Premier Mounts Clevis Plasma Display Wall Mount (Multi-Use)
#369
3.0
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
1
Category Average
4.4
Low Price:
$125.00 at Racks and Stands
 Trusted:
$125.00 at Mounts and More
Find it at Amazon
$125.00 - $185.00
from 3 stores
Pros
  • Adjustable (1)
  • Easy to install (1)
  • Interfaces well with tv (1)
  • Multiple viewing angles (1)
  • Perfect fit (1)
  • Sturdy (1)
See less See more
Cons
  • Limited adjustability (1)
  • Poor interface with tv (1)
Best Uses
  • Office (1)
Provided by Premier Mounts Central
The CTM series brings the benefits of the PCM and adds the versatility of mounting to stands, carts and suspension devices. The Clevis Mount makes mounting your display easy with its unique plate and sliding-rod systems. Designed for horizontal plasma mounting, the Clevis Mount's exclusive heavy-duty, 1/2"-diameter, steel sliding rods support the display, allowing lateral movement for precise horizontal placement. Once mounted, the plasma display can be left in a flat position or tilted up to 12 degrees to achieve the desired viewing angle. The bracket hook tension adjusts to accommodate the plasma display's weight and holds the display securely in the desired tilt position.
Features:
  • Can be mounted to stands, carts and suspension devices
  • Forward tilt adjusts from 0 to 12 degrees
  • Mounts to studs on 16” or 24” centers
  • Sliding-rod system allows lateral movement for precise horizontal placement
  • Exclusive heavy-duty, 1/2"-diameter, steel sliding rods support the display
  • Plasma mounts 2.294" from wall
  • Bracket hook tension adjusts to accommodate the plasma display's weight and holds the display securely in the desired tilt position
  • Dark Charcoal Gray finish (Sinterflex)
  • Includes standard mounting hardware for wood studs
  • Mountable to concrete and reinforced metal studs when used with appropriate hardware (sold separately)
  • CTM-VESA plate works for VESA 200 x 100 TVs
  • Comes with manufacturer's limited lifetime warranty
NOTE: A signature is required for all Premier deliveries
Premier Mounts Clevis Plasma Display Wall Mount (Multi-Use) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 29, 2008
Premier Mounts Clevis Plasma Display Wall Mount (Multi-Use) Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Problem between Mount and Stand
1.0
    Pros
  • None
    Cons
  • Limited Adjustability
  • Poor Interface With TV
    Best Uses
  • None
"The fit between the stand and the mount was not correct. A make-shift effort was put forth to mount the tv to the stand.
(Stand was excellent - sturdy and clean looking, however without a firm connection to the tv mount it wasn't ideal) "
Was this TV Wall Mount review on the Premier Mounts Clevis Plasma Display Wall Mount (Multi-Use) helpful to you?
Sep 26 2007
Chris
NY
I am:
  • Tech Savvy
Reviewed at:
Price: $125.00
Excellent piece of hardware!
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Perfect fit
  • More »
    Cons
  • None
    Best Uses
  • Office
"We used this Clevis mount to secure a 42" LCD onto a Premiere floor stand. We're using the display as an accent piece on our television news set. "
Sep 29 2008
Television Studio
Vermont
I am:
  • Casual User
Reviewed at:
Price: $125.00
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
