Polk Audio SC85i (Ea) 2-Way In Wall Speaker
3.0
based on 1 review
Ratings Distribution
5 star
0
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
4.4
Pros
  • Easy to connect (1)
See less See more
Best Uses
  • Smaller rooms / apartments (1)
Provided by OneCall
SCi Series In-Wall/In-Ceiling Loudspeakers have been designed from the ground up to be our best entry level custom install product. Several of the SCi Series speakers share cutout sizes and accessories with other products for the utmost in install flexibility and performance compatibility, another way Polk Audio combines performance and value.
SC85i Features:
  • Dynamic Balance(TM) polymer composite 8-inch midwoofer driver for smooth wide-range response with low distortion.
  • 1-inch Aimable silk dome tweeter with neodymium magnet for clear, detailed highs and direct control; excellent imaging even for off-axis listening positions.
  • Wide dispersion design for uniform sound-coverage throughout even large rooms.
  • Durable, moisture resistant materials, including Butyl Rubber surrounds, for safe use in kitchen, bath & sauna.
  • Stainless steel mounting screws.
  • Infinite Baffle Tuning uses the virtual enclosure of in-wall space for superior bass response.
  • Paintable, powder-coated Aluminum Grille allow SC85i to virtually disappear in any room!
  • Installation is easy as 1-2-3: cut one hole, feed the wires, and simply drop the speaker in. Rotating Cams secure the speaker safely with no extra assembly or mess.
  • Pre-Construction bracket (part number PB85, bracket for SC/RC85) is available.
  • Sold singly (packaged one per box). Single units can be used for center channel applications in stealth installs!
  • Specification Description
    Model SC85i
    UPC 747192112493
    Color White
    Depth (Inches) 3.43
    Frequency Response 30Hz - 20kHz
    Height (Inches) 14.31
    Impedance 8 ohms
    Speaker Terminals Spring Terminals
    Speaker Type In-Wall
    Tweeter Size (Inches) 1
    Weight (Pounds) 3.7
    Width (Inches) 10.06
    Woofer Size (Inches) 8
    Polk Audio SC85i (Ea) 2-Way In Wall Speaker Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: SC85i (Ea) 2-Way In Wall Speaker
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Feb 17, 2009
    Polk Audio SC85i (Ea) 2-Way In Wall Speaker Reviews
    Displaying 1 - 1 of 1 Reviews
    Show
    Sort by
    Polk SC85i speakers
    3.0
      Pros
    • Easy To Connect
      Cons
    • None
      Best Uses
    • Smaller Rooms
    "Compared in the same location, the sound quality of Boston Acoustics DSi460 was superior to the Polks "
    Was this Speaker & Subwoofer review on the Polk Audio SC85i (Ea) 2-Way In Wall Speaker helpful to you?
    Feb 17 2009
    Better Buying
    Boston, MA
    I am:
    • Musically Inclined
    Reviewed at:
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
