Presidian DECT 6.0 Cordless Phone with Answer Machine
4.0
based on 19 reviews
Ratings Distribution
5 star
8
4 star
7
3 star
1
2 star
2
1 star
1
Category Average
3.8
Pros
  • Nice sound (14)
  • Comfortable handset (13)
  • Compact design (13)
  • Easy setup (12)
  • Nice features (12)
  • Strong signal (11)
  • Good speakerphone (8)
  • Wide range (5)
  • Big range (3)
  • Durable (1)
See less See more
Cons
  • Delete cid each handset (1)
  • Lacks features (1)
  • Missing wallmount bracket (1)
  • No wall mount bracket (1)
  • Phone keys could be large (1)
  • Speaker only problem (1)
  • Timedate not automatic (1)
  • Tollsaver only 4 rings (1)
Best Uses
  • Everyday (16)
  • Home use (9)
  • Outdoors (2)
  • Small spaces (2)
  • Office (1)
  • Poolside and garage use (1)
Provided by RadioShack
Expand your cordless phone network with this DECT 6.0 system.
Specification Description
Model 43-262
Additional Handsets Qty 1 Handsets
Base Depth 4 inches
Base Height 3 inches
Base Weight 3.5 oz
Base Width 5 inches
Battery Type Product
Belt Clip Yes
Benefits DECT 6.0 technology provides you with 1.9GHz Enhanced Cordless TelecommunicationsDigital answering system utilizes microchip technolo
Call Hold Yes
Call Waiting Yes
Caller ID Yes
Capacity UOM mAh
Chemistry Ni-MH
Country Of Origin Vietnam
Depth 3 inches
Description Header Expand your network.
Dialer Type Keypad
Digital Transmission Yes
Display Catalog Number 43-262
Display Languages English and Spanish
Display Location Handset
End Product Indicator Yes
Height 6 inches
Included in the Box Presidian answering machine baseHandsets (2)AC adapterNi-MH battery
Manufacturer Labor Warranty 12
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Base Units Supported 1 Base Units
Max Handsets Supported 6 Handsets
Model 43-262
Multiline Operation Capability Single-line
New Date Tue Dec 23 00:00:00 CST 2008
Operating Temperature UOM ° F
Product Type DECT phones
Rechargeable Yes
Ringer Control Yes
Size Specialty
Speakerphone Yes
Supported Languages English
Transmission Band 1.9 GHz
Transmission Band UOM GHz
Voice Mail Capability Yes
Volume Control Yes
Width 2.5 inches
Presidian DECT 6.0 Cordless Phone with Answer Machine Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DECT 6.0 Cordless Phone with Answer Machine
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 23, 2009
Presidian DECT 6.0 Cordless Phone with Answer Machine Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
Best in the market
"early Jan, 2009 - date purchased Presiden 43-262 is excellent and most dependable ... great features & sound quality, wide range & hassel free. No whiz w/ great bang! Never looked into it as I was brand concious. Using Panasonic phones for 30 years using updated versions of cordless w/c worked perfectly for home use until the nightmare began a few months ago when I bought KX-TG9333T, big mistake. When my fir..." Read Full Review »
Feb 09, 2009 by Cristina
See more positive Presidian DECT 6.0 Cordless Phone with Answer Machine reviews
1.0
Hard to set up handsets.
"I bought this phone for my daughter and son-in-law for their home use since it is expandable (up to six). The first phone had an electrical short in the base handset that gave an intermittent "ssst" sound. Called the store and was told to bring the whole set back and exchange it because the handset alone could not be changed out since it was pre-programmed to work with that particular base. My daughter packed..." Read Full Review »
Jan 05, 2009 by LaDon Beasley
See more negative Presidian DECT 6.0 Cordless Phone with Answer Machine reviews
Displaying 1 - 5 of 19 Reviews
Show
Sort by
Best in the market
5.0
    Pros
  • Big Range
  • Comfortable Handset
  • Compact design
  • Easy To Set Up
  • Excellent sound quality
  • More »
    Cons
  • None
    Best Uses
  • Home Use
Using Panasonic phones for 30 years using updated versions of cordless w/c wor …"  Read Full Review »
Was this Cordless Telephone review on the Presidian DECT 6.0 Cordless Phone with Answer Machine helpful to you?
Feb 9 2009
Cristina
New York, NY
I am:
  • Quality Oriented
Reviewed at:
[3 of 3 customers found this review helpful]
Satisfaction....
5.0
    Pros
  • Big Range
  • Compact design
  • Durable
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
  • Smaller Spaces
"Great phone for the price. I live in rural America and have problems w/ interference on other cordless phones i have tried. Even the high end phones do not measure up to this phone. Works and sounds great. Very pleased with this cordless phone. "
 Report Abuse  (3)  (0)  0 comments
Oct 20 2008
RAZZEL
America,U.S.A.
I am:
  • Quality Oriented
Reviewed at:
1.0
    Pros
  • Good Sound
  • Good Speakerphone
    Cons
  • None
    Best Uses
  • Everyday Use
"I bought this phone for my daughter and son-in-law for their home use since it is expandable (up to six). The first phone had an electrical short in the base handset that gave an intermittent "ssst" sound. Called the store and was told to bring the whole set back and exchange it because the handse …"  Read Full Review »
 Report Abuse  (0)  (1)  0 comments
Jan 5 2009
LaDon Beasley
Corpus Christi, Texas
I am:
  • Quality Oriented
Reviewed at:
[1 of 1 customers found this review helpful]
Really good phone
4.0
    Pros
  • Compact design
  • Good Sound
  • Strong Signal
    Cons
  • None
    Best Uses
  • Everyday Use
  • Smaller Spaces
"After having two Vtech phones that had a short lifespan, I decided to give Persidian a try. The phone is good quality at an affordable price. Voices on the other end come thru clear and the answering machine sound also is easy to understand when playing back messages. I will keep the owner's manu …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 21 2008
K&J
Tomah, WI
I am:
  • Quality Oriented
Reviewed at:
[2 of 2 customers found this review helpful]
I love my Presidian Dect 6.0 Phone
5.0
    Pros
  • Compact design
  • Easy To Set Up
  • Good Sound
  • Good Speakerphone
  • More »
    Cons
  • None
    Best Uses
  • Everyday Use
"I use the phone for personal use at home. Being hard of hearing the ringer and voice message is loud enough that I can hear it. I have no complaints about the phone at all. "
 Report Abuse  (2)  (0)  0 comments
Apr 12 2009
HaroldSays
Scranton PA
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
