Premier Mounts Universal Flat Panel Mount for 37"-61" LCD/Plasma Displays - PCM-MS2
#363
4.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
$121.99 - $164.99
from 9 stores
More Images
Pros
  • Easy assembly (1)
  • Easy to wire (1)
  • Supports weight (1)
See less See more
Best Uses
  • Convenience (1)
  • Space saver (1)
Provided by CSN Stores
This universal version of the PCM wall mount fits most plasma or LCD screens from 37” to 61”. It utilizes Premier’s revolutionary Griplate System. This system accurately supports the appropriate mounting hardware and its ‘teeth’ set within detents along the mounting bracket for a solid fit while securing the plasma or LCD. This eliminates the need for excessive torque on the mounting hardware that most universal products require, ensuring stability and durability over an extended period of time.
The Clevis plasma wall mount makes mounting your display easy with its unique dual-plate and sliding-rod systems. Designed for horizontal plasma mounting, the Clevis Plasma Mount's exclusive heavy-duty, 1/2"-diameter, steel sliding rods support the display, allowing lateral movement for precise horizontal placement. Once mounted, the plasma display can be left in a flat position or tilted up to 10 degrees to achieve the desired viewing angle. The bracket hook tension adjusts to accommodate the plasma display's weight and holds the display securely in the desired tilt position.
Best of all, this mount is guaranteed to be in stock. Any orders placed before 1:00pm EST will ship out SAME DAY!
Features:
  • Fits most plasma or LCD screens from 37” to 61”
  • Griplate System ensures a solid fit to secure the display
  • Forward tilt adjusts from 0 to 10 degrees
  • Mounts to studs on 16” or 24” centers
  • Sliding-rod system allows lateral movement for precise horizontal placement
  • Exclusive heavy-duty, 1/2"-diameter, steel sliding rods support the display
  • Plasma mounts 2.331" from wall
  • Bracket hook tension adjusts to accommodate the plasma display's weight and holds the display securely in the desired tilt position
  • Dark Charcoal Gray finish (Sinterflex)
  • Includes standard mounting hardware for wood studs
  • Mountable to concrete and reinforced metal studs when used with appropriate hardware (sold separately)
  • Comes with manufacturer's limited lifetime warranty
PCM-MS2 Clevis Plasma Wall Mount Installation Instructions
PCM-MS2 Clevis Plasma Wall Mount Technical Data
NOTE: A signature is required for all Premier deliveries
Need professional installation? Use the or the ! Give us a call with any questions!
Specification Description
Model PCM-MS2, PCMMS2, PMMPCMMS2
UPC 829973150327
Compatibility Wall Mounts
Country Of Origin Taiwan
Premier Mounts Universal Flat Panel Mount for 37"-61" LCD/Plasma Displays - PCM-MS2 Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 10, 2007
Premier Mounts Universal Flat Panel Mount for 37"-61" LCD/Plasma Displays - PCM-MS2 Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Premier Mount
4.0
    Pros
  • Easy to Assemble/Wire
  • Easy to Wire
  • Supports Weight
    Cons
  • None
    Best Uses
  • Convenience
  • Space Saver
"Overall great, tv is up high,so wish it tilted down just a little more. "
Was this TV Wall Mount review on the Premier Mounts Universal Flat Panel Mount for 37"-61" LCD/Plasma Displays - PCM-MS2 helpful to you?
Oct 10 2007
mb
New Jersey
I am:
  • Practical
Reviewed at:
[1 of 1 customers found this review helpful]
Re: Wall Mount
5.0
"this mount was exactly what we were looking for and could not find in any box store. it was simple to install and had clear instructions included. "
 Report Abuse  (1)  (0)  0 comments
Mar 20 2007
ms.b
maryland
Reviewed at:
Price: $150.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
