
Speakerphone Yes
Speed Dial Capacity 10 Numbers
Supported Languages English
Transmission Band 1.9 GHz
Transmission Band UOM GHz
Voice Mail Capability Yes
Volume Control Yes
Presidian DECT 6.0 Cordless Phone with Answering Machine Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DECT 6.0 Cordless Phone with Answering Machine
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 12, 2009
Presidian DECT 6.0 Cordless Phone with Answering Machine Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Love My Presidian Cordless Phone!
"I love it because I can hear so well on it. There is no static. I can understand what the people say on the answering machine, because it has clarity. I like the fact that, when caller i.d. clicks in, that it is so easy to go over to the call and then come back to your original caller. I am very happy with my purchase that I am now purchasing a single Presidian Dect 6.0 Cordless Phone w/Caller I.D. for my o..." Read Full Review »
Jun 13, 2009 by Connie the Bichon Frise Owner
See more positive Presidian DECT 6.0 Cordless Phone with Answering Machine reviews
2.0
"I just might buy this product again"
"Great phone for a really great price. The only thing is you can not buy any extra stand alone headsets yet like the owners book says you can (it says your phone can support up to six extra headsets). When they come out with the extra headsets (if they ever do)it will be a great phone in my option...." Read Full Review »
Mar 22, 2009 by Likes to buy what is told he can buy.
See more negative Presidian DECT 6.0 Cordless Phone with Answering Machine reviews
Displaying 1 - 5 of 12 Reviews
Show
Sort by
5.0
    Pros
  • Comfortable Handset
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
  • Outdoors
"I love it because I can hear so well on it. There is no static. I can understand what the people say on the answering machine, because it has clarity. I like the fact that, when caller i.d. clicks in, that it is so easy to go over to the call and then come back to your original caller. I am ver …"  Read Full Review »
Was this Cordless Telephone review on the Presidian DECT 6.0 Cordless Phone with Answering Machine helpful to you?
Jun 13 2009
Frankfort, IN
I am:
  • Quality Oriented
Reviewed at:
[3 of 3 customers found this review helpful]
good buy for the price
4.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
    Cons
  • None
    Best Uses
  • Everyday Use
"Looks good. Has led charging light. Its easy to setup. Sound is good in my apartment. Not sure about the range though as my apartment is pretty small. "
 Report Abuse  (3)  (0)  0 comments
Dec 8 2008
Mike
San Bruno CA
I am:
  • Value Oriented
Reviewed at:
Finally - a Dect 6 phone w. a WALL mount
5.0
    Pros
  • Easy To Set Up
  • Good Sound
  • Nice Features
  • Strong Signal
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
"I was hesitant about purchasing this phone since I had never heard of the 'brand' but since it was the only dect-6 phone that I found with a wall-mount I took the chance. (Wanted it as my kitchen phone where the phone jack is wall mounted and very visible.)
So glad that I did. The set-up was very e …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 7 2009
Senior Nerd
Somerset County, NJ
I am:
  • Quality Oriented
Reviewed at:
2.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • Lacks Features
    Best Uses
  • Everyday Use
  • Home Use
"Great phone for a really great price. The only thing is you can not buy any extra stand alone headsets yet like the owners book says you can (it says your phone can support up to six extra headsets). When they come out with the extra headsets (if they ever do)it will be a great phone in my option. "
Mar 22 2009
Metuchen, New Jersey
I am:
  • Quality Oriented
Reviewed at:
Excellent bang for your buck
4.0
    Pros
  • Big Range
  • Compact design
  • Easy To Set Up
  • Good Sound
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Home Use
  • Outdoors
  • Smaller Spaces
"I'm using this system to replace a ten year old digital answering machine (which was still good anyways) and a terrible 3 year old 5.8 Ghz Radio Shack brand phone. This is a trade that was totally worth it for me... that 5.8 tech is garbage. Need a phone? Buy this one. "
Feb 21 2009
TT
DeKalb, IL
I am:
  • Value Oriented
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
